[Solved]UPL:Fail
  • I have my mqtt client gateway up and running and I have a test node setup.
    The debug for the node is
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=1)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    Not sure what is causing it. If i reset it a few times it eventually connects. I have tried clearing the eeprom and reuploaded the sketch.
    @Jason-Brunk Please provide additional information such as HW setup and configuration, and also post the complete log from node and GW while booting.
  • Looks like it may have been related to my gateway and sensor being too close.
    @Jason-Brunk Yes, this is a common issue.
  • Hello!
    I'm having the same issue. How to solve it?
    I've converted a working sensor having API 1.5 with last API and getting this errors:
    Setting S_LIGHT sensor: 1
    Setting S_LIGHT sensor: 2
    Setting S_LIGHT sensor: 3
    Setting S_LIGHT sensor: 4
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=20)
    TSM:FPAR
    TSP:MSG:SEND 20-20-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-20 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=20)
    TSM:UPL
    TSP:MSG:SEND 20-20-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 28-28-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    TSP:MSG:BC
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    TSP:MSG:BC
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    TSP:MSG:BC
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    TSP:MSG:BC
    !TSM:UPL:FAIL```
    It has worked without issues until the last update.
    @xefil Did you also convert the GW to 2.0? If yes, please post the debug log.
  • I have the same problem as do to solve it?
    Starting repeater (RNNRA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=123)
    TSM:FPAR
    TSP:MSG:SEND 123-123-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:READ 0-0-123 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=123)
    TSM:UPL
    !TSP:MSG:SEND 123-123-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
  • I was quite sure the gateway (MQTTClient) was updated with latest API library, but I was wrong. It was on 1.5 version. Updated to the latest, the problem was solved. Hope it helps!
    Simon
  • @xefil with my errors. I changed the capacitor value to 100u and that fixed ALOT of problems. Some one mentioned to me that 2.0 uses the radio a little more and may need a higher value cap.
    @Pictor-Lallemand Please make sure your GW is at 2.0.
    @xefil Perfect, have fun! 🙂
  • @Jason-Brunk I already had a 100u capacitor, thanks for the suggestion.... btw strange, maybe the update was important.
    @tekka , thank you!! 😉
  • or find the code for my GW I use an Arduino pro mini card for a ENC28J60 network and nRF24L01 for radio. because I can not find it in the examples mysensors
  • You mean you cannot find the examples from the API library? When you download it, you can find it in there. On github as well:
    https://github.com/mysensors/MySensors/tree/master/examples
    In case try to start uploading two examples (1 GW and 1 sensor) and check. They work without issues. If not, maybe a hardware failure.
    Simon
  • in the examples of the API (MySensors 2.0.0) I can not find ENC28J60 Gateway
    send me please you the code in this gateway thank you
  • it didnt change anything here is the log for sensors
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    the sketch use
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before() {
        pinMode(pin, OUTPUT);
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    and that of the gateway
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.15
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;TSP:SANCHK:OK
    the sketch use
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_GATEWAY_ENC28J60
    // Gateway IP address
    #define MY_IP_ADDRESS 192,168,1,15
    #define MY_PORT 5003
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #include <UIPEthernet.h>
      i add a capacitor 220U
  • the gateway log
    IP: 192.168.1.15
    0;255;3;0;9;TSP:MSG:READ 123-123-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=123)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-123-123 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
  • Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
    Simon
  • the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
    @Pictor-Lallemand
    Lets start with a simple setup:
    • all radio caps >= 22uF (ideal 100uF)
    • latest MySensors lib (i.e. 2.0.0)
    Gateway - Program GatewaySerial from the MySensors examples
    Node - Program this simple sketch:
    #define MY_NODE_ID 100
    MyMessage msgGeneral(0, V_VAR1);
    uint32_t counter = 0, lastSend = 0;
    uint8_t rebootCounter = 5;
      sendSketchInfo("TestNode", "1.0");
      present(0, S_ARDUINO_NODE, "Counter");
       if (millis() - lastSend > 500) {
          msgGeneral.setDestination(GATEWAY_ADDRESS);
          send(msgGeneral.set(counter), true);
          counter = 0;
          lastSend = millis();
          if(!rebootCounter--) {
            hwReboot();
       counter++;
    ...and post the debug log from both, GW and node.
  • same problem here:
    minimal example worked and I figured out that assignment of an ID helps 🙂
    Maybe I missed this point that I have to and that auto assignment doesn't work the way I thought.
    @hensing said:
    same problem here:
    Ok, so not related to UPL:Fail (as the title of this topic suggests)?
  • i add 22uF capacitor to node and GW
    debug gw
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
    0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
    debug node
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=100)
    TSM:FPAR
    TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=100)
    TSM:UPL
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    I'm really frustrated that it does not work correctly yet I applied literally your sugestions
    @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
  • i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
    the node is powered by my laptop for use serial debug
    debug node
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    gw debug
    0;255;0;0;18;2.0.0
    Thank you for your support
    @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
  • @tekka in parallel
    @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
  • @tekka I just try not conclusive
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    an idea ?
    @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
  • @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
    @Pictor-Lallemand What HW are you using & frequency?
  • @tekka What is the HW?
    @Pictor-Lallemand
    HW= hardware 😉 FW for firmware or SW software
    that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
  • @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
  • @tekka
    I weld son tips on antenna here debug
    node
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
    TSP:MSG:BC
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSP:MSG:BC
    TSP:MSG:BC
    !TSP:FPAR:ACTIVE (msg not send)
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:BC
    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:BC
    TSP:MSG:BC
    TSM:UPL
    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:PONG RECV (hops=1)
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
    TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
    TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
    TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=fail:TestNode
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
    !TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=17,pt=0,l=7,sg=0,ft=2,st=fail:Counter
    Request registration...
