S_INFO NODE with OLED Display - Solved -
  • Hi, this is my code for writing Text to the oled display.
    Controller is ioBroker and so far everything is working, but... I like to place multiple lines to the display using V_VAR1 - V_VAR5. How to use them?
    And do i need a ACK Command?
    Thanks for you help, sorry this is my first "self made" node.
     * Version 1.1 - Thorsten Böttcher
     * Example sketch showing how to send messages to 0,96" OLED Display
     *       OLED                 ARDUINO
     *  -----1234-----
     *  |            |  1 ->    3,3 V
     *  |            |  2 ->    GND
     *  |            |  3 -> A5 SCL
     *  |            |  4 -> A4 SDA
     *  OLED ASCII Library from https://github.com/greiman/SSD1306Ascii
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define CHILD_ID 0
    //oled display
    #include "SSD1306Ascii.h"
    #include "SSD1306AsciiAvrI2c.h"
    #define I2C_ADDRESS 0x3C
    SSD1306AsciiAvrI2c oled;
    // SketchInfo
    static const char SketchName[]    ="Info Display";
    static const char SketchVersion[] ="1.1";
    int PosX     = 0;
    int PosY     = 0;
    int ClrScr   = 0;
    int FontSize = 1;
    // loop
    static const uint64_t UPDATE_INTERVAL = 60000;
    MyMessage msgText (CHILD_ID, V_TEXT); // Text
    MyMessage msgVar1 (CHILD_ID, V_VAR1); // Cursor PosX
    MyMessage msgVar2 (CHILD_ID, V_VAR2); // Cursor PosY
    MyMessage msgVar3 (CHILD_ID, V_VAR3); // Clear Screen
    MyMessage msgVar4 (CHILD_ID, V_VAR4); // FontSize
    MyMessage msgVar5 (CHILD_ID, V_VAR5); // Not Used
      Serial.println("starting...");
      ShowInfo();
    void presentation()  {
      sendSketchInfo(SketchName, SketchVersion);
      present(CHILD_ID, S_INFO);
    void receive(const MyMessage &mymessage)
     if (mymessage.type==V_TEXT) {
       DisplayMessage(mymessage.getString());
     if (mymessage.type==V_VAR1) {
       PosX = atoi(mymessage.getString());
     if (mymessage.type==V_VAR2) {
        PosY = atoi(mymessage.getString());
     if (mymessage.type==V_VAR3) {
        ClrScr=atoi(mymessage.getString());
        if ( ClrScr > 0 )
          oled.clear();
     if (mymessage.type==V_VAR4) {
        oled.set1X();
        FontSize=atoi(mymessage.getString());
        if ( FontSize > 1 )
          oled.set2X();
      // Wait, but receive messages
      wait(UPDATE_INTERVAL);
    void ShowInfo()
      oled.begin(&Adafruit128x64, I2C_ADDRESS);
      oled.setFont(Arial14);
      oled.set1X();
      oled.setCursor(20,1);
      oled.write("* MySensors 2.0 *");
      oled.setCursor(30,3);
      oled.write(SketchName);
      oled.write(" ");
      oled.write(SketchVersion);
      oled.setCursor(30,5);
      oled.write("NodeID");
      oled.write(" ");
      oled.print(getNodeId());
      sleep(3000);
      oled.clear();
    void DisplayMessage(const char Message[])
      oled.setCursor(PosX,PosY);
      oled.clearToEOL ();
      oled.write(Message);
    @awi got some examples in Domoticz: https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text I dont know how this works in ioBroker with v_var though.
  • Hi sundberg84, using 5 Nodes was my first idea. But i want to use V_VAR1...
    But you solved me problem indirecty. I installed MYSController and...the code (updated above) is correct.
    Looks like ioBroker is my problem.
    Thanks for your help Thorsten
  • Made small update .....X,Y Pos Fontsize...
  • 198
