MH-Z14A CO2 sensor
  • Re: MH-Z14A CO2 sensor
    I need to use this sensor but there is very little documentation on the flying lead header pitch. i need to use a connector that will securely fit the flying wire off of the sensor board to my PCB. but i don't know the pitch it is using, from pictures it looks like either the 1.27mm pitch or 1.5mm pitch. Can someone who has this sensor please help me?
    I would also be very interested in what each colour of the flying wire corresponds to which signal.
    cheers,
    Let's bring this thread to @alexsh1's attention
  • This has all the information i need:
    1.25mm pitch (i'm assuming for 7pins it should be interchangeable with a 1.27mm pitch)
    also from left to right: PWM, Tx, Rx, VCC, GND, AOUT, HD
    https://web.opendrive.com/api/v1/download/file.json/NDVfMzUyMzMyM18?inline=0
  • I am glad you work it out yourself
    I think when it comes to this sensor everything is well documented or available in the Internet
    The sensor is really simple to use, when attached via serial-ttl (3.3V) and powered with 5 volt.
    MH-Z14 co2 readings - PWM & UART with raspberry pi in C++ – 16:20
    — Gary Travell
    You get the values directly from the sensor and don't need to make calculations. Here is what I use:
       DESCRIPTION
        MH-Z14 CO2 sensor via rx/tx serial
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RF69_868MHZ
    #define MY_RFM69_NETWORKID 13
    #define MY_RFM69_ENABLE_ENCRYPTION
    #define MY_IS_RFM69HW
    #include <SoftwareSerial.h>
    #include "Adafruit_HTU21DF.h"
    SoftwareSerial mySerial(A0, A1); // RX, TX соответственно
    Adafruit_HTU21DF htu = Adafruit_HTU21DF();
    byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
    char response[9];
    #define CHILD_ID_AIQ 0
    #define CHILD_ID_TEMP  1
    #define CHILD_ID_HUM   2
    unsigned long SLEEP_TIME = 30 * 1000; // Sleep time between reads (in milliseconds)
    unsigned int TEMP_HUM_ROUNDS = 5; // wait 5 rounds for sending TEMP_HUM
    unsigned int loop_round = 0;
    boolean preheat = true;  // wait TEMP_HUM_ROUNDS for preheat
    int lastppm = 0;
    MyMessage msg(CHILD_ID_AIQ, V_LEVEL);
    MyMessage msg2(CHILD_ID_AIQ, V_UNIT_PREFIX);
    boolean isMetric = true;
      mySerial.begin(9600);
      isMetric = getConfig().isMetric;
      if (!htu.begin()) {
        Serial.println("Couldn't find sensor htu21!");
      sendSketchInfo("AIQ Sensor CO2 MH-Z14 Serial, HTU21 Temp Hum", "1.0");
      present(CHILD_ID_AIQ, S_AIR_QUALITY);
      send(msg2.set("ppm"));
      present(CHILD_ID_HUM, S_HUM);
      mySerial.write(cmd, 9);
      mySerial.readBytes(response, 9);
      int responseHigh = (int) response[2];
      int responseLow = (int) response[3];
      int ppm = (256 * responseHigh) + responseLow;
      if ((loop_round == 0) || (abs(ppm - lastppm) >= 10)) {
        if (!preheat) {
          send(msg.set(ppm));
          lastppm = ppm;
      if (loop_round == 0) {
        float temp = htu.readTemperature();
        if (!isMetric) {
          temp = temp * 9 / 5 + 32; // convert to farenheit
        send(msgTemp.set(temp, 1));
        float hum = htu.readHumidity();
        send(msgHum.set(hum, 1));
      loop_round++;
      if (loop_round >= TEMP_HUM_ROUNDS) {
        loop_round = 0;
        preheat = false;
      // Power down the radio.  Note that the radio will get powered back up
      // on the next write() call.
      sleep(SLEEP_TIME); //sleep for: sleepTime
    Thanks @FotoFieber for providing the information how to read the MH-Z14 via serial communication.
    Works like a charm.
    Seems like my MH-Z14 sensor is faulty after all. My problem was that the sensor reported the value 562 like 80% of the time. I was hoping I could solve this by using the serial method to read the value from the sensor but I stil had the same problem. Luckily I just received another MH-Z14 so I could replace it. Now it seems to work better.
    @korttoma
    It is working like a charme for me. Important is, to have 5V for voltage and 3.3 V on the logical level. Here is a graf, the green "Badezimmer" line is the mysensors sensor with MH-Z14A, the others are from netatmo. The mysensors sensor is in the bathroom and therefore it will have usually less CO2.
