BMP085 + DHT22
  • Hi
    I have a question. Is anybody here who has or can write coode code sketch for Arduino Mini Pro to read data from DHT22 and BMP085 to wrok as Weather Station and send correct to Domoticz ?
    Now i use this code but has a problem:
    #include <Adafruit_BMP085.h>
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 3000;
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 3
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    const float ALTITUDE = 206; // <-- adapt this value to your own location's altitude.
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
        STABLE = 0,            // "Stable Weather Pattern"
        SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
        CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
        UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
        THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
        UNKNOWN = 5            // "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    float lastPressure = -1;
    float lastTemp_C = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    DHT dht;
        if (!bmp.begin())
            Serial.println("Could not find a valid BMP085 sensor, check wiring!");
            while (1) {}
    void presentation()  {
      sendSketchInfo("Cis.+wilg.+temp.", "1.1");
      // Register sensors to gw (they will be created as child devices)
      present(BARO_CHILD, S_BARO);
      present(TEMP_CHILD, S_TEMP);
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
        float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
        float temperaturec = bmp.readTemperature();
        if (!metric)
            // Convert to fahrenheit
            temperaturec = temperaturec * 9.0 / 5.0 + 32.0;
        int forecast = sample(pressure);
        Serial.print("Temperature = ");
        Serial.print(temperaturec);
        Serial.println(metric ? " *C" : " *F");
        Serial.print("Pressure = ");
        Serial.print(pressure);
        Serial.println(" hPa");
        Serial.print("Forecast = ");
        if (temperaturec != lastTemp_C)
            send(tempMsg.set(temperaturec, 1));
            lastTemp_C = temperaturec;
        if (pressure != lastPressure)
            send(pressureMsg.set(pressure, 0));
            lastPressure = pressure;
        if (forecast != lastForecast)
            send(forecastMsg.set(weather[forecast]));
            lastForecast = forecast;
        sleep(UPDATE_INTERVAL);
        sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
        float lastPressureSamplesAverage = 0;
        for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
            lastPressureSamplesAverage += lastPressureSamples[i];
        lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
        return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
        // Calculate the average of the last n minutes.
        int index = minuteCount % LAST_SAMPLES_COUNT;
        lastPressureSamples[index] = pressure;
        minuteCount++;
        if (minuteCount > 185)
            minuteCount = 6;
        if (minuteCount == 5)
            pressureAvg = getLastPressureSamplesAverage();
        else if (minuteCount == 35)
            float lastPressureAvg = getLastPressureSamplesAverage();
            float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                dP_dt = change * 2; // note this is for t = 0.5hour
                dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
        else if (minuteCount == 65)
                dP_dt = change; //note this is for t = 1 hour
                dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
        else if (minuteCount == 95)
                dP_dt = change / 1.5; // note this is for t = 1.5 hour
                dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
        else if (minuteCount == 125)
            pressureAvg2 = lastPressureAvg; // store for later use.
                dP_dt = change / 2; // note this is for t = 2 hour
                dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
        else if (minuteCount == 155)
                dP_dt = change / 2.5; // note this is for t = 2.5 hour
                dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
        else if (minuteCount == 185)
                dP_dt = change / 3; // note this is for t = 3 hour
                dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
            pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        int forecast = UNKNOWN;
            forecast = UNKNOWN;
        else if (dP_dt < (-0.25))
            forecast = THUNDERSTORM;
        else if (dP_dt > 0.25)
            forecast = UNSTABLE;
            forecast = CLOUDY;
            forecast = SUNNY;
        else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
            forecast = STABLE;
            forecast = UNKNOWN;
        // uncomment when debugging
        //Serial.print(F("Forecast at minute "));
        //Serial.print(minuteCount);
        //Serial.print(F(" dP/dt = "));
        //Serial.print(dP_dt);
        //Serial.print(F("kPa/h --> "));
        return forecast;
    In Domoticz after communicate this node with Gateway , he find devices as show on screen 1 and in hardware screen 2. But i want to find temp from DHt22, Hum from DHT22, Baro from BMP085 and temp from BMP085.0_1477991582285_1.jpg
    please help me or correct this code.
