Porting MySensors to work with the RadioHead library
    @Yveaux said:
    Works like a charm, after I disconnected the interrupt line to the nRF24.
    I went through the RadioHead code, looking for enabled INT0 interrupts, interrupts handlers etc. in nRF24 code.
    Found none, so tested again today, with the interrupt line connected.
    Now it also works with interrupt connected...
    Don't know what went wrong before.
    @Yveaux Good to hear that it is working out for you. I'm very curious to see whether you can get my version of the library working with your radio.
    I have posted on the Radiohead group to see whether they can implement a generic sleep function in the driver or in the manager. This would make it much easier for us to put everything to sleep when required. Short of that the only reasonable solution I can see to fix this is to create a sleep function in the sensor source code and pass this as a parameter to the library. Alternatively we can build a different sleep functions in the library, but I guess this will cause the same problems as you talked about earlier with bringing in a lot of code we do not need.
    Ah great! Let's see how flexible they are 😉
    Btw. I'm not totally dismissive of the idea of making small changes to the RadioHead library when it makes our life easier to get a clean interface for MySensors users. Indeed, we have to sync changes (which are almost on a daily basis right now, but that will settle over time) but when the changes to the original library are relatively small this won't be too hard.
    Anyway, let's not give up yet and see if we can use the vanilla library.
    I created a github repo containing the RadioHead sources, including change history. The code is commit using a script, so future updates can easily be added.
    IMHO having the RadioHead library sourcecode under version control is a requrement for inclusion in MySensors and if we ever decide to make small changes to the library we can now easily fork from the original sourcecode.
    Get it at https://github.com/Yveaux/RadioHead
    @kolaf
    Agree on keeping the radio specific sleeping in each driver is the best option.
    Are we talking here about
    (1) each radio driver having its own full sleep library to put the processor to sleep (potentially in addition to the sleep library used by the main sketch), or
    (2) just each radio driver having its own function to put its radio into low power mode with/without IRQ?
    Just (2)
    Good. Let's call it prepare-to-sleep or power-down or something rather than sleep.
    @Zeph Fair enough.
    Since I'm not getting any response on their mailing list, perhaps we should just go ahead and implement something. My plan is to create a virtualised powerdown in RHGenericDriver and then implement a reasonable default at least for the two radios we use. We can then expand this as we gain more experience. I know that for the RF69 driver this should be no more than five minutes work. Does anyone want to take care of your radios?
    If it works out, we can send them a patch 🙂
    Scratch my previous messages. I took a new look at the documentation and there appears to be a function setMode which can set the radio to TX, RX, and idle. I think the idle mode is as close as you come to sleeping, and I know that several of the drivers have a function called setIdleMode which you can use to define how the radio sleeps. This means that we can initialise the sleep function in the same way as we initialise the the other radio specific parameters (e.g. power and frequency), and then simply set the radio to the generic idle mode when sleeping.
    Just a small update on my effort to get RadioHead & MySensors working with nRF24L01+...
    I managed to get the node configured correctly using the MySensors 'defaults'.
    I see data getting sent over the air (as my sniffer captures it). The only data on air, captured by Wireshark, is:
    ff:7e:01:00:ff:7e:00:52:00:01:01:00
    ff:7e:02:00:ff:7e:00:53:00:01:01:00
    ff:7e:03:00:ff:7e:00:54:00:01:01:00
    ff:7e:04:00:ff:7e:00:55:00:01:01:00
    etc.
    Roughly 4 seconds apart.
    I have to dive deeper into the protocol , but I suspect this is the node sending broadcasting requests to find a parent.
    The gateway doesn't acknowledge these broadcasts yet...
    Fixed a few small issues in the nRF24 driver along the way (see https://github.com/Yveaux/RadioHead/commits/MySensors/RadioHead/RH_NRF24.cpp)
    Seems like I'm almost there!
    Some things I miss in the library:
    • Normally the nRF24 changes its destination address when sending to the destination's node address. The current driver/RadioHead implementation just always broadcasts and the header of the data determines which node the data is really for. This means any node within range will always have to process all messages coming in to determine if they are meant for it or not. From a generic driver point-of-view I understand this approach, but it ignores powerful functionality of the nRF24. As the nRF24 is still the main radio target for the MySensors library we might have to think about a solution.
    • The library does not use the auto-acknowledge feature of the nRF24 but instead seems to retry on application level. Another nice feauture of the nRF24 which remains unused...
    I would guess it is a arp request. Weird that it does not use the radio properly, I think both addressing and retransmission works well with rf69.
    Using auto-ack would be impossible (i think) using the in radioheads mesh-setup where every message basically is a broadcast.
    I wondoer if it would it be possible to implement a mySensors class similar to RHMesh which actually works like MySensors do today using a star-topology and direct-addressed messages?
    radiohead uses direct messaging, with an arp protocol and route discovery to build local routing tables, much as original mysensors. At least as far as I understand it.
