Ethernet Gateway ....i am lost
  • I am also trying to build the ethernet gateway. I already have built a sensor (humidity and temp sensor) which is working and tested it with the serial gateway. For the gateway I am using a ardruino nano and a W5100 Ethernet module. (arduino 1.8.2 and board 1.6.11)
    The trouble i am having is getting a valid IP-number. In my scetch (it is the default scetch from the mysensors page for the gateway) i defined the following IP
    #define MY_IP_ADDRESS 192,168,1,108   // If this is disabled, DHCP is used to retrieve address
    When i start my scetch, i am see the following information in the serial monitor:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 0.168.1.108
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: disconnect
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:19.0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=0,c=1,t=1,pt=7,l=5,sg=0:72.0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=0,c=1,t=1,pt=7,l=5,sg=0:71.0
    as you can see the IP address is not correct, but it is receiving information from my temp/humidity sensor. Each time i reset the arduino i am getting a different value. Sometimes a part of my IP-address and sometimes just zeroes. In the page of my router with connected devices, i see sometimes new device with strange IP and part of de MAC-address.
    does anyone have an idea?
    @Mister_ik As you have the router, why don't you try with DHCP and lock an IP on Router for this gateway?
    Other solution you may go with MQTT gateway.
  • Probably a stupid question, but thought I'd chime in... Since you don't show it above, are you also #define'ing a MAC address (like below)... Is the MAC address unique on your network? I've seen very odd things happen with duplicate MACs.
    You could also try other sketches that use w5100 module and see what they do, but try dhcp first.
  • @jkandasa I already tried to lock an IP address on the router, but that does not change anything
  • @stevebus Yes the MAC address is also defined and i tried already different MAC address, so i know for sure it cant be a duplicate MAC address
    Could be a faulty module... Who knows... Did you try a different ethernet library version?
  • @gohan i am also affraid of a faulty module.....i am already waiting for new one to arrrive. i ordered now a ESP8266 version..hopefully more luck with that one.
  • I had the problem you describe, an ip address which was not the one it should be, usually a different one after each reset, sometimes with parts of the address recognisable as parts of the one I was expecting.
    I too tried a different W5100 module, different arduino, different connecting wires. No better.
    Then I found the answer, which was to supply the W5100 with 3.3v rather than the 5v I had been using. This fixed the problem completely.
    It is very odd that supplying the module with 5v stops it working properly, I can't explain it. It has an onboard AMS117 to convert the supply voltage to the 3.3v the chip needs.
    Whatever the reason though, it does fix the problem. I have two W5100 modules and neither will work properly if supplied with 5v. Both work perfectly on 3.3v.
    I see the instructions for the Mysensors ethernet gateway show the module supplied with 3.3v so I guess when I thought I knew better I was wrong!
    Hope this helps.
  • 24
