openHAB 2.2 binding MQTT support
    Finally I'm able to present a first alpha release of the MQTT support of the OpenHAB2 binding.
    I've done some first tests with a RGB node and it looks good, but there is still some work to do.
    So this version is for the category "Don't try this at home!". 😉
    Some important notes and things to test:
    • The binding uses the upcoming MQTT support in smarthome/OpenHAB2, not the old version 1 binding! They may work together, but we need to test that. If you're willing to test that, please let me now.
    • I've tested with OpenHAB2 snapshot #1099. I don't know how far it is compatible to old versions.
    • There is a PR in the smarthome repository to add the functionality of a MQTT broker to OpenHAB2, so a separate broker won't be needed in the future. The binding will be compatible with this addition.
    • I need to adjust logging.
    Instructions:
    1. Start OpenHAB2
    2. In karaf console:
      feature:install esh-io-transport-mqtt
    3. Download binding:
      wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.2.0-mqtt.jar
    4. Place "org.eclipse.smarthome.mqtt.cfg" in the /etc/openhab2/services or conf/services directory. New filename! (Wassn't my idea!) 😉
    Example:
    mosquitto.url=tcp://192.168.2.3:1883
    mosquitto.user=user
    mosquitto.pwd=secret
    mosquitto.retain=false
    (Use it like the old mqtt.cfg)
    1. Configure MQTT broker via PaperUI
      or
    via *.things file
    Bridge mysensors:bridge-mqtt:gateway [  brokerName="mosquitto",
                                            topicPublish="mygateway1-in",
                                            topicSubscribe="mygateway1-out",
                                            startupCheckEnabled=false ] {
    1. Configure or discover things.
    That's it!
  • This is great, it will certainly simplify usage of mySensors over mqtt. I remember that it took me 4-5 hours to set everything up. (I did learn a lot about mqtt and openhab, but still).
    It is still early to mention it, but... if you can somehow get FOTA to work over mqtt from openhab (even if it is via console or whatever), than you are the rock star! 🙂
    Thank you @dakipro for your feedback!
    I've updated the jar-file above. It is now possible to autodiscover a gateway if the corresponding broker is connected to OpenHab2.
    At first glance the smarthome-mqtt and the (old) openhab-mqtt seem to work together, I've had no problem configuring both in the same instance. Of course this means we need mqtt.cfg AND org.eclipse.smarthome.mqtt.cfg.
    Yeah, FOTA support would definatly be nice to have, but I'm not yet using it in my MySensors environment, so I first need to figure out how it works. 🙂
  • That is great, I've been a bit inactive with mysensors (moving and family and things) but it should be now possible to ask gateway to present all nodes (ask nodes to present themselves) and add them as things/items?
    I personally prefer to have items configured in the files, but having them autodetected via mqtt and added trough paperUi is definitely an awesome feature, completes the integration via plugin and its functionality.
    I've played yesterday with MyController https://www.mysensors.org/controller/mycontroller and I've seen that it has support for all those things over mqtt (get items info, auto add them). It can also do FOTA over mqtt, something no other controller is capable of doing today (not even famous MySController that originally introduces FOTA). I am sure you can find some inspiration in MyController code about how it is done, when the time comes 🙂
    My plan was to use MyController only for maintenance and remote update of nodes, but unfortunately I wasn't able to set it up to work, got a bunch of exceptions when I tried to add nodes to it. I will try previous version, but if this would be supported in openhab, that would benefit both platforms, a LOT 🙂
  • First of all, I'd like to thank you for your contribution, it is greatly appreciated!
    Unfortunately, I could not get the binding to talk to my Mosquitto server, yet. I have installed the addon and configured my MySensors MQTT Gateway as described above. But when I start OpenHAB (the Docker container instantiated from "openhab/openhab:2.2.0-amd64-alpine" to be precise), this is what I get in the openhab.log file:
    2018-01-09 15:45:29.710 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
    2018-01-09 15:45:29.711 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki'
    2018-01-09 15:45:30.420 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: ineluki
    2018-01-09 15:45:30.471 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    And there is no "retry" after 10 seconds. At the same time this is and only this logged by Mosquitto:
    1515512709: Socket error on client openhab, disconnecting.