    Do you use the same library in both the sensor and gateway? It won't work of you mix network layer protocols.
    @kolaf with hop by hop acknowledgements
    Ok, read a bit through the docs. Apparently this is what is sent:
    RHDatagram:  ff:7e:01:00     (TO:FROM:ID:FLAGS)
    RHRouter:    ff:7e:00:52:00  (DEST:SOURCE:HOPS:ID:FLAGS)
    RHMesh:      01:01:00        (ROUTE_DISCOVERY_REQUEST:<RESERVED>:DEST)
    Therefore the destination and source address are sent TWICE (destination even 3 times with nRF24, as the destination address is part of the nRF24 header). An ID byte (incremented with each message sent) is also present in RHDatagram & RHRouter.
    After the route is known, sending through RHMesh still requires 1 byte to indicate application payload is transmitted.
    For short, Every message will require 10 bytes header, at least, to which the MySensors payload is added (including its own header of currently 4 bytes) giving at least 14 bytes overhead of 32 bytes total.
    To me this feels like too much....
    Yep, a 10 byte header is a lot.
    @hek Maybe we should just use reliable datagram. The ms header could contain just "source, destination, and last", and rhreliabledatagram deals with hop by hop ack and addressing.
    @kolaf Just because of the size of the header?
    I would prefer to use the RadioHead library also for routing, but maybe the current implementation can be made more efficient, in terms of header length and also code space.
    Currently I can barely fit in a simple sensor example and Ethernet gateway also gives warning about ram usage...
    Got it to work with nRF24!
    Still some issues every now and then and I have to verify the radio config but messages are exchanged between node & gateway, using RHMesh.
    Can't believe I ran into the same trap again as with the CRC8 calculation (remember @hek ?)
    sizeof(message) in MySensor::sendWrite is 33 bytes, which is one byte more than nRF24 can send, causing all transmissions to fail...
    See my changes here: https://github.com/Yveaux/Arduino/commits/radiohead_port
    @Yveaux maybe I could give you write access to my repository. Will be much easier if we are working on the same thing, less hassle with keeping up to date.
    @kolaf OK, fine, but it's working now so I don't plan on much changes anymore.
    Could you merge all 1.4 changes to your fork? I feel it's quite running behind.
    Next I'll focus on a Wireshark dissector, as I'm not convinced everything on air is needed/correct...
    It would be great BTW if the sniffer would work with the Radiohead drivers, so it supports different radios....
    I pulled in the latest eight commits, merged, and pushed. I think I should be completely up-to-date with the development branch.
    @Yveaux I think you have to submit a pull request for me to merge your changes in.
    @kolaf I think I just merged everything in your repo... This is all a bit new to me 😉
    @Yveaux Got it, thanks.
  • Code Contributor
    @hek said:
    RadioHead library does not store any routing info in eeprom so everytime a node is powered up it need to rebuild this.
    That's beneficial in terms of available EEPROM space for other purposes - but would be interesting to see the shit-storm after a power-outage when all nodes power-up at the same time and need to rebuild the entire network tree from scratch?
  • Code Contributor
    Just a thought (I did NOT review the entire RH code) - from the RH documentation it sounds like we could use the RH Drivers without using any of the RH Managers - keeping routing etc. within MySensors responsibility.
    Just checking as it appears that @kolaf and @Yveaux have spent significant time reviewing the code and I would want to understand if that's an option or a totally stupid idea 🙂
    @ToSa It is definitely not a stupid idea, it is a variation of what I suggested previously which you quoted in your post (using the reliable datagram manager instead). It is a question of the abstraction level we want to use. Personally I prefer to use a library where everything is built in and that has widespread use. This gives us much more features for "free", and depending on the user base also a lot more testing. However, it turns out that not everything is perfect. The header is too big, and the library is perhaps not as efficient as it could be.
    This boils down to whether we should do things more efficiently ourselves, or try to fix the library, either officially or unofficially. It looks like the maintainer of the project is very open to suggestions. In fact, I just saw a post where he said he had implemented a generic powerdown mode for all the drivers that I suggested a few days ago. My guess is that if we work with him we could get a lean and mean radio library which could benefit both the MySensors project and the Arduino community as a whole. There appears to be people here with quite good radio knowledge, so think this could be a very powerful combination. Still, it is a question of time, effort, and priorities...
    @kolaf I totally agree with you.
    The MySensors library currently has a solid nrf24 implementation and routing works fine (though not fully mesh) so there's no direct need to switch driver and routing layer.
    This is a roadmap item on which we should continue working, IMO together with the RadioHead development. The RadioHead library has only recently been developed (few months old or so) and is already very mature looking. This is very promising for the future and there's no use in developing/maintaining 2 nearly identical libraries.
    I think the current flaws (e.g. code & message size) can be improved with our help making it a solid base for MySensors.
