Multiple Sensors on a single node?
  • I am having a problem getting HA to read multiple sensors from a single node. What am i missing? I am using the sample DHT Code below.
    // Enable debug prints
    //#define MY_RS485
    #define DHT_DATA_PIN 2
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor();
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL```
  • I feel smart now, After resetting the home assistant server I noticed that my motion sensor (Previously tested) was assigned to that node on child_id 1 After changing my temperature child_id to 2 The temperature showed up properly.
    You didn't specify the NODE ID, so it probably got the last one used on that board.
  • I have previously assigned the node and for testing purposes I don't mind it remaining the same. It was surprising to me that Home Assistant doesn't automatically detect sketch adjustments when the node connects. My next step is to learn how to clean up home assistants records to remove unwanted test data.
    You'd better change node ID if you want to change the sensors type in the sketch or delete sensor in Home assistant before uploading new sketch. You need to help the system a little, it can't do everything on its own
    @Jeff-Willecke
    Hi!
    If using JSON persistence, you can manually edit the JSON persistence file and remove old stale sensors. Make sure your retain the JSON structure.
  • Editing the json took care of all the junk. I appreciate the help.
  • you can use https://jsonformatter.org/json-editor to edit json data.
  • 17
