Newbie needs help
    I just started on mysensors and I have zero knowledge in electronics.
    I want to create some sensor nodes using arduino pro mini.
    However i have few doubts. Hope someone can help a newbie.
    1. I can see only one VCC pin (excluding the one on programming header which i would like keep it for uploading sketches in future). How do I connect my radio and sensor? Shouldn't it be at least 2 VCC pins? Or can I fit in 2 wires into the same VCC pin?
    2. I'm powering the sensor node with 2 AA batteries. The negative terminal goes to ground. What about the positive terminal? Does is goes to RAW?
    I'm sorry for the silly questions.
    Welcome @masterkenobi !
    1: You can connect as many things as you like to the vcc pin. A breakout board is very handy when prototyping to make it easy to connect many things to the same pin.
    2: it depends. Search for 2xAA in the forum and you'll find lots of discussions. But to get started connect + on the batteries to Vcc.
  • @mfalkvidd thanks.
    I manage to build a couple of sensors powered by 2 AA batteries.
    However I'm stuck at monitoring the battery level.
    After I uploaded BatteryPoweredSensor.ino to my board, it overwrote the sensor sketch I uploaded earlier.
    Do I have to merge both sketches into one before upload?
    Yes each time you upload a sketch it replaces the one that is already there.
  • Here you have a sample of one of my battery nodes. Now I'm using V2.0 of Library, but this used to work before updating
    #include <BH1750.h>
    #define SN "SensorLuz"
    #define SV "1.0"
    unsigned long SLEEP_TIME = 300000; // 5 minutos
    #define CHILD_ID_LIGHT 0
    #define NODE_ID 7
    int BATTERY_SENSE_PIN = A0;
    BH1750 lightSensor;
    uint16_t lastlux;
    MyMessage msgLux(CHILD_ID_LIGHT, V_LEVEL);
    MyMessage msgLuxUnit(CHILD_ID_LIGHT, V_UNIT_PREFIX);
       analogReference(INTERNAL);
      gw.begin(NULL, NODE_ID);
      lightSensor.begin();
      gw.sendSketchInfo(SN, SV);
      gw.send(msgLuxUnit.set("lux"));
      uint16_t lux = lightSensor.readLightLevel();
      Serial.print("Lux: ");
      Serial.println(lux);
      if (lux != lastlux) {
          gw.send(msgLux.set(lux));
          lastlux = lux;
      batM();
      gw.sleep(SLEEP_TIME);
       delay(500);
       delay(500);
       //Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       if (batLoop > 24) {  //24 ciclos de 5 min = 2h.
         batLoop = 0;
       batLoop++;
    There is also another thing concern me. What if my neighbor also into Mysensors? Will he be able to view all the data from my sensors? How do I secure the nodes?
    Take a look at https://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors
  • 87
  • 7
20