  • Code Contributor
    Thanks @kolaf @Yveaux.
    makes sense - I thought "just" using the drivers at least as an interim step could give us a head-start but it appears that the majority of the "issues" with RH need to be fixed on the driver level anyways so we would still need to work these first with the RH team...
    I think the addressing is not that bad: the TO/FROM is actually the next/last used in MySensors - only for a single-hop communication these are the same as SOURCE/DEST. With that FROM/SOURCE/DEST in RH == last/sender/destination in MySensors. The TO (next) is the one that is unnecessary because it's part of the nRF24 header - as this is not the case for all radios, this should be adjusted in the NRF24 specific code in RH and shouldn't be that hard to do.
    The ID fields are used to determine if a packet is a duplicate (once for the hop and once end-to-end). I'm wondering how this is done in MySensors today. For the single hop that's probably part of the nRF24 internals (auto-acknowledge / auto-resend) and maybe it could be avoided on the driver level in RH but probably needs some tweaking of ReliableDatagram as well. For e2e I don't think there is an equivalent in MySensors today and it might actually be a valuable add rather than a waste of a byte 🙂 what could happen without it: a node receives a packet and sends an ack - the ack does not make it to the sender and therefore the sender submits the same packet again - the node receives the package once again and thinks it's a new packet... think about a command that toggles a light - woulc toggle twice and go off->on->off instead of off->on.
    The FLAGS bytes appear to be a total waste of space.
    • Looking at the first FLAGS byte it's actually defined on the driver level already but not used in Driver or Datagram but only in ReliableDatagram and the only flag set is RH_FLAGS_ACK - a full byte for a single bit worth of information... The two options would be to either remove that byte and mark ACK packets differently or to just make use of the remaining 7 bits for other purposes. I would prefer using the 7 bits - protocol version (3 bits) is definitely a good fit - command (3 bits) might be the other. Using the lower four bits of FLAGS for application layer purposes is even foreseen in RH (and could be easily changed to use 6 bits for app layer in RHGenericDriver.h)
    • The benefit of the second FLAGS byte (from the Router) is totally unclear to me. It seems like the neither RHMesh nor RHRouter code uses it at all even if it's defined on that level so nothing else should use it either... worth a discussion with the RH team - and either remove it completely or use it again for app layer specific stuff (MySensors type?). I'm surprised that they don't use these FLAGS instead of the first byte of RHMesh messages to determine route discovery vs. app date vs. ...
    Assuming that we can get rid of the "TO" and the "driver level ID" and make use of the FLAGS fields as mentioned above the header would be:
    • RHDatagram: FROM:FLAGS (covering MyMessage last / ack / version / command)
    • RHRouter: DEST:SOURCE:HOPS:ID:FLAGS (covering MyMessage destination / sender / type)
    • RHMesh: one byte to determine "application data" - tbc if this can be moved to the FLAGS instead consuming less than a full byte. at least the MyMessage "payload type" can be included in that byte
    • MyMessage header: none (would need to talk to @hek but I think MyMessage::sensor should actually not be part of the header anymore but part of specific message types only).
    This would leave us with 2+5+1=8 bytes instead of the current 7 bytes for the header (to be fair 8 instead of 6 due to the removed sensor field). That's not as bad as 14!
    Yes, that makes sense.
    Reply from Mike:
    Some of your contributors have the wrong idea about the headers.
    There are 4 header bytes used by drivers, RHDatagram and RHReliableDatagram
    TO
    FROM
    ID
    FLAGS
    These are the hop-to-hop headers. In fact they are present in the payload (but
    effectively unused) even if you use the drivers directly.
    RHRouter and RHMesh (if you use them) add
    DEST
    SOURCE
    HOPS
    ID
    FLAGS
    these are end-to-end headers and are not necessarily the same as the hop-to-
    hop headers. In the general case they will be different values.
    In my view all these header are all necessary.
    BTW, new version 1.33 supports sleep mode for RH_RF69, RH_RF22, RH_NRF24,
    RH_RF24, RH_RF95 drivers.
    Cheers.
  • Code Contributor
    @hek said:
    Reply from Mike:
    yep 🙂
    Well, debatable at least for the FLAGS (or the size of the FLAGS).
    Three questions (@Mike, if you are reading here, just reply directly, otherwise I'll contact you via the RH channels...):
    • is the RH library itself using the end-to-end FLAGS? I couldn't find any reference other than setting it to 0 (when using RHMesh).
    • is the RH library itself using the hop FLAGS for anything other than identifying ACK packets (RH_FLAGS_ACK / RH_FLAGS_NONE)?
    • for the hop ID and TO - if the specific RF chip supports this internally (as part of the preamble/header the chip adds to the on-air packet), why duplicating this wasting valuable payload size - the driver for the specific RF chip could handle it internally and make it look the same for the outside world using the RHGenericDriver interface without changes... I'll give it a try and let you know.