    @FotoFieber My new sensor is giving me the exact same behaivour. Could it be that the problem is that I'm using a 5V Pro Mini?
    Yes. You have to use a 3.3V arduino and power the sensor with 5V (seperate voltage). The sensor may break with a 5V arduino. I use a 3.3V 8 MHz pro mini.
    @FotoFieber
    So the symptom I see as the sensor constantly reporting the value 562 could be because it is already broken?
    Or would a broken sensor just stop communicating via serial?
    @korttoma
    As I do not have a broken sensor, I can not tell you.
    If I were you, I would try to fix the voltage issues and check, if it is working then.
    The sensor requires a preheat. Have you used my sketch from above?
    @FotoFieber I swapped out the 5V Pro Mini with a 3.3V Pro Mini yesterday and I'm afraid it did not help at all. If the Sensor would have had a problem with the 5V on the serial pins I bet it would no longer communicate.
    I used some parts of your sketch but since I use an Si7021 and a different radio I had to do some modifications:
     *  MH-Z14 CO2 sensor
     *  Wiring:
     *   Pad 1, Pad 5: Vin (Voltage input 4.5V-6V)
     *   Pad 2, Pad 3, Pad 12: GND
     *   Pad 6: PWM output ==> pin 6
     *  From: http://davidegironi.blogspot.fr/2014/01/co2-meter-using-ndir-infrared-mh-z14.html
     *    MH-Z14 has a PWM output, with a sensitivity range of 0ppm to 2000ppm CO2, an accurancy of ±200ppm.
     *    The cycle is 1004ms±5%, given the duty cicle Th (pulse high), Tl is 1004-Th, we can convert it to CO2 value using the formula:
     *    CO2ppm = 2000 * (Th - 2ms) /(Th + Tl - 4ms)
     *  From: http://airqualityegg.wikispaces.com/Sensor+Tests
     *    - response time is less than 30 s
     *   - 3 minute warm up time
     *  datasheet:
    * Contributor: epierre
    #define MY_NODE_ID  6
    #define SN "AIQ CO2 MH-Z14 TxRx"
    #define SV "2.1"
    #define MY_BAUD_RATE  9600
    #include <MyConfig.h>
    #include <SI7021.h>
    #include <RunningAverage.h>
    // Define a static node address, remove if you want auto address assignment
    SoftwareSerial mySerial(6, 7); // RX, TX
    char response[9];
    // Child sensor ID's
    #define CHILD_ID_AIQ 1
    #define CHILD_ID_TEMP  3
    //#define AIQ_SENSOR_ANALOG_PIN 5
    #define AVERAGES 2
    float valAIQ =0.0;
    float lastAIQ =0.0;
    int lastppm = 0;
    SI7021 humiditySensor;
    // Global settings
    float lastTemperature = -100;
    int lastHumidity = -100;
      humiditySensor.begin();
      sleep(SLEEP_TIME);
      //pinMode(AIQ_SENSOR_ANALOG_PIN, INPUT);
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
         wait(200);
      sendSketchInfo(SN, SV);
      present(CHILD_ID_TEMP,S_TEMP);
      present(CHILD_ID_HUM,S_HUM);
      wait(200);
      int co2ppm = (256 * responseHigh) + responseLow;
      Serial.print(F("c02ppm :"));Serial.println(co2ppm);
      if ( (abs(co2ppm - lastppm) >= 10)) {
          send(msg.set(co2ppm));
          lastppm = co2ppm;
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.print("T: ");Serial.println(temperature);
        send(msgTemp.set(temperature,1));
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) {
        Serial.print("H: ");Serial.println(humidity);
        send(msgHum.set(humidity));
        lastHumidity = humidity;
      //Serial.println();
    I hope I made a mistake in the sketch since I'm running out of ideas and I don't want the sensors to be broken.
    From where did you buy your sensor? I got them from aliexpress...
    @korttoma
    Where is the preheat logic in your sketch?
    Values in the preheat time could be wrong....
    @FotoFieber Yeah, I don't have preheat logic but that would only account for values when I first plug it in. I get the strange values even if it has been running for weeks. I will try to get a graph of what I see this evening so you can see what I mean. I'm seriously considering to just exclude the value 562 from being sent to the controller.
  • @korttoma Sounds like you have a faulty sensor. Did you try analogue output? This is just to make sure the sensor is working.
    There are PWM or UART.
