Ethernet gateway with W5100
    I recently decide to have some fun with Arduino and MySensors. I am not a programmer so I don know what exactly I'm doing.
    I bought on Ebay an Arduino Shield Compatible (not original, neither only for arduino uno r3) and to be sure an ethernet adapter too.
    The arduino shield have a Wiznet W5100 chip (which should be almost compatible with MySensors) and the etherent adapte have an ENC28J60 (which is supported but with some modificantions to the UIPE code).
    So, i put my shield on the arduino, in the w5100 gateway script enable the softspi and connected my nrf24... When I go to the serial console, it gave me DHCP Failture (once i got connected, on my router i reserved the ip for the arsuino specific mac address) and assigned a static ip of 192.168.1.35 (the one assigned by my router to the mac address). If I give the ip number in the console says that its connected successfully with that ip, but actually it isn't (if i go to my router it says that it isn't connected and the ip is free), even if i go to Domoticz it can't connect to the gateway, neither MyController (i hope it's spelled correctly).
    If i do the same for the ENC driver it works great, it even recognise my node (which is a RelayActuator on a nano) which when is connected through the w5100 doesn't show up in the Serial Console.
    I leave my codes Here so you can look and eventually tell me what is wrong:
    W5100 Code:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    // Enable to UDP
    #define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,35   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    #define MY_MAC_ADDRESS 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    //#define MY_DEFAULT_ERR_LED_PIN A0  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  A2  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  A1  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    ENC28J60 Code:
    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
    #define MY_GATEWAY_ENC28J60
    // Gateway IP address
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #include <UIPEthernet.h>
    Sorry for my bad english but it isn't my native language 😄
    @Edoardo-Macrì
    You may need to comment out this line. It is preventing soft spi from being enabled
  • @Boots33 said:
    @Edoardo-Macrì
    I've tried, moved SI SO SCK from the nrf to the respective analog pins but it won't worked, gave me the same problem
  • Uh. I forgot to mention that the shield with the Ethernet library works perfectly, so it's isn't broken...
    @Edoardo-Macrì
    The example W5100 sketch from the arduino IDE should work without any modifications other than to set the ip address you want to use in the line
    You have made a few changes to the original sketch
    on my W5100 gateway the line below remains commented out
    // #define MY_W5100_SPI_EN 4
    As does the line
    // Enable to UDP
    //#define MY_USE_UDP
    and if you are using a static address this line remains commented out as well
    Check your wiring it should be like below. Ignore the extra regulator if not using an amplified radio.
    Have you tried to ping the gateway ?
    maybe you could post the serial debug info as well, that might give a clue to the problem
    People had trouble with some versions of the Arduino IDE causing constant rebooting of the W5100 gateway. See this post
  • @Boots33
    Thanks, now it's working.. probably somethin in the DHCP string!
    This is the working code:
     * LED purposes:
    //#define MY_W5100_SPI_EN 4
      #define MY_SOFTSPI
    // Enable to UDP
    #define MY_DEFAULT_ERR_LED_PIN A3  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  A4  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  A5  // the PCB, on board LED
    @Edoardo-Macrì great work!