    @hek Thanks for getting Mike 'on board'! Good move!
    Great work guys. I'm glad to see some enthusiasm for this as it will allow me to utilise the platform and not have to reinvent the wheel 🙂
  • Code Contributor
    Test compilation comparing code size with current MySensors 1.4 radio library and with radiohead. The radiohead integration to MySensors is not optimized (pushing full MySensors header through even if the radiohead header has the same content etc.) and the radiohead library provides some benefits (not just a 1:1 replacament) - so it's expected to be larger. Based on the two examples below it's right now about 4-5k flash and ~800 ram for global variables.
    => let's see how far we can get that down reducing the duplication of header data etc.
    **SerialGateway with MySensors: **
    Sketch uses 17,566 bytes (57%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 688 bytes (33%) of dynamic memory, leaving 1,360 bytes for local variables. Maximum is 2,048 bytes.
    SerialGateway with RadioHead:
    Sketch uses 22,242 bytes (72%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,455 bytes (71%) of dynamic memory, leaving 593 bytes for local variables. Maximum is 2,048 bytes.
    **DallasTemp with MySensors: **
    Sketch uses 20,288 bytes (66%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 551 bytes (26%) of dynamic memory, leaving 1,497 bytes for local variables. Maximum is 2,048 bytes.
    DallasTemp with RadioHead:
    Sketch uses 24,592 bytes (80%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 1,319 bytes (64%) of dynamic memory, leaving 729 bytes for local variables. Maximum is 2,048 bytes.
  • Code Contributor
    @ToSa Wonder what the runtime values are...
    What radio/Arduino IDE did you compile for?
    For Serial Gateway, nrf24, Arduino 1.5.7 I get:
    Sketch uses 20.962 bytes (64%) of program storage space. Maximum is 32.256 bytes.
    Global variables use 1.471 bytes (71%) of dynamic memory, leaving 577 bytes for local variables. Maximum is 2.048 bytes.
    @Damme
    Currently MySensor::setRadio creates an instance of RHMesh at runtime, so RAM usage is even worse...
  • Code Contributor
  • Code Contributor
    nRF24 / 1.5.6-r2
    DEBUG turned on - your values appear to be with DEBUG turned off
    I did a few changes starting to reduce the header so I can't rerun with DEBUG off and compare right now...
    A small digression from the main topic here, but I just tested the mesh functionality of the library. I took a laptop with a serial gateway outside of the range of my sensor and observed that it stopped working. I then went back a few metres and powered up a battery powered sensor which basically just sent hello every second and processed messages. I was able to significantly extend my range, experiencing only a few seconds of interrupt in the ping flow.
    Moving back and powering down the intermediate node, the direct route was reestablished within a new couple of seconds and everything was working correctly again 🙂 I think I will have much fun playing with this.
    @kolaf said:
    I was unable to significantly extend my range, experiencing only a few seconds of interrupt in the ping flow.
    Shouldn't that be "I was able"?
    I want to be happy with you, but not sure now 😉
    You are most certainly correct, I have edited my original post. I'm suffering a bit from tendinitis, so I'm using speech recognition when I write. Sometimes it recognises almost exactly what I say 😉
    What are the differences between the MySensors protocol and RH in terms of mesh dynamics?
    I'm guessing that RH is more dynamicly configured, but I'd like to understand more.
    @kolaf ah, great to see your results then!
    I read some mixed results on the Radiohead mailing list regarding mesh, so good to see it's working for you.
    BTW I'm in the progress of writing wireshark directors for Radiohead which can be used with the nrf24 sniffer. It'll give us better insight on Radiohead's performance and functioning.
    It makes sense to migrate the MySensors last,sender and destination bytes to RH from,source,dest.
    I do not think it makes sense to move type (V_code) or command into the RH FLAGs. Typically when such space is reserved for the protocol in the header but not yet fully used, it's subject to change as the protocal evolves. If part of the goal is to take advantage of the maintenance and ongoing development of RH, we don't want to set up a conflict - because other users are not going to use those FLAGs our way anyway.
    Basically, Radio Head should be concerned with delivering a payload (set of bytes) to a node. Everything specific to just the MySensors application should be in the payload (as seen by RH). That includes:
    • child id ("sensor")
    • command
    • V_code ("type")
    • version (if needed)
    • ack - is this still needed??
    If we want to remain compatible with other RH users (ie: their development), rather than re-allocating bytes or bits in the RH header to our own purposes, we would be putting our MySensors' header in the RH payload, but omitting from our header the redundant fields which are handled by RH:
    • last,
    • sender,
    • destination
    The RH payload would include the reduced MySensors header plus the MySensors payload.
  • Code Contributor
    From the RH documentation / the source code:
    • for Datagram FLAGS:
      A bitmask of flags. The most significant 4 bits are reserved for use by RadioHead. The least significant 4 bits are reserved for applications.