    Did you try both of them? I am using 5V Arduino Nano with no problem.
    The digital pins communicate via PWM or UART. Output (and input for UART) of these ports work on 3.3 Volts - this means you should change the ARef of your Arduino - or rescale your values
  • @korttoma try to put it outside for some time to recalibrate. If it does not help, you may need to calibrate it.
    Or you just got a bad one.
    @alexsh1 Will the sensor really recalibrate by itself if I put it outside?
    I could send a "zero calibration" command via serial but then I would need to "input Nitrogen gas for 5 minutes when make zero calibration. "
    Instead of exposing it to nitrogen gas could I just like you said put it outside and then send the "zero calibration" command?
    To do the " span calibration" I would need to know what kind of values to send to it and I have no idea.
    btw, here are some values I read now via serial at the office (I do not get the 562 value so far) but does these values seem reasonable for a well ventilated office?
    HiResp :3
    LoResp :-21
    Tem.channel :63
    c02ppm :747
    HiResp :3
    LoResp :124
    Tem.channel :63
    c02ppm :892
    HiResp :3
    LoResp :21
    Tem.channel :63
    c02ppm :789
    HiResp :2
    LoResp :-57
    Tem.channel :63
    c02ppm :455
    HiResp :2
    LoResp :-110
    Tem.channel :63
    c02ppm :402
    HiResp :2
    LoResp :99
    Tem.channel :63
    c02ppm :611
    HiResp :2
    LoResp :51
    Tem.channel :63
    c02ppm :563
    HiResp :2
    LoResp :20
    Tem.channel :63
    c02ppm :532
    HiResp :1
    LoResp :-2
    Tem.channel :63
    c02ppm :254
    HiResp :1
    LoResp :-32
    Tem.channel :63
    c02ppm :224
    HiResp :1
    LoResp :-55
    Tem.channel :63
    c02ppm :201
    HiResp :1
    LoResp :-68
    Tem.channel :63
    c02ppm :188
    HiResp :1
    LoResp :-75
    Tem.channel :63
    c02ppm :181
    HiResp :1
    LoResp :-79
    Tem.channel :63
    c02ppm :177
    HiResp :1
    LoResp :-98
    Tem.channel :63
    c02ppm :158
    HiResp :1
    LoResp :-102
    Tem.channel :63
    c02ppm :154
    HiResp :1
    LoResp :-109
    Tem.channel :63
    c02ppm :147
    HiResp :1
    LoResp :-116
    Tem.channel :63
    c02ppm :140
    HiResp :1
    LoResp :-125
    Tem.channel :63
    c02ppm :131
    HiResp :1
    LoResp :-124
    Tem.channel :63
    c02ppm :132
    HiResp :1
    LoResp :111
    Tem.channel :63
    c02ppm :367
    HiResp :1
    LoResp :115
    Tem.channel :63
    c02ppm :371
    HiResp :1
    LoResp :121
    Tem.channel :63
    c02ppm :377
    HiResp :1
    LoResp :114
    Tem.channel :63
    c02ppm :370
    HiResp :1
    LoResp :-62
    Tem.channel :63
    c02ppm :194
    HiResp :1
    LoResp :-7
    Tem.channel :63
    c02ppm :249
    HiResp :1
    LoResp :-53
    Tem.channel :63
    c02ppm :203
    HiResp :1
    LoResp :-68
    Tem.channel :63
    c02ppm :188
    HiResp :1
    LoResp :-96
    Tem.channel :63
    c02ppm :160
    HiResp :1
    LoResp :-111
    Tem.channel :63
    c02ppm :145
    HiResp :1
    LoResp :-121
    Tem.channel :63
    c02ppm :135
    HiResp :1
    LoResp :-127
    Tem.channel :63
    c02ppm :129
    HiResp :1
    LoResp :-124
    Tem.channel :63
    c02ppm :132
    HiResp :1
    LoResp :-126
    Tem.channel :63
    c02ppm :130
    HiResp :1
    LoResp :-126
    Tem.channel :63
    c02ppm :130
    HiResp :1
    LoResp :-110
    Tem.channel :63
    c02ppm :146
    HiResp :1
    LoResp :-110
    Tem.channel :63
    c02ppm :146
    HiResp :1
    LoResp :-60
    Tem.channel :63
    c02ppm :196
    HiResp :1
    LoResp :-69
    Tem.channel :63
    c02ppm :187
    HiResp :1
    LoResp :-101
    Tem.channel :63
    c02ppm :155
    HiResp :1
    LoResp :-104
    Tem.channel :63
    c02ppm :152
    HiResp :1
    LoResp :-114
