BME280 temp/humidity/pressure sensor
  • Has anyone built a node that uses the BME280 temp/humidity/pressure sensor?
    I'm guessing if I build it from scratch, the HumiditySensor example would probably be the best one to use. One thing I saw was that someone is working on an ESP8266 weather station gateway with this sensor, and in his comments, it appears that you have to do some funky stuff with moving the CE pin somewhere else or it interferes with the I2C communication for this chip. I would be doing this on a Nano, not an ESP. Are the pin changes the same?
    On the ESP8266 SDA and SCL native pins are used in the radio wiring, that's why you need the funky stuff.
    No pin changes necessary on nano or promini as A4 and A5 are not used. You plug it as any other I2C sensor (just be sure to feed it with 3.3V, not 5V)
  • Awesome. I just got it working with a test sketch like 2 minutes ago. If I get a working sketch for MySensors, how can I get it uploaded to the site as an example?
    Also, if anyone has done it before, I'd appreciate any code you might have to save some time. I only get like 5 minutes here an there to work on this.
    This should work, it removes the 2-3 ESP8266 config lines:
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    // BME280 libraries and variables
    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
    // Written originally by Embedded Adventures
    // https://github.com/embeddedadventures/BME280
    #include <BME280_MOD-1022.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define HUM_CHILD 2
    const float ALTITUDE = 23; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
    // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
      STABLE = 0,     // "Stable Weather Pattern"
      SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
      CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
      UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
      THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
      UNKNOWN = 5     // "Unknown (More Time needed)
    float lastPressure = -1;
    float lastTemp = -1;
    float lastHum = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
    // get kPa/h by dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage humMsg(HUM_CHILD, V_HUM);
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      return lastPressureSamplesAverage;
    // Algorithm found here
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
          dP_dt = change * 2; // note this is for t = 0.5hour
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
          dP_dt = change; //note this is for t = 1 hour
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
      int forecast = UNKNOWN;
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
        forecast = CLOUDY;
        forecast = SUNNY;
      else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
        forecast = UNKNOWN;
      // uncomment when debugging
      //Serial.print(F("Forecast at minute "));
      //Serial.print(minuteCount);
      //Serial.print(F(" dP/dt = "));
      //Serial.print(dP_dt);
      //Serial.print(F("kPa/h --> "));
      return forecast;
      Wire.begin(); // Wire.begin(sda, scl)
    void presentation()  {
      sendSketchInfo("BME280 Sensor", "1.6");
      // Register sensors to gw (they will be created as child devices)
      present(BARO_CHILD, S_BARO);
      present(TEMP_CHILD, S_TEMP);
      present(HUM_CHILD, S_HUM);
    // Loop
      // need to read the NVM compensation parameters
      BME280.readCompensationParams();
      /* After taking the measurement the chip goes back to sleep, use when battery powered.
      // Oversampling settings (os1x, os2x, os4x, os8x or os16x).
      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient, higher numbers avoid sudden changes to be accounted for (such as slamming a door)
      BME280.writeOversamplingPressure(os16x);    // pressure x16
      BME280.writeOversamplingTemperature(os8x);  // temperature x8
      BME280.writeOversamplingHumidity(os8x);     // humidity x8
      BME280.writeMode(smForced);                 // Forced sample.  After taking the measurement the chip goes back to sleep
      // Normal mode for regular automatic samples
      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
      BME280.writeMode(smNormal);
      while (1) {
        // Just to be sure, wait until sensor is done mesuring
        while (BME280.isMeasuring()) {
      // Read out the data - must do this before calling the getxxxxx routines
      BME280.readMeasurements();
      float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
      float humidity = BME280.getHumidityMostAccurate();
      float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
      float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
      int forecast = sample(pressure);
      if (!metric)
        // Convert to fahrenheit
        temperature = temperature * 9.0 / 5.0 + 32.0;
      Serial.println();
      Serial.print("Temperature = ");
      Serial.print(temperature);
      Serial.println(metric ? " °C" : " °F");
      Serial.print("Humidity = ");
      Serial.print(humidity);
      Serial.println(" %");
      Serial.print("Pressure = ");
      Serial.print(pressure);
      Serial.println(" hPa");
      Serial.print("Forecast = ");
      Serial.println();
      if (temperature != lastTemp)
        send(tempMsg.set(temperature, 1));
        lastTemp = temperature;
      if (humidity != lastHum)
        send(humMsg.set(humidity, 1));
        lastHum = humidity;
      if (pressure != lastPressure)
        send(pressureMsg.set(pressure, 2));
        lastPressure = pressure;
      if (forecast != lastForecast)
        send(forecastMsg.set(weather[forecast]));
        lastForecast = forecast;
      sleep(SLEEP_TIME);
  • @signal15
    I have this sensor working on Arduino Mini Pro. I am sure you can make it work under ESP8266
  • @emc2
    I'm getting some problems compiling the code you provided above. Is this for 1.6 or something? I'm on 1.5, do I need to change some function names?
