Missing mysensors_XYZ.pretty files
  • I have installed KiCad on my Windows 8.1 PC and am trying to learn it so I can start making PCBs for some sensors. I am using the MySensors KiCad REPO and have followed the tutorial at https://github.com/mysensors-kicad/part_management and all seems to work. The issue though happens when I run CvPcb to associate the footprints and get the following error:
    IO_ERROR: footprint library path 'C:\Users\Thomas\Git\MySensors\mysensors_symbols\mysensors_radios.pretty' does not exist from C:/Jenkins/workspace/windows-kicad-msys2-stable/src/kicad/pcbnew/kicad_plugin.cpp : FootprintEnumerate() : line 1786
    I see the same error for all the mysensor_xyz.pretty files. Now those files are not in that location because the guide (refernced above) that I followed didn't say anything about cloning those "mysensor_xyz.pretty" repos and I was under the assumption that KiCad would look for those files in their respective GitHub repos. I figured that was the whole purpose of defining a MYSGITHUB path.
    Am I supposed to clone those repos as well? If so, wouldn't I need to update my fp-lib-table AND what is the point of the MYSGITHUB path?
    This is what the pertenant part of my fp-lib-table file looks like:
    (lib (name mysensors_arduino)(type Github)(uri ${MYSGITHUB}/mysensors_arduino.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_arduino.pretty")(descr ""))
      (lib (name mysensors_buttons)(type Github)(uri ${MYSGITHUB}/mysensors_buttons.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_buttons.pretty")(descr ""))
      (lib (name mysensors_connectors)(type Github)(uri ${MYSGITHUB}/mysensors_connectors.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_connectors.pretty")(descr ""))
      (lib (name mysensors_handsoldering)(type Github)(uri ${MYSGITHUB}/mysensors_handsoldering.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_handsoldering.pretty")(descr ""))
      (lib (name mysensors_leds)(type Github)(uri ${MYSGITHUB}/mysensors_leds.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_leds.pretty")(descr ""))
      (lib (name mysensors_network)(type Github)(uri ${MYSGITHUB}/mysensors_network.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_network.pretty")(descr ""))
      (lib (name mysensors_obscurities)(type Github)(uri ${MYSGITHUB}/mysensors_obscurities.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_obscurities.pretty")(descr ""))
      (lib (name mysensors_radios)(type Github)(uri ${MYSGITHUB}/mysensors_radios.pretty)(options "allow_pretty_writing_to_this_dir=${MYSLOCAL}\mysensors_symbols\mysensors_radios.pretty")(descr ""))```
  • One more thing. I thought maybe the "/" were messing up Windows so I switched a few of them to "" and then got this error on the ones I switched:
    IO_ERROR: http GET command failed Cannot get/download Zip archive: 'https://codeload.github.com/mysensors-kicad%5cmysensors_radios.pretty/zip/master' for library path: 'https://github.com/mysensors-kicad\mysensors_radios.pretty'. Reason: 'Bad request' from C:/Jenkins/workspace/windows-kicad-msys2-stable/src/kicad/pcbnew/github/github_plugin.cpp : remote_get_zip() : line 584```
    I haven't tried to use kicad on windows, but on Linux I have to create the *.pretty directories myself, if I create them, and leave them empty, kicad can figure the rest out by itself.
    And it shouldn't be necessary to change the forward slashes... If I remember right, @Anticimex verified the setup instructions on windows..
    The guide emphasizes in bold that you have to create the local pretty paths you specify in your fp table. Have you done that?
  • Ok, so I must have misread or just had a "space-out" moment when reading that part, but after creating the *.pretty directories it worked. Thanks!
    Spacing out is done by all, glad it was such a simple "fix" 🙂
  • 31
  • 6
