Send msg in background
  • Hello
    I'm writing program for work with my waterpump.
    If the waterlevel is rich I would to turn on relay and (maybe in background_ I would like to send information to domoticz.
    Normally it works fine but if it a problem with connection to the gateway the program don't start...
    I cut code about Pump to make it easy to understand . I should see in console: "PUMP WORK" and "START"
    I get in console:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    My code:
    //#define MY_REPEATER_FEATURE
    //#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
    #define MY_TRANSPORT_DONT_CARE_MODE
    #define CHILD_ID 1 // turn on pump
    //Serial.begin(115200);
    Serial.println(" START ");
    sendSketchInfo("Pump", "1.0");
    present(CHILD_ID, S_LIGHT);
    ////......SOME CODE
    Serial.println("PUMP WORK");
    send(msg.set(true), true);
    @zsakul I know this is really late but I was just doing a search and came across your post. Hopefully you have found the solution but if not you need to put "#define MY_TRANSPORT_DONT_CARE_MODE" above #include <MySensors.h> in your code. Also, MY_TRANSPORT_DONT_CARE_MODE has been replaced by MY_TRANSPORT_WAIT_READY_MS 1 in the most recent version.
  • It's not working.
    Can I change also something in Config.h ?
    @zsakul Try downloading the latest version from github. The master branch will be updated to version 2.1 very soon and I recommend waiting for that. https://github.com/mysensors/MySensors/tree/master
    Once you have updated you should be able to use MY_TRANSPORT_WAIT_READY_MS in your code. I have it working in my device.
    You could change MY_TRANSPORT_WAIT_READY_MS in the myconfig.h file but if you do it there every node you build will have this setting (which my not be desired).
  • 14
  • 20
  • 274
