Correct presentation of Sensebender temperature and humidity?
    I am starting slowly to get into MySensors, and currently my setup is sporting one Sensebender connected to a Raspberry serial gateway and Home Assistant on this Raspberry. This setup works, and the controller gets temperature and humidity from the sensor.
    I have some questions regarding the presentation in the loop function: the current temperature must be presented? Humidity also? To get the current temperature I have to add in the loop function everything needed to get a temperature value - since the values of the loop function are seen in Home Assistant? So looking at the sketch the temperature and humidity is sent twice to the gateway - once in loop, once in sendTempHumidityMeasurements? Should I get rid of one measurement sent to the gateway?
    Sorry for my basic questions... I am really happy to be so far though 🙂
    Here are those parts of the sketch:
    void presentation()  {
      sendSketchInfo("Sensebender Micro", RELEASE);
      present(CHILD_ID_TEMP,S_TEMP);
      present(CHILD_ID_HUM,S_HUM);
    #ifdef BATT_SENSOR
      present(BATT_SENSOR, S_POWER);
      if (!initialValueSent) {
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        Serial.println("Sending initial value");
        send(msgTemp.set(temperature,1));
        send(msgHum.set(humidity));
        wait(2000, C_SET, V_STATUS);
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        lastHumidity = humidity;
        transmission_occured = true;
        if (sendBattery > 60) {
         sendBattLevel(true); // Not needed to send battery info that often
         sendBattery = 0;
    @Madhias
    Just call sendTempHumidityMeasurements, with force argument set to true, from inside the if block in the loop. Then you don't need to duplicate code so much.
    You also need to change the last argument in the call to wait inside the if block in the loop. V_STATUS is not the correct type for temperature and humidity that you are waiting for. I think you can leave the last argument out in the call to wait. Let me double check that.
    Edit:
    No, you either have to call wait with all three arguments or only call it with one argument for time to wait. I guess you can put either V_HUM or V_TEMP as the last argument and just make sure you request that value last. BTW, you're missing a call to request as well. Put it after you send in the values ie after the call to sendTempHumidityMeasurements.
  • I have called the measurement function now inside the loop function (that is way better of course), and changed the third wait argument to V_TEMP. That works.
    I had a request in the code, but commented it out, it was like: request(CHILD_ID_TEMP, V_TEMP); because I was not sure if it is needed.
    Thanks for your help!
  • Hi Madhias, would you mind sharing your final sketch ?
    I am trying to get the very same thing working right now and am very new to programming for arduino's.
    Thanks in advance 🙂
  • I thought I have a correct sketch now, but as I loaded the sketch to another sensor, something must be wrong, since I always get this error in the Home Assistant log:
    WARNING:mysensors.mysensors:Node 2 is unknown
    INFO:mysensors.mysensors:Requesting new presentation for node 2
    INFO:homeassistant.components.mysensors:No sketch_name: node 2
    WARNING:mysensors.mysensors:child_id 1 already exists in children of node 2, cannot add child
    WARNING:mysensors.mysensors:child_id 2 already exists in children of node 2, cannot add child
    The json file looks like it got some values (I just changed the format for better reading here):
        "2": {
            "sketch_version": "1.4",
            "children": {
                "1": {
                    "type": 6,
                    "id": 1,
                    "description": "",
                    "values": {
                        "0": "25.6"
                "2": {
                    "type": 7,
                    "id": 2,
                    "description": "",
                    "values": {
                        "1": "65"
            "sensor_id": 2,
            "type": 17,
            "protocol_version": "2.1.1",
            "sketch_name": null,
            "battery_level": 104
    This is the sketch:
    // Define a static node address, remove if you want auto address assignment
    #define MY_NODE_ID 2
    // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
    #define MY_OTA_FIRMWARE_FEATURE
    #include <SI7021.h>
    #ifndef MY_OTA_FIRMWARE_FEATURE
    #include "drivers/SPIFlash/SPIFlash.cpp"
    #include <EEPROM.h>
    #include <sha204_lib_return_codes.h>
    #include <sha204_library.h>
    #include <RunningAverage.h>
    //#include <avr/power.h>
    // Uncomment the line below, to transmit battery voltage as a normal sensor value
    //#define BATT_SENSOR    199
    #define RELEASE "1.4"
    #define AVERAGES 2
    // Child sensor ID's
    #define CHILD_ID_TEMP  1
    #define CHILD_ID_HUM   2
    // How many milli seconds should we wait for OTA?
