I'm wondering what the minimum input voltage is. The description only says max. 6.5V input voltage from the battery, but does not say what the minimum is. Both the nrf24l01+ as well as the atmega328P work with 3.3V, so if I use three AA batteries, that should be fine, right? I suppose using two AA batteries is not enough?
@mr_red
I have a zipped snapshot of all the 3d step/wrl models that I used to build my projects so far. It was quite some work to gather them all and align with the footprints using the kicad stepup tools. It's not complete - still needs some more work:simple_smile: but it should help you or anyone else to get started into MCAD integration using FreeCAD and kicad stepup tools. Maybe it's not very easy to start when using free tools but hey they are "FREE" so we cannot ask for more. But the nice thing is that once you get used it will be really easy to do your stuff and to go forward. Oh and FreeCAD can be so powerful after you learn it - I was really amazed what you can do with it(it has it's quirks and downsides but once you master it - oh, well...).
There's also: https://www.onshape.com/ - pretty powerful this one too and it has more advanced features than FreeCAD but the downside is that it's a cloud based solution: it's free for public documents but you never know when they will go to paid accounts only so yeah...I don't really like the idea to depend on something that it's hosted and the application is not on my PC along with the documents that I create with it. Cloud solutions have their flexibility but you're locked and you depend entirely on that hosted service.
Ok, enough talking...I uploaded the zip file here: http://www.mediafire.com/file/kzh1l9uo40cpj1u/kicad_stepup_packages.zip
Do you have interest to try OH2 together with MySensors Ethernet Gateway to get working?
I do not have enough force to push developers to make this happen. At the moment there is some problem on this, because full control is not possible. I think that MySensors Serial Gateway is working with OH2, but I don't like to use it. I like to connect my devices into LAN not cabling via old fashioned way using serial wires.
I think you need to post a clear drawing or photos of the setup and the code you are using.
I donlt know what you mean by "connecting the current in series" nor what "AC regulator" you are using or what "thermal serial currenr" is.
@krisztian
Hi krisztian,
the singleLED board - as its name suggests - features only one LED output. If you want to have a setup with multiple LED strips you need to design a board with multiple outputs. I have already designed a board with 4 outputs, but I haven't built it.
In terms of software you need to register multiple sensors in your program like this:
#define numCh 4 //the number of outputs
const byte ledPins[] = {9,6,5,3};
byte ledLevel[numCh];
boolean ledDimWay[numCh];
//in the setup function request the dim levels from the gateway
for(byte i=0; i<numCh; i++) request(i, V_DIMMER);
//in the presentation function register multiple lights
for(byte i=0; i<numCh; i++) present(i, S_DIMMER);
//if you receive a signal, you need to check for the sensor id
setLED(message.sensor, requestedLevel);
//to set the LED level (function: setLED) you need to use the sensor id to determine brightness and pin
//Fade LED to set level
int delta = (level - ledLevel[child]) < 0 ? -1 : 1;
//Write to LED
analogWrite(ledPins[child], map(ledLevel[child],0,100,0,255));
I will probably publish the whole code once I have built and tested the 4LED controller (i call it "MySensors rainbowLED")
Hope I could help you
ThetaDev