    Arduino/Mysensors_BME280/Mysensors_BME280.ino: In function 'void setup()':
    Mysensors_BME280:252: error: 'getConfig' was not declared in this scope
    /Users/jay.austad/Documents/Arduino/Mysensors_BME280/Mysensors_BME280.ino: In function 'void presentation()':
    Mysensors_BME280:258: error: 'sendSketchInfo' was not declared in this scope
    Mysensors_BME280:261: error: 'present' was not declared in this scope
    /Users/jay.austad/Documents/Arduino/Mysensors_BME280/Mysensors_BME280.ino: In function 'void loop()':
    Mysensors_BME280:328: error: 'send' was not declared in this scope
    Mysensors_BME280:335: error: 'send' was not declared in this scope
    Mysensors_BME280:341: error: 'send' was not declared in this scope
    Mysensors_BME280:347: error: 'send' was not declared in this scope
    Mysensors_BME280:351: error: 'sleep' was not declared in this scope
       sleep(SLEEP_TIME);
    exit status 1
    'getConfig' was not declared in this scope```
  • Ah, looks like I just need to add "gw." in front of all of these functions and "MySensor gw;" just after the includes.
    Ah yes sorry, it's for the dev branch (1.6 or now called 2.0)
  • @emc2
    Eh, looks like there's a lot more that I have to do to get this working, like moving the presentation into the setup() function.
    If you are using 1.5 probably a lot more.
    Easier to install 2.0, compile and upload. It will be compatible with your 1.5 gateway anyway.
  • @emc2
    Oh, I thought that you had to upgrade the gateway as well. If that's the case, then I'll grab 2.0. Do I just go to the dev branch in github and hit download ZIP?
  • Do you have to upgrade the files on the controller to 2.0b as well? I have a vera, and when I added this new sensor on 2.0b, all of my nodes stopped updating and the tiles for them on the Devices screen doesn't list anything about the sensor like it normally does.
    I get these errors in the Vera logs:
    02	05/06/16 18:54:40.167	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduino1 <0x2ac17000>
    02	05/06/16 18:54:40.170	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduinonode1 <0x2ac17000>
    02	05/06/16 18:54:40.171	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduinonode1 <0x2ac17000>```
    Also, the MySensors parent device disappeared from my Devices page in Vera. If I telnet to my gateway on port 5003, I only see the new sensor reporting as well, not any of my other sensors. Did the 2.0b sensor do something bad to my gateway or the Vera plugin?
    Update: I deleted the new devices created from the 2.0b sensor in my Vera. This fixed it so the other node information showed up again, and the MySensors parent device showed up. But, my 1.5 sensors were no longer updating. I restarted them, and they started updating.
    If 2.0 sensors are designed to be backwards compatible with a 1.5 gateway and 1.5 controller code, then there's a problem somewhere. Maybe it's with the Vera code. But, like I said, I telneted to port 5003 on my gateway, and the only thing that the gateway was receiving was the data from my 2.0b sensor. Either the gateway was ignoring the 1.5 sensors, or the 1.5 sensors stopped sending for some reason.
    Thoughts?
  • @hek
    Let me know if you make a change and need me to test.