    • for Router/Mesh FLAGS:
      Optional flags for use by subclasses or application layer
    Not setting up a conflict with the RH code will be the biggest issue: the two benefits of RH are the multi radio support and the more advanced Mesh topology - which would be worth a couple of additional bytes in flash and ram - but the other reason for the big overhead is that several advanced features of the nRF24 chip are not used because they are not available in all supported chips.
    Two examples:
    • the multi-pipe capability of nRF24 would allow to filter traffic to only current address and broadcast and avoid that any other traffic ever reaches the MCU (only slightly less code but wondering if that helps with battery powered nodes).
    • the ReliableDiagram processing in code essentially duplicates capabilities that are build into the chipset as well (auto-acknowledge / autoresubmit)
    I know you are interested in getting RF69 supported but the question is how much negative impact for all the other users (with current nRF24 setup) is acceptable. That's like using the RF69 and implementing an AES encryption in code rather than using the build-in capabilities of the chip...
  • Code Contributor
    Didn't want to sound too negative yesterday...
    • I'm still looking at the RH library but changes will be major and will not necessarily be in line with the RH purpose so Mike might not want to merge them into the main codebase: mainly defining what driver is used at compile time of the library (similar to MyConfig) which would then allow to e.g. "bypass" the majority of ReliableDatagram etc.
    • what we should definitely do is splitting application layer and network layer: no longer inherit MySensor from RF24 but create an RF24 instance at runtime / leave application layer message handling in MySensors / move network layer message handling to a separate class (the "driver" for RF24). This will make it way easier to switch radios in the future.
    Is it not sufficient that we define the radio at compile time in the sensors and the gateway as we have done now?
  • Code Contributor
    I'm talking about changing how the library is compiled and essentially having a separate ReliableDiagram class that bypasses manual handling of ACKs etc. and instead leaves reliable delivery to the radio itself. Mesh and Router are derived from the ReliableDatagram class - therefore we would need to define which radio to use prior to library compilation - not just prior to sketch compilation.
    Could someone summarize the differences between the current MySensors mesh and the RadioHead mesh, and why the latter is preferable for us?
    @Zeph
    RH is a true mesh where every node can communicate with any other directly (if in range). All nodes acts as repeaters.
    MySensors forms nodes forms a star network where every node has a parent and potentially a few child sensors. The gateway node is the "center". Every node always tries to find the closest (least number of hops) route to gateway.
             GW
            A   D
          B   C
    If B want to communicate with C messages has to pass A in the MySensors case. In RH C and B will communicate directly if the can hear each other.
    RH does not use the nifty features NRF24L01 offers which offloads mcu (pipes/addresses) nor auto ack (impossible in RH setup). So nodes in range has to process every message it can "hear". And this can potentially be a lot.
    @hek
    Thanks, that was very helpful, and a good explanation.
    That helps explain the overhead in the RH library mesh. It sounds cool for some purposes, but it also sounds like possible overkill for the wireless sensor network. Allowing B and C to communicate directly is not a primary use case. The MySensors is purpose-built for the sensor network with central gateway use case, and is pretty lean thereby. As I see it, even allowing B to send to C via A is not a primary use case, but sort of falls out "for free" given the routing approach that allows repeating nodes.
    Aside - can B send a message to itself via A?
    In my case, I'm mainly focusing on multi-sensor nodes, so RAM or Flash could be in short supply with a larger radio library. Worse still, I want to be able to incorporate MySensors functionality into nodes which also have non MySensors functions (eg: xmas light control also usng nRF24L01+), so space is even more at a premium.
    So while the RH option is interesting, and a lighter weight RH derivative may pan out, I hope the MySensor WSN radio layer will continue to provide a "lean and mean" alternative into the future.
    So MySensors can use both individual node addresses as well a broadcast, while RH uses only broadcast (at the radio level)? I understand why RH needs to do this, and I wonder if the receive FIFO ever overruns with unneeded packets.
    I wonder if MySensors gets much savings from using the auto-ack of ESB. If you already have network ack code anyway, how much code & ram is saved by sometimes using ESB (one hop away) and sometimes not? (I do get that a star network with no repeater nodes could use only ESB autoack and save some code).
    Yes.
    I think end-to-end ack is very important. The inter-node ack is only used as a trigger re-routing today (if communication fails 3 times to parent node .. the node tries to find another parent).
    Could someone please explain to me how the direct messaging of the NRF24 works? In my mind every radio network is a broadcast network on the physical layer, and it is up to the receiving radio to determine whether the packet is relevant or not. How is this different from your radios? Is it perhaps that your radios have a hardware address so that the filtering is done on the hardware level, while Radiohead uses a software address, so each packet has to be explicitly processed? I have no idea, I'm just guessing here...
