Reporting Battery Level
  • How to add to sketch this feature? I use Domoticz controller and serial gateway. Nodes is Arduino mini pro 3,3V with batteries. Today i use door open/close sensor, elecricity meter, moisture sensor.
  • I don't have my sketch available, but I used this code below for measuring 2xAA. I have changed #define MIN_V 1900 (milliVolt) since I have disabled BOD, so Arduino runs to 1,8V, bur NRF24L01+ is working down t0 1,9V
    NOTE: This is only showing battery measuring, it's not a full sketch...
      #define MIN_V 2700
      #define MAX_V 3200
      int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100); // Convert voltage to percentage
      gw.sendBatteryLevel(batteryPcnt); // Send battery percentage to gateway
      long readVcc() {
  • Okay. I understand but how to add this piece from software to each sketch? Each what arduino powerted from batteryes.
    @Fat-Fly Easiest way is to use the Vcc library by @Yveaux
  • This is better. I need cut off Arduino voltage regulator and power led ?
    @Fat-Fly To save power you can... but not needed for the Vcc library to work if you power your pro-mini from the vcc pin 😉
  • Ok. I try to write sketch.
  •  * The MySensors Arduino library handles the wireless radio link and protocol
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #include <Vcc.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    //battery voltage
    const float VccExpected   = 3.0;
    const float VccCorrection = 2.860/2.92;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    static int oldBatteryPcnt = 0;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         oldValue = value;
        int batteryPcnt = (int)vcc.Read_Perc(VccExpected);
        if (oldBatteryPcnt != batteryPcnt)
            oldBatteryPcnt = batteryPcnt;
  • Verification successful says codebender. I do not know working this or not. I can't try. Only in home after working day.
  • https://codebender.cc/sketch:337094 This is modified electricity meter sketch with battery level .
  • @Fat-Fly Nice, interested to try this also.
    Any idea how long the batteries will last? Electricity meters tend to blink quite often, so not that much sleep..
  • At the moment i try this with 2xAA recargeable batteryes but no luck. Gnd and vcc pin. Not working , not reported. if i find batterys.... I search. All remotes is AAA 😞 2.68volts from recargeable AA's. where is the fish ?
  • From recargeable 2x AA and 2,68V not working.
  • I bought 2AA batteries. Working.Domoticz devices page report battery level 3. How to see battery level graph ?
    @Fat-Fly to report battery voltage you have to create a S_MULTIMETER sensor and send the voltage with V_VOLTAGE.
    Sendbatterylevel only changes the battery level in Domoticz in % and can not be shown separate.
    Tot use your arduino with low voltages you need to change the fuse settings (BOD) with an ISP programmer.
  • How to i do this ?
    @Fat-Fly I will post some code later when I get to a pc. 👀
    This is great. I do not find from google search. My mother tongue is Estonian 🙂
    @Fat-Fly "Estonia: Between East, West and the World" 😉
    These are the lines of code which should do the trick... you need to put them in the right spot yourself
    #define VOLTAGE_CHILD_ID 		5
    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);	// Node voltage
    gw.present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery " );
    float voltage = vcc.Read_Volts() ;
    gw.send(voltageMsg.set(voltage,2));				//send battery in Volt
  • Estonia between world and russia. 🙂
  • @Fat-Fly I am not sure how you intend to arrange your electricity pulse meter reading, but in my case I had to wire Pro Mini 5V to mains or otherwise recharge a battery every 5-7 days. I think you can do the total kWh and putting Pro Mini to sleep, but you cannot have total consumption kWh and current consumption kW with sleeping.
  • Yesterday this not working. KW reader is too away from gateway.My house is lenght is 22m. Electricity meter is one end of house and gateway is center house. can i use repeater on something other. I use for this nrf with antenna.
    @Fat-Fly check the "range issues" troubleshooting flowchart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
  • 14
  • 933
  • 274
