Can't assign firmware to node in MYSController for OTA
  • This is probably a stupid question but why can't I assign firmware to my node in MYScontroller?
    I use a Pro Mini 16MHz with the MYSBootloaderV13pre.hex burned and MYScontroller_1_0_0beta.
    In the context menu of the node I don't get the assign option:
    I can see the bootloader is communicating with my gateway (RPI Ethernet gateway) and in the controller.
    mysgw: TSF:MSG:FPAR REQ,ID=1
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    mysgw: TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFF0800DCEF0102
    mysgw: TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=0,sg=0:255
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    The controller log looks as follows:
    1/23/2017 19:07:58	INFO	BL version=258
    1/23/2017 19:07:58	INFO	No FW assigned
    1/23/2017 19:08:01	RX	1;255;4;0;0;FFFFFFFF0800DCEF0102
    1/23/2017 19:08:01	DEBUG	Undefined firmware/type for node=1
    1/23/2017 19:08:01	INFO	BL version=258
    1/23/2017 19:08:01	INFO	No FW assigned
    1/23/2017 19:08:05	RX	1;255;4;0;0;FFFFFFFF0800DCEF0102
    1/23/2017 19:08:05	DEBUG	Undefined firmware/type for node=1
    1/23/2017 19:08:05	INFO	BL version=258
    1/23/2017 19:08:05	INFO	No FW assigned
    1/23/2017 19:08:16	RX	1;255;4;0;0;FFFFFFFF0800DCEF0102
    1/23/2017 19:08:16	DEBUG	Undefined firmware/type for node=1
    1/23/2017 19:08:16	INFO	BL version=258
    1/23/2017 19:08:16	INFO	No FW assigned
    1/23/2017 19:08:19	RX	1;255;4;0;0;FFFFFFFF0800DCEF0102
    1/23/2017 19:08:19	DEBUG	Undefined firmware/type for node=1
    1/23/2017 19:08:19	INFO	BL version=258
    1/23/2017 19:08:19	INFO	No FW assigned
    1/23/2017 19:08:22	RX	1;255;4;0;0;FFFFFFFF0800DCEF0102
    1/23/2017 19:08:22	DEBUG	Undefined firmware/type for node=1
    1/23/2017 19:08:22	INFO	BL version=258
    1/23/2017 19:08:22	INFO	No FW assigned
    Somewhere I am missing something simple. Please help. I see that when I request info on the node it states the firmware updates are not allowed.
  • OK, OTA works with MYSController 0.1.2.282, it has the assign firmware in the context menu. But the latest version 1.0.0beta no way. Can't figure out how to assign the firmware.
  • Ok, so I reverted everything to the previous version of the MYSBootloader and the previous version of the MYSController. First time I tried I could assign firmware and do the OTA update.
    I then updated the bootloader to the latest version and OTA still worked. I then opened the latest version of the MYSController and guess what, I can assign firmware.
    SO what did I do? I made sure all files int he MYSController directory was read/write enabled. Was this the problem? I have no idea and clearly no-one else either.
    @MarcoE The issue you describe occurs when the firmware_config.csv file is corrupted or the formatting is wrong. Have a look at the MYSController log tab.
  • @tekka Thanks tekka, have it sorted now! Any idea why I can't reset my nodes from the MYSController? (!TX).
    @MarcoE !TX indicates that you are in "RX only" mode.
  • 482
  • 75