    @kolaf
    Yes,
    NRF chip offer 6 reading "pipes". In practice it acts as a hw filter for addresses between 0-255.
    I use this to have one broadcast address (255) which all repeating nodes and gateway listens to and each sensor also listen to its own address.
    Looking at the documentation for the RF69 (page 41) it talks about sync word recognition. This is a programmable word that apparently can be used as the node's hardware address, similarly to the NRF24. Perhaps it is possible to expand the Radiohead drivers to utilise this functionality where it is available for filtering incoming packets?
    As for the dynamic mesh, this is a feature I find especially useful for one of my dream applications. We have horses, and it would be really fun to place a radio module with a accelerometer, and maybe GPS receiver, on each horse to track their movements. This could also be combined with a breakable wire in the harness which would let us know if the radio had been ripped off of the horse. Having a dynamic mesh will greatly increase the range of flexibility of such a monitoring network. I know that this is somewhat outside of the normal use case, but how fun wouldn't it be to build this? :-).
    Personally I'm also a bit interested in direct sensor to sensor configurations to allow for tightly coupled control systems without the need for a central controller in the loop (all the time). I know, we have resource limits so that I can probably not have everything, but one can dream...
    Nevermind the sink word recognition, this appears to function as some kind of network ID has to be the same for both the sender and receiver. However, there is also an optional address byte which is considered by the radio before the packet enters the FIFO queue. Page 55 of http://www.hoperf.com/upload/rfchip/RF69-V1.2.pdf
    The trouble is you have to distinguish between broadcasts and direct messages, so you need to listen at 2 addresses at a time, so to say.
    Yep, both pros and cons. 🙂
    A nice feature you can do with MySensors is to set a static parent (when calling gw.begin()). This could be useful for a presence sensor e.g. mounted on a car set statically to contact a repeater node mounted near the garage. The car sensor won't try to find or contact any other node than the garage one.
    Just brainstorming, but what if we consider adding the concept of a roving node to the MySensors network, without the overhead of a full mesh? Your use case doesn't require that all nodes be meshed with each other, just that a class of leaf nodes be able to move around.
    If I understand, a gateway or repeater node will forward a packet from anybody, if it recognizes the destination (as a node id in its routing table). Suppose you had coverage of your corral (or whatever) via gateway and various repeaters. In theory (perhaps naive theory) the roving node could report to the gateway by broadcasting a message picked up by whatever repeater is nearest; being addressed to node 0, the repeater knows what to do with it.
    There would be no network ack and no way for the gateway to send to the roving node as described so far. That is, unless this special "rover packet" caused each relay to rewrite that entry of its routing table as it was passed to the gateway, to enable an updated path back to the roving node. If your horses run around among many nodes often, EEPROM wear could be a concern, unless there was a small "routing override table" in RAM to handle roving nodes.
    One part I'm not clear about is how to avoid two or more nearby repeaters both forwarding this broadcast packet from the roving node. That might be tricky if it often causes OTA collisions. It could also complicate the back route logic, IF that was implemented. If we could avoid or gracefully recover from collisions, the gateway and controller may be able to deal with multiple copies of the same packet (not unlike the MQTT level 1 "deliver at least once").
    And - it might be technically infeasible to enhance MySensors networking to support roving nodes. But in that case I'm sure I'll learn something from the manner in which it's shot down 🙂
    There is a separate optional broadcast address byte. I'm not sure how this is used, but I'm guessing that the radio checks against both addresses before deciding what to do with the message. That should solve the broadcast problem.
    @Zeph @kolaf
    The rovering node will be able to send its message (after a few failed attempts) in the current solution.
    If even faster parent-search is required you can change the #define SEARCH_FAILURES in MySensor.h.
    @hek Just to be clear, I'm not dependent on the mesh functionality. I think I could be very happy with the current MySensors functionality with the added part of supporting my radio 🙂
    That's good!
    Aha, I see that on page 57 now.
    I think that would handle it! (I see no need for 6 address-filtered pipes, two addresses will do).
    Yes, it would be nice if the RH library could take advantage of address filtering for those radios which support it. I'm not so sure auto-ack is important tho.
    So, anyone still developing on RadioHead integration, or did all of you just give up? 😉
    I spend some time on writing Wireshark dissectors for RadioHead and integration of MySensors, to be used with the sniffer (http://forum.mysensors.org/topic/242/wireless-nrf24l01-sniffer-for-mysensors)
    Code is almost final (still have to test dessection of routing tables).
    Just as a preview, here's a screenshot to hopefully get you enthusiastic again!
    upload-2e15da80-1b44-4113-a6ac-e0077160d77b
    @Yveaux
    Looks good @Yveaux!
    I'm still a bit in doubt how sleeping nodes fit in when using RadioHead.
    It has no notion of sleeping nodes and just expects all nodes to be available anytime.
