motion sensor and 2 relay code
  • hi all
    im running mysensors 2.0 with the following code on a node
     * Version 1.0 - Henrik Ekblad
    // Enable debug print
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2  5  // Arduino Digital I/O pin number for first relay
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    // Initialize motion message
    void before()
            pinMode(pin, OUTPUT);
        sendSketchInfo("Motion Sensor and officelights", "1.2");
        present(CHILD_ID, S_MOTION);
            present(sensor, S_BINARY);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
        if (message.type==V_STATUS) {
            // Change relay state
            // Store state in eeprom
    its a mix of copies of different examples but i think i stuffed it up
    i dont see any communication from domoticz when i switch my relays
    If you use sleep the node can't receive anything, try using wait(500)
  • This is my sketch for relays + motion sensor:
    You can specify everything in the "#define"-section of the code.
    Features:
    • multiple Relays
    • optional motion sensor
    • specify which relays should be triggered through the motion sensor
    • child ID of the motion sensor: 0
    • The Child-IDs of the attached relays range from 1 up to (1-(NUMBER_OF_RELAYS))
    A few things are missing at the moment (e.g. report the state of the motion-activated relays to the controller), but it should work out of the box.
       REVISION HISTORY
       Version 1.1 - HenryWhite
       DESCRIPTION
       Example sketch showing how to control physical relays.
       This example will remember relay state after power failure.
       Optional attachment of motion sensor to control the relays is possible.
       Note: The Child-IDs of the attached relays range from 1 up to (1-(NUMBER_OF_RELAYS))
    //----------------------- Library Configuration ---------------------
    #define MY_DEBUG                          // uncomment to enable debug prints to serial monitor
    //#define MY_REPEATER_FEATURE               // uncomment to enable repeater functionality for this node
    //#define MY_NODE_ID 20                       // uncomment to define static node ID
    // Enable and uncomment attached radio type
    //#define MY_TRANSPORT_WAIT_READY_MS 1      // uncomment this to enter the loop() and setup()-function even when the node cannot be registered to gw
    //----------------------- Relay Configuration -----------------------
    const int RELAYS[] = {6, 3, 5};             // digital pins of attached relays
    #define NUMBER_OF_RELAYS 3                  // Total number of attached relays
    //----------------------- Motion Sensor Configuration ---------------
    #define MOTION                              // un-comment to enable motion sensing
    #define MOTION_PIN 2                        // The digital input pin of the motion sensor
    const int MOTION_RELAY_PINS[] = {5};        // The digital input pins of the relays, which should be triggered through motion
    #define NUMBER_OF_MOTION_RELAYS 1           // Total number of relays, which should be triggered through motion
    #define MOTION_CHILD_ID 0                   // Set the child id of the motion sensor
    //----------------------- DO NOT CHANGE -----------------------------
    MyMessage msg(MOTION_CHILD_ID, V_TRIPPED);  // Initialize motion message
    bool lastTripped = 0;
    void before()
      int i;
      for (int sensor = 1, i = 0; sensor <= NUMBER_OF_RELAYS; sensor++, i++) {
        // set relay pins to output mode
        pinMode(RELAYS[i], OUTPUT);
        // Restore relay to last known state (using eeprom storage)
        digitalWrite(RELAYS[i], loadState(sensor) ? RELAY_ON : RELAY_OFF);
      // set motion pin to output mode, if MOTION is defined
    #ifdef MOTION
      pinMode(MOTION_PIN, INPUT);
      sendSketchInfo("Relay/Motion", "1.0");
      for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) {
    #ifdef MOTION
      present(MOTION_CHILD_ID, S_MOTION);
    #ifdef MOTION
      bool tripped = digitalRead(MOTION_PIN) == HIGH;
      if (lastTripped != tripped) {
        Serial.print("New Motion State: ");
        // Change relay states and store state in eeprom
        for (int i = 0; i < NUMBER_OF_MOTION_RELAYS; i++) {
          digitalWrite(MOTION_RELAY_PINS[i], tripped ? RELAY_ON : RELAY_OFF);
          saveState(i, tripped);
        send(msg.set(tripped ? "1" : "0"));
        lastTripped = tripped;
        digitalWrite(RELAYS[message.sensor - 1], message.getBool() ? RELAY_ON : RELAY_OFF);
        saveState(message.sensor - 1, message.getBool());
  • ok im really new at this coding ide stuff...what if i want none of the relays triggered by the motion sensor
    i would prefer to link each component back to domoticz by itself, and let it dictate what happens each part seperately...then i can change it easier if i want to leverage other things later
    Just remove the FOR cycle in the loop function
  • @gohan said in motion sensor and 2 relay code:
    It's much easier than that: Just set NUMBER_OF_MOTION_RELAYS to 0
  • i have attempted both
    the motion sensor now turns on and off on demand by waving my hand in front of it perfectly
    but the relay doesnt respond at all....
    the node receives the following message
    212874 TSF:MSG:READ,0-0-1,s=1,c=1,t=2,pt=0,l=1,sg=0:1
    Incoming change for sensor:1, New status: 1
    so i know the node receives it, but it doesnt seem to do anything with the message
    this is current code
       REVISION HISTORY
       DESCRIPTION
    #define MY_NODE_ID 1                       // uncomment to define static node ID
    const int RELAYS[] = {5};             // digital pins of attached relays
    #define NUMBER_OF_RELAYS 1                  // Total number of attached relays
    #define MOTION_PIN 3                        // The digital input pin of the motion sensor
    #define NUMBER_OF_MOTION_RELAYS 0          // Total number of relays, which should be triggered through motion
    void before()
      int i;
    #ifdef MOTION
      sendSketchInfo("Office Switches", "2.0");
    #ifdef MOTION
    #ifdef MOTION
    @markjgabb are you sure you connected the relay to the right pin? I usually try with LEDs attached to pins to check if all are working, it is easy to confuse pin numbers
  • ill double check it tonight, but im almost positive i have the pins right....
    it was working untill i removed the for part of the loop
    OK, then leave the FOR cycle and set the other parameter to 0 as suggested earlier