  • @emc2 or anybody:
    Does anyone have a working BME280 mysensors arduino sketch? The code above states include mysensor.h now it is mysensorS.h, so I have renamed, but it won't compile, it says:
    bme280:252: error: 'getConfig' was not declared in this scope
    I have a MySensors Gateway USB
    Version: 2.1.1 (arduino nano) with Domoticz, and I would like to use the bme280 for a battery powered outdoor temp/humidity/barometer (as DHT22 does not like battery level below 3.3V, and I would run on 2x1.5V AA)
    Was modified in 2.1.1, you need to change
    to
    metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
  • Still a lot of errors in this sketch, did take some out but this is still in it:
    In file included from C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino:48:0:
    C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
    #ifndef __BME280_MOD-1022_H
    C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
    #define __BME280_MOD-1022_H
    In file included from C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:40:0:
    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp: In member function 'BME280Class::readCompensationParams()':
    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:276:45: warning: iteration 20 invokes undefined behavior [-Waggressive-loop-optimizations]
    compParams.compArray[count] = Wire.read();
    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:275:3: note: containing loop
    for (count = 0; count < 28; count++) { // first 28 bytes we can process like this
    C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino: In function 'loop':
  • @emc2 Thanks! With this modification the sketch compiled successfully. Today I had time, so put everything together, and the BME280 works with the 2.4GH radio, temp/hum/pressure all reporting like they should.
    Using arduino pro mini, bme280, nrf24, 2XAA Batteries. It reports to the mysensors serial gw, and then shown in domoticz.
  • @yoshida Hello
    You can share your sketch.
    Please
    I can not make modifications.
    I still have a lot of errors.
  • Zbigniew Ko:
    (2.1.1 mysensors compatible, but first you need to install the BME280_MOD-1022.h library in arduino IDE)
    #define HUM_CHILD 2
    const float ALTITUDE = 184; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
    enum FORECAST
    float lastHum = -1;
    float pressureAvg;
    float pressureAvg2;
    float dP_dt;
    boolean metric;
      minuteCount++;
        minuteCount = 6;
        forecast = UNKNOWN;
        forecast = CLOUDY;
        forecast = SUNNY;
        forecast = STABLE;
        forecast = UNKNOWN;
      return forecast;
    // Loop
      while (1) {
      if (!metric)
      Serial.println();
      Serial.println();
        lastHum = humidity;
      sleep(SLEEP_TIME);
  • @yoshida Thank you very much.
    As soon as I find time I will check it out.
    Yes checked, sketch works.
    Thanks yoshida.
    Please note that the library BME_MOD-1022.h consists of two parts: file-h, and file cpp.
    I am using the one from adafruit : what's the difference with this other library?
  • @gohan I have been using both libraries with a chinese module I bought from Aliexpress. I did not notice any differences apart from size and maybe a module address, which you can change in either library.
  • I used the last sketch posed by Yoshida and for some reason whenever the temp and humidity goes through a stretch where there isn't any change, it's as if the node goes into a deep sleep and doesn't come out of it until I hit the reset on a pro mini.
    I have it plunged in and not on batteries, so no need for any deep sleep. Is there anything I can change in the sketch? I'm still fairly new at this, although I'm having a blast.
  • @bluezr1 Interesting... 🙂 I used it with a pro mini as well, and my problem was that it ate up the batteries in 2 weeks... 😄 So I would need more deep sleep for the same sketch 😄
    But for that 2 weeks, it was working well. Temp/Hum/Baro updated every minute.
    @yoshida did you do the modifications (remove led and regulator) recommended at https://www.mysensors.org/build/battery ?
    My storage room sensor (https://forum.mysensors.org/topic/7227/esp8266-wifi-gateway-with-rssi-for-rfm69-and-wifi ) uses the bme280. Not sure if that sketch is any help, but you are welcome to use it. It is much much simpler than the sketch posted above though.
  • @mfalkvidd good question, yes I have removed the two leds I found, but I am too lame to remove the voltage regulator 😞 I have read here that the most consuming part is the LED(s)
  • @yoshida said in BME280 temp/humidity/pressure sensor:
    >  * The MySensors Arduino library handles the wireless radio link and protocol
    >  * between your home built sensors/actuators and HA controller of choice.
    >  * The sensors forms a self healing radio network with optional repeaters. Each
    >  * repeater and gateway builds a routing tables in EEPROM which keeps track of the
    >  * network topology allowing messages to be routed to nodes.
    >  * Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
    >  * Copyright (C) 2013-2015 Sensnology AB
    >  * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
    >  * Documentation: http://www.mysensors.org
    >  * Support Forum: http://forum.mysensors.org
    >  * This program is free software; you can redistribute it and/or
    >  * modify it under the terms of the GNU General Public License
    >  * version 2 as published by the Free Software Foundation.