    1515512729: New connection from 172.19.0.5 on port 1883.
    Do you have any clue or hint what I might be doing wrong? I'm entirely new to OpenHAB, so please excuse if I'm missing something obvious.
    Hi @cgrf !
    Please post the content of "org.eclipse.smarthome.mqtt.cfg".
    My guess is: there is no connection between OpenHAB2 and Mosquitto. The binding is only using the connection, it is not in charge for establishment or reconnects.
    Please check that in org.eclipse.smarthome.mqtt.cfg :
    mosquitto.user=user
    and in the MQTT GW configuration (in OH2) the names are matching.
    In your case it should look like (or similar to):
    ineluki.url=tcp://172.19.0.5:1883
    ineluki.user=user
    ineluki.pwd=secret
    ineluki.retain=false
  • Hi @TimO,
    Thanks for your response! There is an incoming connection from OpenHAB to Mosquitto, I can see as much in the Mosquitto log. But that connection does not seem to succeed.
    This is the content of my mqtt.cfg:
    ineluki.url=tcp://192.168.5.2:1883
    ineluki.clientId=openhab
    ineluki.qos=2
    ineluki.retain=true
    That Mosquitto instance currently does not require users to authenticate.
    @cgrf
    Is there a log entry in OpenHAB that looks like this?
    [DEBUG] [.io.transport.mqtt.MqttService:155  ] - Starting MQTT Service...
    [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110733874326 and file store '/tmp/mosquitto'
    [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110762725063 and file store '/tmp/mosquitto'
    Depending on your log level there only may be the INFO line.
  • @TimO
    I have this INFO line, as included in my first post, that looks similar but not quite the same:
    The four lines from my first post are actually all lines I have in that log after the UI start-up messages.
    @cgrf said in openHAB 2.2 binding MQTT support:
    You're using the mqtt1 (openhab1-addon) to connect to the broker. The OpenHAB2 binding is based on the current (/upcoming) mqtt-transport implementation of ESH.
    My guess: the file org.eclipse.smarthome.mqtt.cfg is missing in /etc/openhab2/services and there only is a mqtt.cfg file. Just copy the mqtt.cfg file to org.eclipse.smarthome.mqtt.cfg (Same content, different name, different use).
    mqtt.cfg: mqtt1 binding, mqtt-transport, owntracks ...
    org.eclipse.smarthome.mqtt.cfg: ESH-MQTT and I'm only aware of my binding using it yet. But there are a few upcoming (mqtt generic, mqtt2 binding ..)
  • @timo said in openHAB 2.2 binding MQTT support:
    Excellent guess, that was my problem! My gateway is "online" now. It would have taken me forever to figure that out on my own, so thank you very much! (And yes, reading your first post now I realize that you said so.)
    Should OpenHAB be able to discover the sensors behind the gateway? Or do I need to configure them manually?
    @cgrf
    If you restart the node they should represent themself and will show up in the Inbox in PaperUI.
