DS18B20 Sketch from Examples doesn't brings Node to sleep.
  • Hi, the 1.1 Sketch doesn't brings the Node to sleep with 2.0.1-beta.
    Anyone else is having this problem?
    I have two nodes and both having this issue 😞
    What type of hardware?
  • Arduino Pro Mini with NRF24L01+...
    It Works great with the "old" 2.0.0 beta.
  • Any Ideas, why it is not working with new 2.0.1-beta?
    Could you post more infos plz ?
    • your sketch even if it's the original
    • which lib you're using for onewire
    • enable MY_DEBUG in sketch and post the logs
  • DEBUG:
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.0.1-beta
    4 MCO:BGN:BFR
    65 TSM:INIT
    73 TSM:INIT:TSP OK
    75 TSM:INIT:STATID=2
    77 TSF:SID:OK,ID=2
    79 TSM:FPAR
    114 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    227 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    233 TSF:MSG:FPAR OK,ID=0,D=1
    2123 TSM:FPAR:OK
    2123 TSM:ID
    2125 TSM:ID:OK
    2127 TSM:UPL
    2134 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2156 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2162 TSF:MSG:PONG RECV,HP=1
    2164 TSM:UPL:OK
    2166 TSM:READY
    2170 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2181 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.0.1-beta
    2191 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2197 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4208 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
    4225 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    4235 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4241 MCO:REG:REQ
    4245 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4263 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4270 MCO:PIM:NODE REG=1
    4274 MCO:BGN:STP
    4276 MCO:BGN:INIT OK,ID=2,PAR=0,DIS=1,REG=1
    4282 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
    4288 !MCO:SLP:REP
    5070 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.0
    5079 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    5085 !MCO:SLP:REP
    65089 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
    65095 !MCO:SLP:REP
    65875 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:18.7
    65884 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
    65890 !MCO:SLP:REP```
    SKETCH:
     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
     * http://www.mysensors.org/build/temp
    #define MY_NODE_ID 2
    #define MY_REPEATER_FEATURE Disabled
    #include <OneWire.h>
    #define MAX_ATTACHED_DS18B20 2
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
         present(i, S_TEMP);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
      sleep(SLEEP_TIME);
    ...and the Onewire Library from: Mysensors Libraries @GitHub
    @Floca Your node is defined as repeater, and repeaters do not sleep by definition:
    See log:
    65890 !MCO:SLP:REP
    To disable repeater mode, comment this line (writing "Disabled" won't work):
  • 7
  • 7
  • 11
  • 16
  • 48