    Tem.channel :63
    c02ppm :142
    HiResp :1
    LoResp :-128
    Tem.channel :63
    c02ppm :128
    HiResp :1
    LoResp :-122
    Tem.channel :63
    c02ppm :134
    HiResp :1
    LoResp :122
    Tem.channel :63
    c02ppm :378
    HiResp :1
    LoResp :119
    Tem.channel :63
    c02ppm :375
    HiResp :1
    LoResp :-128
    Tem.channel :63
    c02ppm :128
    HiResp :1
    LoResp :-86
    Tem.channel :63
    c02ppm :170
    HiResp :1
    LoResp :-110
    Tem.channel :63
    c02ppm :146
    HiResp :1
    LoResp :-123
    Tem.channel :63
    c02ppm :133
    HiResp :1
    LoResp :-101
    Tem.channel :63
    c02ppm :155
    HiResp :1
    LoResp :-75
    Tem.channel :63
    c02ppm :181
    HiResp :1
    LoResp :-92
    Tem.channel :63
    c02ppm :164
    HiResp :1
    LoResp :-101
    Tem.channel :63
    c02ppm :155
    HiResp :1
    LoResp :-123
    Tem.channel :63
    c02ppm :133
    HiResp :1
    LoResp :-114
    Tem.channel :63
    c02ppm :142
    HiResp :1
    LoResp :-127
    Tem.channel :63
    c02ppm :129
    HiResp :1
    LoResp :-120
    Tem.channel :63
    c02ppm :136
    HiResp :1
    LoResp :126
    Tem.channel :63
    c02ppm :382
    HiResp :1
    LoResp :118
    Tem.channel :63
    c02ppm :374
    HiResp :1
    LoResp :-127
    Tem.channel :63
    c02ppm :129
    HiResp :1
    LoResp :118
    Tem.channel :63
    c02ppm :374
    HiResp :1
    LoResp :120
    Tem.channel :63
    c02ppm :376
    HiResp :1
    LoResp :118
    Tem.channel :63
    c02ppm :374
    HiResp :1
    LoResp :115
    Tem.channel :63
    c02ppm :371
    HiResp :1
    LoResp :124
    Tem.channel :63
    c02ppm :380
    HiResp :1
    LoResp :120
    Tem.channel :63
    c02ppm :376
    HiResp :1
    LoResp :-119
    Tem.channel :63
    c02ppm :137
    HiResp :1
    LoResp :-126
    Tem.channel :63
    c02ppm :130
    HiResp :1
    LoResp :-127
    Tem.channel :63
    c02ppm :129
    HiResp :1
    LoResp :-124
    Tem.channel :63
    c02ppm :132
    HiResp :1
    LoResp :121
    Tem.channel :63
    c02ppm :377
    HiResp :1
    LoResp :114
    Tem.channel :63
    c02ppm :370
    HiResp :1
    LoResp :108
    Tem.channel :63
    c02ppm :364
    HiResp :1
    LoResp :108
    Tem.channel :63
    c02ppm :364
    HiResp :1
    LoResp :119
    Tem.channel :63
    c02ppm :375
    HiResp :1
    LoResp :-110
    Tem.channel :63
    c02ppm :146
    HiResp :1
    LoResp :124
    Tem.channel :63
    c02ppm :380
    HiResp :1
    LoResp :127
    Tem.channel :63
    c02ppm :383
    HiResp :1
    LoResp :-43
    Tem.channel :63
    c02ppm :213
    HiResp :1
    LoResp :-72
    Tem.channel :63
    c02ppm :184
    HiResp :1
    LoResp :-77
    Tem.channel :63
    c02ppm :179
    HiResp :1
    LoResp :-63
    Tem.channel :63
    c02ppm :193
    HiResp :1
    LoResp :-92
    Tem.channel :63
    c02ppm :164
    HiResp :1
    LoResp :-105
    Tem.channel :63
    c02ppm :151
    HiResp :1
    LoResp :-116
    Tem.channel :63
    c02ppm :140
    HiResp :2
    LoResp :41
    Tem.channel :63
    c02ppm :553
    HiResp :2
    LoResp :47
    Tem.channel :63
    c02ppm :559
    HiResp :2
    LoResp :26
    Tem.channel :63
    c02ppm :538
    HiResp :2
    LoResp :-107
    Tem.channel :63
    c02ppm :405
    HiResp :2
    LoResp :-76
    Tem.channel :63
    c02ppm :436
    HiResp :2
    LoResp :-97
    Tem.channel :63
    c02ppm :415
    HiResp :2
    LoResp :-109
    Tem.channel :63
    c02ppm :403
    HiResp :2
    LoResp :106
    Tem.channel :63
    c02ppm :618
    HiResp :2
    LoResp :-96
    Tem.channel :63
    c02ppm :416
    HiResp :2
    LoResp :80
    Tem.channel :63
    c02ppm :592
    HiResp :2
    LoResp :69
    Tem.channel :63
    c02ppm :581
    HiResp :2
    LoResp :40
    Tem.channel :63
    c02ppm :552
    HiResp :2
    LoResp :84
    Tem.channel :63