    When a route is e.g. discovered which uses a node that is about to go to sleep, routing will fail, but probably the route will then be rediscovered and finally settle using a node that is continuously powered.
    How long this will take and the likelyhood of such scenarios (depends ofcourse on the amount of nodes and how often/when they are awake) is still unclear to me.
    Hopefully I can analyze some real-world behavior using the sniffer.
  • Code Contributor
    no progress on my end - but that's rather related to the fact that this was my first week back in the office after vacation...
    I think we should do one thing first: decouple the "network layer" from the "application layer" in MySensors:
    • not having MySensors derived from RF24
    • have a "generic" interface between MySensors and the radio
    That way it would be rather easy to make use of other radios and other network topologies - could be RH or something else. I've taken a shot at that (a lot of this based on what Kolaf and Yveaux did adjusting MySensors to RH) and will provide a link once it compiles and is tested and I hope I can keep the overhead small enough to be acceptable for the gained flexibility.
    It is great to see that something is still happening. I wonder if I can build a packet sniffer for the RF69 radios? I guess it shouldn't be that difficult since they receive everything that is sent...
    The reason for my lack of progress late the has several reasons.
    1. I have a version of the library networks for my simplifications. This means that I can start building small sensors instead of spending all my time on the library 🙂
    2. My kids think I spent way too much time on this project already 😞
    3. I'm waiting for some kind of consensus to emerge.
    My hope has been to get this new radio library thing to a point where the community would adopt it so that I would not have to do any specific maintenance to keep my copy up to date with the official version. Based on this very long discussion thread there seems to be interest among you guys to achieve this, so I hope we will be able to get there at some point. However, we need to agree on how it is to be done, how much of the Radiohead library we want to use (or maybe even use a different library?). This obviously depends mostly on resource constraints considerations, and I'm not the best to judge this since I have not used MySensors extensively.
    It is great to see effort being spent on trying to reduce the footprint, and as an experiment it makes sense to do this. Once we have seen how small it is possible to make it, then we can perhaps agree on what features we want (everything, or just the device interface, maybe with RHDatagram manager class (without acknowledgements)).
    I'm holding back on developing any more this until we have reached some kind of consensus since I do not really have time to play around too much without being a relatively sure that the results will be useful.
  • Code Contributor
    Initial version - tested with a simple DallasTemperatureSensor setup successfully here
    Note that this fork/branch does not include the "1.4 update 1" changes for nodeID / CRLF.
    Overhead is limited (~150b flash / ~20b ram):
    Sketch uses 20,426 bytes (66%) of program storage space. Maximum is 30,720 bytes.
    Global variables use 575 bytes (28%) of dynamic memory, leaving 1,473 bytes for local variables. Maximum is 2,048 bytes.
    Care to share any details on which parts you took from where? Is it basically the Radiohead drivers with the MySensors network layer? Or did you make more effort on trying to split everything up to a larger extent
  • Code Contributor
    @kolaf it's only splitting the MySensor application layer form the underlying network layer. Still using the MySensor tree network topology and the RF24 driver. It's adding the framework to allow others to easily integrate other topologies (e.g. mesh) and other radio modules (e.g. RF69). The interface expects a reliable submission - no matter if that's achieved by software (like radiohead) or hardware (nRF24).
    The MyDriver header file includes a short description of the routines and it should be fairly easy to attach it to radiohead. The main benefit is that the original MySensor tree setup still works as before if wished.
    Looks good @ToSa!
    @ToSa Could you give me the link to your repository?
  • Code Contributor
    @ToSa Got it. My apologies for being slow, it was getting late ;).
    Itlooks like this should be quite easy to work with. For the RF69 driver, maybe I could even use the unreliable datagram service from Radiohead And Configure the Driver to Use Hardware Acknowledgements (I Believe They Exist).
    I will make an effort in this direction during the next few days, I hope. I'm curious to see how much space this requires compared to the NRF24 solution
    @ToSa I was trying to fork your repository in order to build the driver for the RF69 based on Radiohead. It does not seem to work, maybe because I already have a fork of the main mysensors repository?
    Maybe I can just check out your code, add the necessary files and be allowed to push it back to you?
  • Code Contributor
    yes - Git doesn't allow two forks with the same base name (Arduino) for one user. We are about to move the changes into the mysensors/development branch. That way you can pick it up from there...
    @ToSa Great, I will add my changes when you have done this.
    It has been implemented, but I won't bother testing it until your changes have been merged with development, I don't want to mess up my existing development environment. My biggest uncertainty is whether this set up will allow the Radiohead library to be installed as a regular library in the "libraries" folder or if it has to be put directly into the MySensors folder.
    Is there any progress of merging into the development branch? I'm currently holding off of building anything definitive for in-house deployment until we have settled on a relatively stable base for the code.