  • @TimO
    Ok, I've restarted the sensor multiple times now and I assume that it presents itself properly as it is discovered by other controllers (mycontroller.org, that is). But in OpenHAB's PaperUI it doesn't show up at all. There is a trace of it in the openhab.log though:
    2018-01-10 09:29:39.268 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR1
    2018-01-10 09:29:39.269 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR2
    2018-01-10 09:29:39.277 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR3
    2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR4
    2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR5
    2018-01-10 20:38:26.959 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR1
    2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR2
    2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR3
    2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR4
    2018-01-10 20:38:26.981 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR5
    2018-01-10 20:38:27.084 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR1
    2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR2
    2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR3
    2018-01-10 20:38:27.088 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR4
    2018-01-10 20:38:27.089 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR5
    2018-01-10 20:39:10.530 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
    2018-01-10 20:39:11.529 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
    2018-01-10 20:39:11.660 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
    2018-01-10 20:40:58.584 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
    2018-01-10 20:40:59.461 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
    2018-01-10 20:40:59.592 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
    While this is happening on MQTT:
    gateway1-out/3/255/0/0/17 2.1.1
    gateway1-out/3/255/3/0/6 0
    gateway1-out/3/255/3/0/11 Combined Climate Sensor
    gateway1-out/3/255/3/0/12 1.0.16
    gateway1-out/3/0/0/0/7 (null)
    gateway1-out/3/7/0/0/30 (null)
    gateway1-out/3/10/2/0/15 (null)
    gateway1-out/3/1/1/0/0 21.9
    gateway1-out/3/0/1/0/1 42
    gateway1-out/3/7/1/0/38 3.98
    gateway1-out/3/255/3/0/0 56
    Have you got another hint for me, maybe? It would be greatly appreciated.
  • Unfortunately, I'm still making no progress here. In the meantime I deleted the MQTT Gateway in the Paper UI and restarted the device to see what would happen. Now I'm seeing an error in openhab.log:
    2018-01-16 19:45:23.419 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki' to 'tcp://192.168.5.2:1883' with clientid openhab2 and file store '/openhab/userdata/tmp/ineluki'
    2018-01-16 19:45:29.680 [INFO ] [.transport.mqtt.MqttBrokerConnection] - MQTT connection to 'ineluki' was lost: MqttException
    2018-01-16 19:45:29.681 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
    org.eclipse.paho.client.mqttv3.MqttException: MqttException
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:176) [211:org.eclipse.paho.client.mqttv3:1.0.2]
            at java.lang.Thread.run(Thread.java:748) [?:?]
    Caused by: java.lang.NullPointerException
            at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:142) ~[?:?]
            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) ~[?:?]
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) ~[?:?]
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) ~[?:?]
            ... 1 more
    2018-01-16 19:45:29.709 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'ineluki' every 10000ms
    Does this give any clue on what's going wrong?
  • Ok, now I'm seeing items in my Inbox, after I changed my org.eclipse.smarthome.mqtt.cfg from
    ineluki.qos=2
    ineluki.retain=true
    to
    #ineluki.qos=2
  • OK, n00b questions again:
    1. where to place the binding-jar and do I have to do something with the jar-file?
    2. no services directory exists in /etc. Create it?
    3. any other things to install? Fresh PaperUI-OpenHab installation so far.
      My system:RpiZero/Scratch+Mosquitto.
    @masmat
    1. /usr/share/openhab2/addons/
    2. Thank you for the hint, I've pointed to the wrong directory, it's: /etc/openhab2/services
    3. For additional Informations please have a look at the wiki: https://github.com/tobof/openhab2-addons/wiki
    @cgrf Thank you for the hint! At the moment I don't have an explanation for that behaviour.
  • @timo I still cant find mqtt.cfg OR org.eclipse.smarthome.mqtt.cfg. I looked thru the Github stuff but didn't see it.
    Any ideas where to locate either of these files? I assume they have more lines than those four on display in the example.
    Thanks. Sorry I'm still a tool with OH2
    @masmat As far as I know .cfg files are only the config files fpr your installed addons and are located in the service directory (see TimO's post above). And they indeed only contain the settings you want to use, which can be 4 lines only. Depends on the addon
  • @lastsamurai I kinda figured that. From the first post I understood that the MQTT binding (binding-mqtt1 - 1.11.0) did not need to be installed. mqtt.cfg -file does come from that. So far I haven't installed it, but if that's where the mqtt.cfg file should come from then I'll do that next.
    Just dont want to have addon on top of addon if they're redundant.
