Repeater node crashes
    I mounted sensors on an Arduino pro mini 3.3v, radio nrf24 managing a DHT22, a 1Wire 18b20 and a door contact under interruption. Everything is working very well.
    On this basis, I created a repeater (#define MY_REPEATER_FEATURE) by replacing the Delay () statement with Wait (). The repeater crashes during the Wait () statement, but interrupts still work. I turned off the interrupt and the repeater does not crash anymore.
    Do you have an idea
    Thank you for your answers.
  • In addition to my previous post:
    I use the MySensors 2.1.1 library and I tested with 2.2.0 rc2. same result.
    IDE 1.8.0
    I also noticed that the led pin 13 is off on the sensors and adding (#define MY_REPEATER_FEATURE), the led remains on.
  • Thank you for adding some more info, now there's only the code missing if you follwo the instructions here.
    Sounds like you did not do a "non-blocking-loop()" but used some kind of wait/delay functionality instead. I'd highly recommend using non-blocking methods for repeaters and not use wait/delay (with the exeption of short periodes needed for the DS18B20 to do their measurements).
  • The code is inspired by MySensors sketchs :
      MM Octobre 2017
     1.5 remplacé Delay() par Wait()
         Update intervalle 5 min
         readDHT() : wait(1100)
    // Enable debug prints
    #define MY_NODE_ID 111
    #define SketchName "Buanderie"
    #define SketchVer "1.5"
    #include <MyConfig.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 5
    #define DHT_DATA_PIN 3
    #define DOOR_PIN 2
    #define DHTTYPE DHT22
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5 * 60000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_DOOR 2
    #define CHILD_ID_1WIRE 3
    float lastTemp;
    float lastHum;
    float lastTemp1W;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    uint8_t nNoUpdatesTemp1W;
    MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
    MyMessage msg1W(CHILD_ID_1WIRE, V_TEMP);
    DHT dht;
    DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
    DeviceAddress insideThermometer;
      sendSketchInfo(SketchName, SketchVer);
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_DOOR, S_DOOR);
      present(CHILD_ID_1WIRE, S_TEMP);
      analogReference(INTERNAL);
      wait(500);
      pinMode(DOOR_PIN, INPUT_PULLUP);
      digitalWrite(DOOR_PIN, HIGH);
      oneWire.reset_search();
      // assigns the first address found to insideThermometer
      if (!oneWire.search(insideThermometer)) {
      sensors.setResolution(insideThermometer, 9);
      attachInterrupt(digitalPinToInterrupt(DOOR_PIN), DoorMoving, CHANGE);
    void DoorMoving() {
        Serial.println("------> Door");
        send(msgDoor.set(digitalRead(DOOR_PIN) == HIGH ? 1 : 0));
    void read1Wire() {
      sensors.requestTemperatures(); // Send the command to get temperatures
      float tempC = sensors.getTempC(insideThermometer);
      if (tempC != lastTemp1W  && tempC > -50.00 && tempC != 85.00 || nNoUpdatesTemp1W == FORCE_UPDATE_N_READS) {
        send(msg1W.set(tempC, 1));
        lastTemp1W = tempC;
        nNoUpdatesTemp1W = 0;
    #ifdef MY_DEBUG
        Serial.print("Temp 1Wire C: "); Serial.println(tempC);
      } else
        nNoUpdatesTemp1W++;
    void readDHT() {
      dht.readSensor(true);
      wait(1100);
      if (isnan(temperature)) {
        Serial.println("T DHT!");
        lastTemp = temperature;
        // Reset no updates counter
        nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
        Serial.print("T: "); Serial.println(temperature);
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        Serial.println("H DHT");
        lastHum = humidity;
        nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
        Serial.print("H: "); Serial.println(humidity);
        nNoUpdatesHum++;
      Serial.println("------> readDHT");
      readDHT();
      Serial.println("------> read1Wire");
      read1Wire();
      Serial.println("------> wait");
      wait(UPDATE_INTERVAL);
  • @mimaret Well organised code, congratulation.
    Imo, you should just change your loop() (btw: that's really cool, just "straight forward") to be non-blocking. The principle is described here: https://www.arduino.cc/en/tutorial/BlinkWithoutDelay.
    If you need a working implementation of the blink-without-delay function within MySensors, see the https://www.mysensors.org/build/pulse_power example.
