Temperature sensor WITH battery monitor
    I'm new to all of this arduino stuff, but I've managed to get a Serial GW and 2 tempsensors going.
    Now I would like to add the battery monitor to the temp sensor sketch, to monitor the 3,7V LiPo batteries.
    What I've done is, merged the battery sketch setup with the temp sketch setup, and also done the same with the Void sections.
    No errors on upload - weee!
    Problem is now, that I only get the Volt reading from the Node and no temperature reading anymore. 😞
    So where did I go wrong?
  • Here's my sketch for the tempnode:
    // Example sketch showing how to send in OneWire temperature readings
    #include <OneWire.h>
    unsigned long SLEEP_TIME = 120000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
    int oldBatteryPcnt = 0;
    // Startup OneWire
    sensors.begin();
    // Startup and initialize MySensors library. Set callback for incoming messages.
    gw.begin();
    gw.sendSketchInfo("Temperature Sensor", "1.0");
    gw.present(i, S_TEMP);
    analogReference(INTERNAL);
    // Process incoming messages (like config from server)
    float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
    if (lastTemperature[i] != temperature && temperature != -127.00) {
      gw.send(msg.setSensor(i).set(temperature,1));
    // get the battery Voltage
    Serial.println(sensorValue);
    float batteryV = sensorValue * 0.004106;
    Serial.print(batteryV);
    Serial.println(" V");
    Serial.print(batteryPcnt);
    Serial.println(" %");
    // Power up radio after sleep
    oldBatteryPcnt = batteryPcnt;
    gw.sleep(SLEEP_TIME);
  • DOH!!! Stupid me!
    Forgot the temp only transmits on temp change...
    it's working now 🙂
  • Perhaps related to the topic. This program was used for monitoring battery level, but can not read the battery level. 😞
    mqtt="<[mysensor:MyMQTT/21/255/V_BATTERY_LEVEL:state:default]"
    So I tried to read, the program opanhab, but not getting value. Any ideas what went wrong.
  • Hi
    I know this is an old post but I try to convert this Sketch to use it with Version 2.1.and I am not sure If this can be work because I am tottaly new in Arduino and Mysenseors
     #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
     unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)
     //MySensors gw;
     int numSensors=0;
     // Startup OneWire
     sensors.begin();
     present(i, S_TEMP);
    sleep(SLEEP_TIME);
    Would be great If someone confirm Ifthis is correct so far...
    Many thanks
    Markus
    @Markus. I would say: give it a go. It looks fine at first instance. It's rather hard to say it's correct without running it through a compiler. For readability's sake I would advice you to look at the coding guidelines for reference.
  • Its working so far.:-) But the battery voltage is only available as serial print. How must i change the file to get also the voltage send to the gateway? Simply by adding the send command before the sleep?
    Thx
    M.
    @Markus. You need to send the voltage explicit with a V_VOLTAGE (S_MULTIMETER) message.
  • @AWI Hope you can give me an example because it seems that the requiered programming Level currently are over my Knowledge 😉
    THX
    Markus
  • Anyone here an idea how i can get the voltage send tomthe gateway? Works great so far except the send of the voltage ....:-(
