RFM69 BinarySwitchSleepSensor not working.
  • Im runnig a BinarySwitchSleepSensor.ino file with some edits to make it work with a RFM69 but alas im not getting what i want
    Here is the code im using (on a Uno with the level adjuster to get 3.3V)
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define RF69_IRQ_PIN 4
    #define SKETCH_NAME "Wall switch"
    #define SKETCH_MAJOR_VER "0"
    #define SKETCH_MINOR_VER "1"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
    MyMessage msg(PRIMARY_CHILD_ID, V_LIGHT);
    MyMessage msg2(SECONDARY_CHILD_ID, V_LIGHT);
      // Setup the buttons
      // Activate internal pull-ups
      present(PRIMARY_CHILD_ID, S_LIGHT);
      present(SECONDARY_CHILD_ID, S_LIGHT);
      uint8_t value;
      uint8_t value2;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      Serial.println("Im Awake!");
      if (value != sentValue) {
         Serial.println(value);
         send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
      value2 = digitalRead(SECONDARY_BUTTON_PIN);
      if (value2 != sentValue2) {
         Serial.println(value2);
         send(msg2.set(value2==HIGH ? 1 : 0));
         sentValue2 = value2;
      Serial.println("Going to sleep until buttons are pressed");
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    When i run this i get this from the Serial monitor, this is including me pressing the buttons connected to pin 2 -> GND and 3 -> GND.
    ti�G�Starting sensor (RRNNA-, 2.0.0)
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    Anyone got an idea on how to fix this?
    Hello.
    For the moment you have no communication.
    In your define you set RF69_IRQ = D4, but you can't. you need to use D2 or D3, native INT0/1 of Arduino which are compatible with Mysensors.
    So, interruption is not fired and then you cannot get any ACK etc..no parent node etc..
    So comment the line for D2 default, or use D3, should fix your problem i hope.
  • aah. Then I will have to run it from a 3.3V pro micro 🙂 need 3 interupt pins for this sketch 🙂
    Thank you for the answer!
  • 24