    #define OTA_WAIT_PERIOD 300
    #define FORCE_TRANSMIT_INTERVAL 30
    // Pin definitions
    #define TEST_PIN       A0
    #define LED_PIN        A2
    #define ATSHA204_PIN   17 // A3
    const int sha204Pin = ATSHA204_PIN;
    SI7021 humiditySensor;
    SPIFlash flash(8, 0x1F65);
    // Sensor messages
    #ifdef BATT_SENSOR
    MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean isMetric = true;
    boolean highfreq = true;
    boolean transmission_occured = false;
    bool state = false;
    bool initialValueSent = false;
    float lastTemperature = -100;
    int lastHumidity = -100;
    long lastBattery = -100;
     * Setup code
      pinMode(LED_PIN, OUTPUT);
      digitalWrite(LED_PIN, LOW);
      Serial.print(RELEASE);
      Serial.flush();
      // First check if we should boot into test mode
      pinMode(TEST_PIN,INPUT);
      digitalWrite(TEST_PIN, HIGH); // Enable pullup
      if (!digitalRead(TEST_PIN)) testMode();
      // Make sure that ATSHA204 is not floating
      pinMode(ATSHA204_PIN, INPUT);
      digitalWrite(ATSHA204_PIN, HIGH);
      digitalWrite(TEST_PIN,LOW);
      digitalWrite(LED_PIN, HIGH);
      humiditySensor.begin();
      Serial.flush();
      isMetric = getControllerConfig().isMetric;
      Serial.print(F("isMetric: ")); Serial.println(isMetric);
      raHum.clear();
      sendTempHumidityMeasurements(false);
      sendBattLevel(false);
    #ifdef MY_OTA_FIRMWARE_FEATURE
      Serial.println("OTA FW update enabled");
      present(CHILD_ID_HUM, S_HUM);
    #ifdef BATT_SENSOR
     *  Main loop function
        bool forceMeasure = true;
        sendTempHumidityMeasurements(forceMeasure);
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID_HUM, V_HUM);
        wait(2000, C_SET, V_TEMP);
      measureCount ++;
      sendBattery ++;
      bool forceTransmit = false;
        highfreq = false;
      if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        forceTransmit = true;
        measureCount = 0;
    /*  if (sendBattery > 60)
         sendBattLevel(forceTransmit); // Not needed to send battery info that often
         sendBattery = 0;
      if (transmission_occured) {
          wait(OTA_WAIT_PERIOD);
      sleep(MEASURE_INTERVAL);
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
      bool tx = force;
      if (tx) {
        measureCount = 0;
         sendBattery = 0;
     * Parameters
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery) {
        lastBattery = vcc;
    #ifdef BATT_SENSOR
        float send_voltage = float(vcc)/1000.0f;
        send(msgBatt.set(send_voltage,3));
        // Calculate percentage
        long percent = vcc / 14.0;
        sendBatteryLevel(percent);
    long readVcc() {
     * Verify all peripherals, and signal via the LED if any problems.
    void testMode()
      uint8_t ret_code;
      byte tests = 0;
      digitalWrite(LED_PIN, HIGH); // Turn on LED.
      Serial.println(F(" - TestMode"));
      Serial.println(F("Testing peripherals!"));
      Serial.flush();
      Serial.print(F("-> SI7021 : "));
      Serial.flush();
      if (humiditySensor.begin())
        Serial.println(F("ok!"));
        tests ++;
        Serial.println(F("failed!"));
      Serial.flush();
      Serial.print(F("-> Flash : "));
      Serial.flush();
      if (flash.initialize())
        tests ++;
      Serial.flush();
      Serial.print(F("-> SHA204 : "));
      Serial.flush();
      if (ret_code != SHA204_SUCCESS)
        Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
      Serial.flush();
      if (ret_code == SHA204_SUCCESS)
        ret_code = sha204.getSerialNumber(rx_buffer);
          Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
          Serial.print(F("Ok (serial : "));
          for (int i=0; i<9; i++)
            if (rx_buffer[i] < 0x10)
            Serial.print(rx_buffer[i], HEX);
          Serial.println(")");
          tests ++;
      Serial.flush();
      Serial.println(F("Test finished"));
      if (tests == 3)
        Serial.println(F("Selftest ok!"));
        while (1) // Blink OK pattern!
          delay(200);
          delay(200);
        Serial.println(F("----> Selftest failed!"));
        while (1) // Blink FAILED pattern! Rappidly blinking..
    @Mark69 Can't post a helpful sketch so far. Sorry!
    @Madhias
    Sketchname is missing in the persistence file, so maybe that message doesn't go through? Have you looked at the serial log of the node and confirmed that all messages are sent ok?
  • @martinhjelmare It works now! I think it is a hardware issue I have here, since I just put the decoupling capacitor in between the radio and the pin header socket. Checking that connection helped (pushing again in), and the presentation was correct now - including the sketch name.
  • 17
