Vera command to relay board
  • My MySensors gateway has been successfully communicating soil moisture sensor information to my Vera controller.
    I now need to be able to send Vera commands to a relay board.
    This is the sketch
    #define MY_REPEATER_FEATURE
    void before()
        pinMode(pin, OUTPUT);
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_BINARY);
      if (message.type==V_STATUS) {
        // Change relay state
        // Store state in eeprom
        Serial.println(message.getBool());```
    Debug output
    0 MCO:BGN:INIT REPEATER,CP=RNNRA---,VER=2.2.0-beta
    4 MCO:BGN:BFR
    6 TSM:INIT
    6 TSF:WUR:MS=0
    14 TSM:INIT:TSP OK
    16 TSF:SID:OK,ID=1
    18 TSM:FPAR
    55 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    632 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    636 TSF:MSG:FPAR OK,ID=0,D=1
    2062 TSM:FPAR:OK
    2062 TSM:ID
    2064 TSM:ID:OK
    2066 TSM:UPL
    2070 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2080 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2086 TSF:MSG:PONG RECV,HP=1
    2091 TSM:UPL:OK
    2091 TSM:READY:ID=1,PAR=0,DIS=1
    2097 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2105 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2113 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=18,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
    2123 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2170 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2177 !TSF:MSG:PVER,0=2
    2181 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
    2189 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    2199 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    2207 MCO:REG:REQ
    2209 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2217 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2224 MCO:PIM:NODE REG=1
    2226 MCO:BGN:STP
    2228 MCO:BGN:INIT OK,TSP=1
    29208 TSF:MSG:READ,0-0-1,s=1,c=1,t=2,pt=0,l=1,sg=1:0
    29214 !TSF:MSG:PVER,0=2
    63557 TSF:MSG:READ,0-0-1,s=1,c=1,t=2,pt=0,l=1,sg=1:1
    63563 !TSF:MSG:PVER,0=2
    Vera log extract
    grep Arduino LuaUPnP.log
    02      07/11/17 13:51:05.869   luup_log:78: Arduino: Incoming internal command '1;255;3;0;21;0' discarded for child: 95 <0x2e52a680>
    50      07/11/17 13:56:50.572   luup_log:78: Arduino: Sending: 1;1;1;1;2;1 <0x2adab000>
    50      07/11/17 13:58:26.814   luup_log:78: Arduino: Sending: 1;1;1;1;2;1 <0x2adab000>
    50      07/11/17 13:58:38.725   luup_log:78: Arduino: Presentation: 1;255;0;0;18;2.2.0-beta <0x2e52a680>
    50      07/11/17 13:58:38.725   luup_log:78: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,ArduinoLibVersion, 2.2.0-beta, 95 <0x2e52a680>
    50      07/11/17 13:58:38.725   luup_log:78: Arduino: Warning: Sensor has different library version than GW. Id: 1;255 <0x2e52a680>
    50      07/11/17 13:58:38.727   luup_log:78: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdate, 1499777918, 95 <0x2e52a680>
    50      07/11/17 13:58:38.729   luup_log:78: Arduino: urn:micasaverde-com:serviceId:HaDevice1,LastUpdateHR, 13:58, 95 <0x2e52a680>
    50      07/11/17 13:58:38.730   luup_log:78: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,RelayNode, 0, 95 <0x2e52a680>
    50      07/11/17 13:58:38.731   luup_log:78: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,RelayNodeHR, GW, 95 <0x2e52a680>
    50      07/11/17 13:58:38.731   luup_log:78: Arduino: Sending: 1;255;3;0;6;M <0x2e52a680>
    50      07/11/17 13:58:38.814   luup_log:78: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,SketchName, Relay, 95 <0x2e52a680>
    50      07/11/17 13:58:38.816   luup_log:78: Arduino: urn:upnp-arduino-cc:serviceId:arduinonode1,SketchVersion, 1.0, 95 <0x2e52a680>
    50      07/11/17 13:58:38.817   luup_log:78: Arduino: Presentation: 1;1;0;0;3; <0x2e52a680>
    50      07/11/17 13:59:05.812   luup_log:78: Arduino: Sending: 1;1;1;1;2;0 <0x2adab000>
    50      07/11/17 13:59:40.214   luup_log:78: Arduino: Sending: 1;1;1;1;2;1 <0x2adab000>
    As far as I can see clicking the 'On' or 'Off' buttons in the Vera plugin sends a message to the relay board, but I cannot understand why I'm getting the '!TSF:MSG:PVER,0=2' error (Message protocol version mismatch (actual!=expected) )?
    @Woodside i think it is wise to bring all modules to same version.
    • Your MySensors tile reports an old plugin version (1.5 latest version is 1.7) does not report a lib-version (gateway) but in your Vera log this message appears
    • And your repeater tile reports 2.2.0-beta
    i would suggest to start using the stable released version 2.1.1 and try again.
  • @BartE
    I am running Vera UI5.
    The link from the MySensors 'Vera Controller' page, takes me to [https://github.com/mysensors/Vera/tree/master] which is plugin V1.5 (I think)
    Should I be using this or something later from the Development branch?