    @masmat Just create the org.eclipse.smarthome.mqtt.cfg file. It's not created automatically. mqtt.cfg is not needed for the binding.
  • @timo Alright!! MQTT Gateway Online. Thanks for your patience. Hopefully this thread will help future hopefuls.
    Now, I'm gonna activate some nodes and see what happens.
  • Well, this joy lasted almost 24h...until I unplugged and moved the set-up.
    Now Mosquitto-service wont start "Status 11/SEGV"...went nuts looking for that.
    Moved Mosquitto to another machine, but now mysgw-service "failed to connect".
    Any ideas why Mosquitto went status11 after reboot?
    Why wont mysgw connect to another Mosquitto IP? does the port 1883 need to be configured as well?
    My configure-line: --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=192.168.0.52 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=????? —-my-mqtt-password=???????
  • @TimO The MySonsors Binding didn't find any things for me. 😕
    My /etc/openhab2/services/org.eclipse.smarthome.mqtt.cfg
    broker.url=tcp://localhost:1883
    broker.clientId=openhabianpi
    broker.user=*private*
    broker.pwd=*private*
    My /etc/mosquitto/mosquitto.conf
    persistence true
    password_file /etc/mosquitto/passwd
    allow_anonymous false
    My /var/log/mosquitto/mosquitto.log
    1516918990: mosquitto version 1.4.10 (build date Mon, 29 May 2017 13:43:29 +0100) starting
    1516918990: Config loaded from /etc/mosquitto/mosquitto.conf.
    1516918990: Opening ipv4 listen socket on port 1883.
    1516918990: Opening ipv6 listen socket on port 1883.
    1516919015: New connection from x.x.x.29 on port 1883.
    1516919015: New client connected from x.x.x.29 as MQTT_Terrassen_Beleuchtung (c1, k15, u'openhabian').
    1516919044: New connection from 127.0.0.1 on port 1883.
    1516919044: New client connected from 127.0.0.1 as openhabianpi (c1, k60, u'openhabian').
    1516920798: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
    MQTT_Terrassen_Beleuchtung is the thing to find.
    My /var/log/openhab2/openhab.log
    2018-01-26 00:15:23.079 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
    2018-01-26 00:15:25.437 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
    2018-01-26 00:15:28.660 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to 51.5032,7.0073, Time zone set to Europe/Berlin
    2018-01-26 00:15:31.505 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'broker' to 'tcp://localhost:1883' with clientid openhabianpi and file store '/var/lib/openhab2/tmp/broker'
    2018-01-26 00:15:31.642 [WARN ] [rthome.io.transport.mqtt.MqttService] - MqttBroker start failed: Persistenz wird bereits verwendet
    org.eclipse.smarthome.io.transport.mqtt.MqttException: Persistenz wird bereits verwendet
            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:572) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
            at org.eclipse.smarthome.io.transport.mqtt.MqttService.modified(MqttService.java:145) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
            at org.eclipse.smarthome.io.transport.mqtt.MqttService.activate(MqttService.java:157) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
            at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
            at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
            at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
            at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
            at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
            at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
            at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
            at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
            at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
            at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
            at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
            at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
            at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
            at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
            at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
            at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:799) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:743) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
            at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
            at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
            at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
            at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
            at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
            at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
            at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
            at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
            at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
            at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
    Caused by: org.eclipse.paho.client.mqttv3.MqttPersistenceException: Persistenz wird bereits verwendet
            at org.eclipse.paho.client.mqttv3.persist.MqttDefaultFilePersistence.open(MqttDefaultFilePersistence.java:112) ~[?:?]
            at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:286) ~[?:?]
            at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:167) ~[?:?]
            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:570) ~[?:?]