    >  * REVISION HISTORY
    >  * DESCRIPTION
    > // Enable debug prints to serial monitor
    > #define MY_DEBUG
    > // Enable and select radio type attached
    > #define MY_RADIO_NRF24
    > //#define MY_RADIO_RFM69
    > #include <SPI.h>
    > #include <MySensors.h>
    > #include <Wire.h>
    > #define HUM_CHILD 2
    > enum FORECAST
    > float lastHum = -1;
    > float pressureAvg;
    > float pressureAvg2;
    > float dP_dt;
    > boolean metric;
    >   minuteCount++;
    >     minuteCount = 6;
    >     else
    >     else
    >     else
    >     else
    >     else
    >     else
    >     forecast = UNKNOWN;
    >     forecast = CLOUDY;
    >     forecast = SUNNY;
    >     forecast = STABLE;
    >   else
    >     forecast = UNKNOWN;
    >   return forecast;
    > void setup() {
    >   // Send the sketch version information to the gateway and Controller
    > // Loop
    > void loop() {
    >   while (1) {
    >   if (!metric)
    >   Serial.println();
    >   Serial.println();
    >     lastHum = humidity;
    >   sleep(SLEEP_TIME);
    Added to sketch @yoshida battery state send, but its not sending it, please chek it:
    #define HUM_CHILD 2
    int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
    int oldBatteryPcnt = 0;
    const float ALTITUDE = 450; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
    const unsigned long SLEEP_TIME = 300000;
    enum FORECAST
    float lastHum = -1;
    float pressureAvg;
    float pressureAvg2;
    float dP_dt;
    boolean metric;
      minuteCount++;
        minuteCount = 6;
        forecast = UNKNOWN;
        forecast = CLOUDY;
        forecast = SUNNY;
        forecast = STABLE;
        forecast = UNKNOWN;
      return forecast;
      analogReference(INTERNAL1V1);
      analogReference(INTERNAL);
    // Loop
      while (1) {
      if (!metric)
      Serial.println();
      Serial.println();
        lastHum = humidity;
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
      sleep(SLEEP_TIME);
    @scalpel - works great! Thank you!!
    Downloaded the library from the link in your sketch and up and running i no time.
    Here is my sketch, with some modifications:
    • Lightsensor A0
    • No sleep (might want to enable repeater function later)
    • Sends every 5 minute regardless of prevoius value (I use Domoticz and want to avoid red nodes and combined nodes).
    • Fixed node it
    //Fixed ID/Parent?
    #define MY_NODE_ID 20                     //To set a fixed ID for your node
    //#define MY_PARENT_NODE_ID 100             //To set a fixed parent for this node
    #define HUM_CHILD 2
    long interval = 300000;           // interval at which to send (milliseconds)
    long previousMillis = interval;        // will store last time data was sent
    const float ALTITUDE = 135; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
    enum FORECAST
    float pressureAvg;
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    //Light
    #define CHILD_ID_LIGHT 3
    #define LIGHT_SENSOR_ANALOG_PIN A0
    MyMessage light_Msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      minuteCount++;
        minuteCount = 6;
        forecast = UNKNOWN;
        forecast = CLOUDY;
        forecast = SUNNY;
        forecast = STABLE;
        forecast = UNKNOWN;
      return forecast;
      sendSketchInfo("WeatherStation #20", "1.0");
    // Loop
    if(currentMillis - previousMillis > interval) {
        // save the last time sent the data
      analogReference(DEFAULT);
      wait(500);
       readLightLevel();   //Read Light
      wait(500);
      if (!metric)
      Serial.println();
      Serial.println();
    wait(50);
    wait(50);
    wait(50);
    wait(50);
    void readLightLevel()      {
      Serial.println(analogRead(A0));
      int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23; //To get a value ranging from 0 (dark) to 100 (bright).
    #ifdef MY_DEBUG
      Serial.print("Light: "); Serial.println(lightLevel);
      send(light_Msg.set(lightLevel));
  • Hi...i am a new user here. I built a RFM69 gateway and a node.I decided to place the RFM69 node in a basement storage room. The room has been flooded a few times historically, so being able to monitor humidity in the room seems like a good idea.The room has thick brick walls, which the RFM69-433MHz radio is much more capable to handle than the nrf24. Still, I wanted to keep an eye on the signal strength. Because of this, I added code to the gateway to report RSSI from the node.
    circuit card assembly
  • 87
  • 7
  • 7