    On a side note, I'm currently deploying Z wave actuators for all the lights in my house (we're refurbishing the entire electric system, anyway), and I must say that I am not very happy with the closed nature of the Z wave network management. I have gotten to the point where I believe that if I were to replace all the Z wave components with MySensors components I would get a much more stable system. Unfortunately I will get in trouble with the authorities if I try this 😞
  • @hek It looks to me that all the activity that happen on getting the RFM69 integrated as part of the Mysensor ecosystem is dying. Can we not see if we can talk to Felix from Lowpower (https://lowpowerlab.com/) to see if he is not willing to get his Moteino integters as part of the MySensor ecosystem. Here is the tread on his forum where I asked him about this. https://lowpowerlab.com/forum/index.php/topic,542.0.html
    The integration has not stopped. It is just a bit slow as we all have lots on our plate 😉
    Felix has actually sent me a couple of Moteinos that arrived a few days ago.
    But the first step is to separate radio code from the rest of the library. @ToSa has begun this work and is nearly finished. Guess he is swamped with work as I haven't heard from him the last couple of weeks.
    https://github.com/mysensors/Arduino/pull/36
    Then we can create a new driver for the RFM69.
    I am waiting for the new radio separation code to be merged into the development branch. I have a working implementation (I think) of the RadioHead RFM69 library using his new code. I don't mind the wait, though, because I have lots of other things to do in the meantime and I can still build sensors using my own version of the library 🙂
    Super @kolaf! Can't seem to get in contact with @ToSa. Maybe time to take it in (even if the config thing is unresolved) to get some progress.
    @kolaf
    The driver refactoring has now been merged into development. Ready for RFM69! 😄
    Working on it, fighting git about a rolled back rebase...
    I managed to resolve my git problem, but I'm now back to a problem we have discussed before.
    The problem is with how I should include the driver in order to use it without having to modify the header of every driver file. Can't seem to find what we landed on last time...
    You mean every sketch file?
    Guess you'll have to do like we did with rf24 and add it to the utility folder. Or maybe I misunderstand the question.
    I mean that I have to place the RadioHead library inside the main my sensors folder for everything to work. If I were to place it in the "utility" folder, I would have to change every include inside the library to use" instead of brackets.
    Anyway, I have gotten it to compile, and there is some radio communication going on. Trouble is that there seems to be some issues with the buffer sizes (I guess?).
    Here was what the sensor is sending:
    find parent
    send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,st=bc:
    And this is what the Gateway is receiving (with an additional debug message from me):
    0;0;3;0;9;read: 0-0-0 s=255,c=3,t=6,pt=1,l=1:0
    0;0;3;0;9;version: 0
    0;0;3;0;9;version mismatch
    Obviously something is getting mangled along the way...
    Good that something is transmitted.
    But should you really use RadioHead? That seems a bit redundant.
    Felix over at LowPowerLab directed me to: https://github.com/LowPowerLab/RFM69/
    I got something working with a new library. Requesting node ID, and sending all initialisation stuff seems to work correctly. I was not able to place the libraries in the correct place this time either, but perhaps you can move them and re-factor the code?
    I created a pulled request so that you can look at it.
    This is happening in the gateway with the new code:
    0;0;3;0;9;read: 1-1-255 s=255,c=3,t=7,pt=0,l=0:
    0;0;3;0;9;send: 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,st=ok:0
    0;0;3;0;9;read: 0-1-1 s=255,c=3,t=8,pt=1,l=1:0
    0;0;3;0;9;send: 0-0-0-1 s=255,c=3,t=8,pt=1,l=1,st=fail:0
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1:0
    1;255;3;0;6;0
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=13:Wave switch 3
    1;255;3;0;11;Wave switch 3
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3:1.1
    1;255;3;0;12;1.1
    0;0;3;0;9;read: 1-1-0 s=1,c=0,t=3,pt=0,l=3:1.4
    1;1;0;0;3;1.4
    0;0;3;0;9;read: 1-1-0 s=3,c=0,t=6,pt=0,l=3:1.4
    1;3;0;0;6;1.4
    0;0;3;0;9;read: 1-1-0 s=2,c=2,t=2,pt=0,l=3:1.4
    1;2;2;0;2;1.4
    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=2,pt=2,l=2:0
    1;1;1;0;2;0
    0;0;3;0;9;read: 1-1-0 s=3,c=1,t=0,pt=7,l=5:23.2
    1;3;1;0;0;23.2
    0;0;3;0;9;read: 1-1-0 s=3,c=1,t=0,pt=7,l=5:23.3
    1;3;1;0;0;23.3
    Great @kolaf. I'll take a look.
    Ok merged! Seems to compile fine with the library in utility after some minimal changes. Thanks @kolaf.
    Excellent. I took a quick look at the changes you did to move the library, I'm a bit ashamed that I didn't manage to do that myself...
    I'm very happy to have a solution in the development branch that allows the radios I bought to be brought along into the future of MySensors 🙂