            ... 118 more
    2018-01-26 00:15:32.456 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://x.x.x.30:8080
    2018-01-26 00:15:32.465 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://x.x.x.30:8443
    2018-01-26 00:15:52.506 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
    2018-01-26 00:16:01.849 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
    2018-01-26 00:16:01.999 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
    2018-01-26 00:16:02.291 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
    2018-01-26 00:16:02.816 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
    2018-01-26 00:16:02.819 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
    2018-01-26 00:16:02.822 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
    2018-01-26 00:16:05.597 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
    2018-01-26 00:16:06.390 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
    Have you any idea to fix this?
  • Hi @TimO ,
    after doing clean install of OH and the ESH mqtt binding per the original post above, the mqqt service ran properly (no errors in the debug log). After installing the mysensors binding, I start seing mysensors topics come in, but then following exception is thrown
    2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 message=PUBLISH qos:1 msgId:1 retained:true dup:false topic:"mysgw-out/1/0/1/0/97" payload:[hex:33392e38 utf8:"39.8" length:4]
    2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 token=org.eclipse.paho.client.mqttv3.MqttToken@e71260 message=SUBACK msgId 1 granted Qos 1
    2018-02-06 20:01:10.677 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: new msg avail, notify workAvailable
    2018-02-06 20:01:10.678 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: wait for new work or for space in the inflight window
    2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsReceiver] - paho167001634703924: network read message
    2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: call messageArrived key=1 topic=mysgw-out/1/0/1/0/97
    2018-02-06 20:01:10.680 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=1
    2018-02-06 20:01:10.681 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=28
    2018-02-06 20:01:10.681 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: callback threw exception
            at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:140) [233:org.openhab.binding.mysensors:2.2.0.201712141227]
            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) [232:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) [231:org.eclipse.paho.client.mqttv3:1.0.2]
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) [231:org.eclipse.paho.client.mqttv3:1.0.2]
    2018-02-06 20:01:10.683 [DEBUG] [o.client.mqttv3.internal.ClientComms] - paho167001634703924: state=DISCONNECTING
    Any idea what I'm doing wrong?
    UPDATE:
    For what it's worth, I found the trigger for the error. In fact, the mqtt messages the binding received were (for whatever reason) retained messages of the mosquitto broker. After removing the mosquitto presistence file
    sudo service mosquitto stop
    sudo rm /var/lib/mosquitto/mosquitto.db
    sudo service mosquitto start
    it now seems to work o.k. - Hope this might help others who come across this thread.
    @jjk Thank you for reporting back!
  • @timo, another effect I noticed is that the mysensor binding seems a bit sensitive to updates in the things and item files. I got new errors every time I added a thing to the things file or modified the items file. After rebooting OH those erros were gone and the things properly included. Stopping the mysensors binding (bundle:stop) before adding/changing things or items and restarting it afterwards works without a problem.
  • hi,
    first I would say thanks for the binding. Generally I got it working, but I build a special sensor for my district heating counter. It has two sensors in one node, power and watermeter. The power sensor also sends messages for value types VAR1-5. Unfortunately these value seem to have a problem. I see them in the mosquitto broker but in openhab I can't see them. In the logging there are some warnings concerning these values.
    Is it a known problem?
    thanks and best regards
    Joachim
    @jogant please enable debug output with log:set DEBUG org.openhab.binding.mysensors and post the debug output here. I'll look at it.
  • @timo I enabled debugging and could see that all mqtt messages are received correct. I had a problem with caching through jsondb. I deleted some things and links and now everything is fine. So nothing wrong in the binding. Thanks for your helpful hint.
  • Hi everyone. Since my last I reinstalled everything. I went back to Raspbian Jessie to get Mosquitto working properly. Full reinstall of MySensors mqtt gw and Openhab2 and binding.
    I have one sensor built that will not connect to the gw and I seem to be having problems on the gw as well.
    Quick specs: Rpi W, jessie, nrf24.
    I'm pretty new to Rpi as gateway, so I'm having little difficulty with finding debug-logs etc as well.