    c02ppm :596
    HiResp :2
    LoResp :45
    Tem.channel :63
    c02ppm :557
    HiResp :2
    LoResp :3
    Tem.channel :63
    c02ppm :515
    HiResp :1
    LoResp :-30
    Tem.channel :63
    c02ppm :226
    HiResp :1
    LoResp :-62
    Tem.channel :63
    c02ppm :194
    HiResp :1
    LoResp :-73
    Tem.channel :63
    c02ppm :183
    HiResp :1
    LoResp :-75
    Tem.channel :63
    c02ppm :181
    HiResp :1
    LoResp :-96
    Tem.channel :63
    c02ppm :160
    HiResp :1
    LoResp :-89
    Tem.channel :63
    c02ppm :167
    HiResp :1
    LoResp :-101
    Tem.channel :63
    c02ppm :155
    HiResp :1
    LoResp :-112
    Tem.channel :63
    c02ppm :144
    HiResp :1
    LoResp :-107
    Tem.channel :63
    c02ppm :149
    HiResp :1
    LoResp :-112
    Tem.channel :63
    c02ppm :144
    HiResp :1
    LoResp :-110
    Tem.channel :63
    c02ppm :146
    HiResp :1
    LoResp :-124
    Tem.channel :63
    c02ppm :132
    HiResp :1
    LoResp :-120
    Tem.channel :63
    c02ppm :136
    HiResp :1
    LoResp :-75
    Tem.channel :63
    c02ppm :181
    Some of the values seem a bit low to me. Especially while the HiResp is 1 or the LoResp is negative.
    I will do this test again at home when I get the chance.
    @korttoma
    In the technical specification I only find the calibration with nitrogen. I don't think, that putting it outside, will help, as it is usually at around 400 ppm at the moment. (AFAIK netatmo sets the lowest measured value in the last one or two weeks to 400 for calibration).
  • @korttoma values are completely off. Co2 cannot go down below 300 level. This is a value of co2 outside (300-400).
    You have to calibrate it regularly. Zero calibration (this is what you are talking about) is different.
    8.1 The sensor should be calibrated regularly. The cycle time is better to be no more than 6 months. 8.2 Do not use the sensor in the high dusty environment for long time.
    8.3 Please use the sensor with correct power supply.
    8.4 Forbidden to cut the sensor pin.
    Try to put it outside for 10mins and then short pins 8 and 12 (see the photo below). This worked for me when I had some weird readings
  • @FotoFieber Netatmo is using index also cannot be compared with mh-z14a.
    I think the idea putting the sensor outside is to stabilise it - the reading is in the range of 300-400
    Where did you get this kind of information from? The MH-Z14.pdg I found online does not mention anything about this.
  • @korttoma It was recommended by an Aliexpress seller who sold me the sensor.
    Let's agree that Chinese documentation is not always comprehensive 🙂
    I finally found some time to really look in to this 562 issue. I looked at the raw data in DataMine2 and I noticed that the 562 value appeared every 10 minutes on the minute.
    Then I knew that this value cannot possibly come from the sensor. I search around in my Vera device for a bit and I found some lua code that copied the "Variable1" value from the sensor to the "CurrentLevel" every 10 minutes. Then I remembered that in the previous version of this sensor the value was reported via V_VAR1 and I had to copy it to another variable in Vera to be able to draw any graph. The current version of the sensor reports the value directly to the "CurrentLevel" variable and the value 562 that was still in the old variable was copied over the "real" value every 10 minutes.
    I also previously had some really low values from time to time from the sensor mostly when responseHigh = 1 and responseLow = negative value
    so I forced the responseLow to always be a positive value like this:
    int responseLow = abs((int) response[3]);
    I will keep an eye on the behavior of the sensor now that I have finally removed the confusing 562 value.
  • 87
  • 6
18
