MySensors Controller
  • Hi.
    I want to setup the MySensors Controller and start to collect data, http://www.mysensors.org/build/raspberry. I'm not that interested in gui stuff at the moment. I followed the instructions on github,https://github.com/mysensors/Arduino/tree/master/NodeJsController, but I'm not sure I got it right.
    First, how do I connect the serial gateway to the Pi? Usb to usb or usb to GPIO? The mysensors site state one thing and github another or I don't understand that the are the same.
    Second, do I need the OTA stuff to get it to work if I only want to collect some data? I dont see the point but I might have missed something.
    /Markus
    If you make the serial gateway using an Arduino Nano you can just connect the USB of the Nano to the USB of you Raspberry Pi; you should see it using lsusb as:
    ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
    An it should enumerate as ttyUSB, but better try "ls /dev/serial/by-id/"
    No it is not needed. The OTA stuff is meant for Over-The-Air updates.
  • Thanks.
    Then I know I'm on the right track. Looks as if I'm getting something from the gateway in the log but nothing from the temp node yet. Need to investigate more.
    I figured out the Over the Air just could not see if it was relevant for some reason.
    /Markus