  • Please help...
    I need merged to one sketch this:
    https://www.mysensors.org/build/humidity
    and this:
    https://www.mysensors.org/build/pressure
    @pepson there is a great guide on combining sketches at https://forum.mysensors.org/topic/115/implementing-multiple-sensors/4
  • @pepson
    I did what you tried to do, and it worked, also in Domoticz two temps are visible.
    This is my code:
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
     * Toegevoegd: na 10x dezelfde waarde te hebben gelezen bij TeEmp en Hum toch een waarde aan de GW sturen.
    const float ALTITUDE = 1.05; // <-- adapt this value to your own location's altitude.
    const char *weather[] = { "stabiel", "zonnig", "bewolkt", "onstabiel", "onweer", "onbekend" };
    enum FORECAST
    	STABIEL = 0,		// "Stable Weather Pattern"
    	ZONNIG = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
    	BEWOLKT = 2,		// "Slowly falling L-Pressure ", "BEWOLKT/Rain "
    	ONSTABIEL = 3,	// "Quickly rising H-Press",     "Not Stable"
    	ONWEER = 4,	    // "Quickly falling L-Press",    "ONWEER"
    	ONBEKEND = 5		// "ONBEKEND (More Time needed)
    float lastTempBMP = -1;
    float pressureAvg;
    float pressureAvg2;
    float dP_dt;
    DHT dht;
    float lastTempDHT;
    float lastHum;
    boolean metric = true;
    	gw.begin();
    	gw.sendSketchInfo("BaroHum", "2.0");
    	if (!bmp.begin())
    		while (1) {}
    	gw.present(BARO_CHILD, S_BARO);
    	gw.present(TEMP_CHILD, S_TEMP);
    	float temperatureBMP = bmp.readTemperature();
    	if (metric)
    		temperatureBMP = temperatureBMP * 9.0 / 5.0 + 32.0;
    	Serial.print(temperatureBMP);
    	if (temperatureBMP != lastTempBMP)
    		gw.send(tempMsg.set(temperatureBMP, 1));
    		lastTempBMP = temperatureBMP;
    		gw.send(pressureMsg.set(pressure, 0));
    		gw.send(forecastMsg.set(weather[forecast]));
    float temperatureDHT = dht.getTemperature();
      if (isnan(temperatureDHT)) {
      } else if (temperatureDHT != lastTempDHT  || nNoUpdatesTemp == FORCE_UPDATE_N_READS) {
        lastTempDHT = temperatureDHT;
        if (!metric) {
          temperatureDHT = dht.toFahrenheit(temperatureDHT);
        nNoUpdatesTemp = 0;
        gw.send(msgTemp.set(temperatureDHT, 1));
        Serial.println(temperatureDHT);
        nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
        nNoUpdatesHum++;
    	gw.sleep(SLEEP_TIME);
    	minuteCount++;
    		minuteCount = 6;
    	int forecast = ONBEKEND;
    		forecast = ONWEER;
    		forecast = ONSTABIEL;
    		forecast = BEWOLKT;
    		forecast = ZONNIG;
    		forecast = STABIEL;
    	return forecast;
    enum FORECAST
    float pressureAvg;
    float pressureAvg2;
    float dP_dt;
    DHT dht;
    float lastTempDHT;
    float lastHum;
    	gw.begin();
    	if (!bmp.begin())
    		while (1) {}
    	if (metric)
        if (!metric) {
        nNoUpdatesTemp = 0;
        nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
        nNoUpdatesHum++;
    	minuteCount++;
    		minuteCount = 6;
    		forecast = ONWEER;
    		forecast = BEWOLKT;
    		forecast = ZONNIG;
    		forecast = STABIEL;
    	return forecast;