    Here's what my configuration was:
    ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-signing=password --my-signing-password=123456
    2018-02-19 16:56:15.280 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto' to 'tcp://127.0.0.1:1883' with clientid paho108561372416048 and file store '/var/lib/openhab2/tmp/mosquitto'
    2018-02-19 16:56:15.406 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto' to 'tcp://127.0.0.1:1883' with clientid paho108561583416206 and file store '/var/lib/openhab2/tmp/mosquitto'
    ......keeps repeating
    1519052215: Socket error on client <unknown>, disconnecting.
    1519052215: New connection from 127.0.0.1 on port 1883.
    1519052225: New connection from 127.0.0.1 on port 1883.
    ....keeps repeating
    systemctl status mysgw.service
    Feb 18 10:27:44 GwMqOH2 mysgw[359]: connect: Connection refused
    Feb 18 10:27:44 GwMqOH2 mysgw[359]: failed to connect
    ...repeating
    when I run mysgw -d:
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.1-alpha
    mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.1-alpha
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: GWT:RMQ:MQTT RECONNECT
    mysgw: connected to 127.0.0.1
    mysgw: GWT:RMQ:MQTT CONNECTED
    mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Any ideas? Where should I start?
    Sorry for flooding, the code-block is not working for some reason....
  • @TimO after installing a (simple) sketch on a new node with the mysensors 2.2 library, I noticed frequent exceptions in the openhab logfile. It took me a while to figure out why, but it seems the issue is linked to new messages the ne mysensors library is sending in relation to smartsleep (type 32 and 33). I was able to reproduce the exceptions with manually generated mqtt messages. Below is the openhab log filtered for MySensorsMQTT
    2018-02-21 13:43:23.232 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:43:23.478 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysgw-out/151/4/1/0/0, Message: 2.4
    2018-02-21 13:43:23.480 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 151/4/1/0/0
    2018-02-21 13:43:23.481 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 151;4;1;0;0;2.4
    2018-02-21 13:43:23.665 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysgw-out/151/3/1/0/4, Message: 1013
    2018-02-21 13:43:23.666 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 151/3/1/0/4
    2018-02-21 13:43:23.668 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 151;3;1;0;4;1013
    2018-02-21 13:43:28.499 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysgw-out/151/255/3/0/22, Message: 13830390
    2018-02-21 13:43:28.501 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 151/255/3/0/22
    2018-02-21 13:43:28.503 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 151;255;3;0;22;13830390
    2018-02-21 13:43:33.234 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:43:43.236 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:43:53.238 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:44:03.240 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:44:13.242 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:44:23.244 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    2018-02-21 13:44:23.579 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysgw-out/43/255/3/0/33, Message: 300000
    2018-02-21 13:44:23.581 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 43/255/3/0/33
    2018-02-21 13:44:23.589 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
    	at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:140) ~[?:?]
    2018-02-21 13:44:33.247 [TRACE] [rotocol.mqtt.MySensorsMqttConnection] - Bridge is connected, connection skipped
    Currently, the only workaround seems to be to avoid smartsleep or compile the nodes with the 2.1.1 library.
  • @timo Re: openHAB 2.2 binding MQTT support
    Hi @TimO. I'm lost. Should I install
    or the 2.3.0-SNAPSHOT?
    I'm using mqtt gateway.
    It doesn't seem to startup with either one.
    @guillermo-schimmel Don't use the old jar.
    Use the Eclipse marketplace to install the binding or use the one linked in the wiki. They both point to the same and current jar.
    Don't forget to fulfill the dependencies either by installing the features in the karaf console or by installing the new mqtt binding and the serial binding.
    https://github.com/tobof/openhab2-addons/wiki/Installation
  • @timo Thank you very much. I don't now how to use the marketplace, will research right now.
    I have followed your instructions, but you link to the 2.3.0-SNAPSHOT. Perhaps you would like to correct that.
    Thanks again
  • 22
  • 19
22
