Relay and Light Node
  • Hi, i try to combine Relay and Light node sketch. It works ok but i need put interupt or delay for light sensor reading only 1 read per minute. If i put sleep time to loop then it block comunication for realy and node repeater 😞
    I found some examples only for 1.5 v nodes .........
    Thanks for help!
    My sketch:
    • The MySensors Arduino library handles the wireless radio link and protocol
    • between your home built sensors/actuators and HA controller of choice.
    • The sensors forms a self healing radio network with optional repeaters. Each
    • repeater and gateway builds a routing tables in EEPROM which keeps track of the
    • network topology allowing messages to be routed to nodes.
    • Created by Henrik Ekblad henrik.ekblad@mysensors.org
    • Copyright (C) 2013-2015 Sensnology AB
    • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    • Documentation: http://www.mysensors.org
    • Support Forum: http://forum.mysensors.org
    • This program is free software; you can redistribute it and/or
    • modify it under the terms of the GNU General Public License
    • version 2 as published by the Free Software Foundation.
    • REVISION HISTORY
    • Version 1.0 - idefix
    • DESCRIPTION
    • Arduino BH1750FVI Light sensor
    • communicate using I2C Protocol
    • this library enable 2 slave device addresses
    • Main address 0x23
    • secondary address 0x5C
    • connect the sensor as follows :
    • VCC >>> 5V
    • Gnd >>> Gnd
    • ADDR >>> NC or GND
    • SCL >>> A5
    • SDA >>> A4
    • http://www.mysensors.org/build/light
    #define MY_NODE_ID 9
    #include <BH1750.h>
    #define CHILD_ID_LIGHT 10
    #define RELAY_1 3 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_ON 0 // GPIO value to write to turn on attached relay
    BH1750 lightSensor;
    // transmitting LUX light level.
    // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux;
    void before() {
    pinMode(pin, OUTPUT);
    lightSensor.begin();
    sendSketchInfo("Relays and Light Lux Sensor node", "1.0");
    present(sensor, S_LIGHT);
    Serial.println(lux);
    if (lux != lastlux) {
    send(msg.set(lux));
    lastlux = lux;
    if (message.type==V_LIGHT) {
    // Change relay state
    // Store state in eeprom
  • Hi Marek,
    What I've done in this situation is to introduce a time check instead of sleeping the node, since you need to keep it awake to listen for relay commands. I got my inspiration from Hek's RGB dimmer sketch.
    My code was for a gas sensor:
    unsigned long currentTime  = millis();
    if (currentTime > lastTime + READ_DELAY_TIME) {
        lastTime = currentTime;
        readgassensor();
    READ_DELAY_TIME is set to 30000 so that it waits 30s between reads (in your case, increase that to get 1min intervals).
    This is not a super-precise way of doing it, but it's simple enough for regular sensor reads and seems to work for me.
    Hope that helps!
  • Hi!
    Thanks for help, now it works perfect 🙂
    Posting updated code:
    • REVISION HISTORY
    • DESCRIPTION
    • Main address 0x23
    • VCC >>> 5V
    • Gnd >>> Gnd
    • SCL >>> A5
    • SDA >>> A4
    #include <BH1750.h>
    unsigned long lastTime = millis();
    BH1750 lightSensor;
    uint16_t lastlux;
    void before() {
    if (currentTime > lastTime + 60000) {
    if (lux != lastlux)
    send(msg.set(lux));
    lastlux = lux; }
22