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
    !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    !TSP:SEND:TNR
    TSM:FPAR
    Init complete, id=100, parent=255, distance=255, registration=1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    gateway debug from MYSController
    8	13/08/2016 18:33:12	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
    10	13/08/2016 18:33:20	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    11	13/08/2016 18:33:22	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    12	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
    14	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
    17	13/08/2016 18:33:27	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
    18	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
    20	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
    23	13/08/2016 18:33:28	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
    24	13/08/2016 18:33:46	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    25	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
    27	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
    30	13/08/2016 18:34:01	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
    31	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
    33	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
    36	13/08/2016 18:34:02	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
    37	13/08/2016 18:34:08	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    38	13/08/2016 18:34:08	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
    40	13/08/2016 18:34:08	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
    43	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
    44	13/08/2016 18:34:09	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
    46	13/08/2016 18:34:09	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
    49	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
    50	13/08/2016 18:34:09	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    51	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    52	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    53	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    54	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    55	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    56	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    57	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    58	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    59	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    60	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    62	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    63	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    64	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    65	13/08/2016 18:34:14	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
    67	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
    69	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
    71	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	NA (24)	BYTE	1	NO		1
    72	13/08/2016 18:34:16	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			hops=1)
    73	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	NA (25)	BYTE	1	NO	ok	1
    74	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO		0100
    75	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO	ok	0100
    76	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_PRESENTATION	S_ARDUINO_NODE	STRING	5	NO		2.0.0
    78	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_CONFIG	BYTE	1	NO		0
    81	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_CONFIG	STRING	1	NO	ok	M
    84	13/08/2016 18:36:27	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
    @Pictor-Lallemand Looks to me like a power issue, not an antenna issue.
    Half of the messages are OK, and then all of a sudden they all fail:
    TSM:UPL
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    At what frequency are you running your minis? Out of curiosity, can you post a pic of your node+radio (ideally with a pic of the cap) and GW+radio - this may give additional info.
  • @tekka
    my node
    my gateway
    @Pictor-Lallemand ok, now upload this sketch to both nodes and post the debug output:
    #define MY_CORE_ONLY
    void setup(){
      MY_SERIALDEVICE.begin(115200);
      MY_SERIALDEVICE.println(F("**********"));
      MY_SERIALDEVICE.println(__FILE__);
      MY_SERIALDEVICE.println(MYSENSORS_LIBRARY_VERSION);
      MY_SERIALDEVICE.println(hwFreeMem());
      MY_SERIALDEVICE.println(hwCPUVoltage());
      MY_SERIALDEVICE.println(hwCPUFrequency());
      MY_SERIALDEVICE.println(F_CPU);
    void loop(){}
  • @tekka my debug output
    C:\Users\victor\Documents\Arduino\sketch_aug14c\sketch_aug14c.ino
    2.0.0
    1703
    5001
    164
    16000000
    @Pictor-Lallemand and from your GW?
  • @tekka
    debug gw
    C:\Users\victor\Documents\Arduino\sketch_aug14b\sketch_aug14b.ino
    2.0.0
    1703
    4728
    175
    16000000
    @Pictor-Lallemand Ok output looks good, GW is running at a slightly higher frequency - but this can also be an artefact. I assume your radios run at 3V3?
    Let's try these things:
    1. increase the RF24 data rate to 1MBPS using
    #define MY_RF24_DATARATE RF24_1MBPS
    1. If (1) doesn't improve the radio transmissions, change the RF24 channel using
    #define MY_RF24_CHANNEL 37
  • @tekka I already used the command 1Mbit
  • after having followed your two board this is what I get the node code
    debug
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=101)
    TSM:FPAR
    TSP:MSG:SEND 101-101-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:BC
    TSP:MSG:READ 0-0-101 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=101)
    TSM:UPL
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=1,st=fail:0
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=2,st=fail:0
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=3,st=fail:0
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=4,st=fail:0
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=5,st=fail:0
    !TSM:UPL:FAIL
    TSM:FPAR
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:READ 0-0-255 s=255,c=3,t=255,pt=0,l=3,sg=0:255
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=fail:0
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSP:MSG:BC
    TSM:UPL
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=5,st=fail:1
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=6,st=fail:0
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=7,st=fail:0
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=8,st=fail:0
    TSP:MSG:READ 0-0-101 s=255,c=3,t=25,pt=1,l=1,sg=0:1
    TSP:MSG:BC
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=9,st=fail:0
    TSP:CHKUPL:OK
    TSM:UPL:OK
    TSM:READY
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=10,st=fail:0100
    !TSP:MSG:SEND 101-101-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=11,st=fail:2.0.0
    !TSP:MSG:SEND 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=12,st=fail:0
    !TSM:UPL FAIL, SNP
    TSM:FPAR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    TSM:FPAR
    !TSP:SEND:TNR
    TSM:FPAR
    !TSP:SEND:TNR
    TSM:FPAR
    !TSP:SEND:TNR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    Init complete, id=101, parent=255, distance=255, registration=1
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    !TSP:SEND:TNR
    the code of node
    #define MY_NODE_ID 101
          counter = 0;
            hwReboot();
       counter++;
    the gateway code
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    the debug gateway
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 101-101-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=101)
    0;255;3;0;9;!TSP:MSG:SEND 0-0-101-101 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
  • @tekka
    yes my radio module operates on 3.3V ams1117 I use the regulator to reduce the voltage 3.3V
  • 24