    Additional remarks: As mysensors may use interrupts in the future, (if possible) connecting Pin2 to nRF interrupt, door sensor to Pin3 and use one of the remaining Pins to connect the DHT may be a good idea.
  • @rejoe2 Thank you for your reply.
    I seemed to have read that for a repeater it was necessary to replace delay () by wait (). . .
    I will adapt my program according to your recommendations and keep you informed.
    @mimaret could you post the debug output from before and during the crash?
    What you're doing should work. The debug output usually gives useful info on why things don't work the way they are supposed to.
    Also, check the power problem flowchart on the page @rejoe2 linked earlier. PA_MAX puts very high stress on the power supply. My guess is that this is related to insufficient power stability.
  • @mfalkvidd Thank you for your reply.
    I do not think about power problem. The power supply can deliver 1A and I mounted a capacitor of 470 uF on the 3.3v and a 47 uF close to the radio module. I had doubts about hardware and I set up a second repeater.
    On the first repeater, radio module nrf24L01 + PA + LNA. On the second repeater, radio module nrf24L01 +. Same problem.
    When the repeater crashes, the interrupt is executed again. The led pin 13 that I do not manage is ON during normal operation and goes OFF when the repeater crashes.
    I noticed that by disabling the interrupt (// attachInterrupt (....), the repeater does not crash.
    I will look how to check the state of memory, stack, etc.
    I also include the debug output and I do not see anything particular.
  • OOPS :
    19820560 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    ------> Door
    ------> Door
    19825700 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    ------> Door
    19826745 !TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:0
    ------> Door
    19826745 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:0
    19826747 TSF:MSG:READ,255-255-255,s=255,c=7,t=255,pt=7,l=25,sg=1: 0
    19826755 !TSF:MSG:LEN,7!=32
    ------> readDHT
    20105310 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.4
    H: 42.40
    ------> read1Wire
    20105426
    ------> readDHT
    20405309 TSF:MSG:SEND,111-111-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.8
    T: 21.80
    20405323 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:42.1
    H: 42.10
    ------> read1Wire
    20405440
    20700045 TSF:SAN:OK
    ------> readDHT
    20705310 TSF:MSG:SEND,111-111-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.9
    H: 41.90
    ------> read1Wire
    20705427
    ------> Door
    20707352 !TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:1
    ------> Door
    20707352 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:0
    ------> Door
    20723965 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    ------> Door
    20725862 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    ------> Door
    <------------------------------------CRASH-----------------
    ------> Door
    20729143 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
    ------> Door
    20730232 TSF:MSG:SEND,111-111-0-0,s=2,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    ------> Door
    @mimaret could you describe what you mean ny "crash"? I thought you meant that the node rebooted, but I see now that my assumption was wrong.
  • In fact, the node no longer executes the program and the only solution is to restart it with a reset or switch off the power supply.
    @mimaret strange. The (re)start should be visible in the debug output. Did you cut it out?
  • There is no restart. Only the interrupt executes when I open the door contact. The Loop () does not continue. I did not cut anything, I just added the crash line as soon as the program stopped.
    @mimaret thanks for explaining.
    I think the problem lies in calling send from within the interrupt handler. Interrupt handlers are supposed to execute very quickly. Usually they just set a flag that there is work to be done, and return.
    From https://learn.adafruit.com/multi-tasking-the-arduino-part-2/interrupt-etiquette
    Code in the ISR should not call anything that requires interrupts to be active (e.g. delay() or anything that uses the i2c bus). This will result in hanging your program.
    From the debug output, send fails. That means the node must have tried to send, waited for acknowledgement until timeout, tried to send again and waited and so on until the max number of attempts is reached. That's way too much time to spend inside an interrupt handler. And the radio use
    Try to only set a variable inside the interrupt handler, and perform the send from inside loop instead.
    Also see https://arduino.stackexchange.com/questions/30968/how-do-interrupts-work-on-the-arduino-uno-and-similar-boards/30969
  • A big thank you for your contribution. I modified the program according to your proposals. Everything is working. I am attaching you the pieces of code relating to the door contact.
    My problem is solved.
      DoorChange = 1;
      LastDoor = 0;
    void DoorMoving() {
        DoorChange = 1;
    void readDoor() {
      if (DoorChange) {
        boolean Door = (digitalRead(DOOR_PIN));
        if (Door != LastDoor) {
          send(msgDoor.set((Door) == HIGH ? 1 : 0));
          LastDoor = Door;
          DoorChange = 0;
      readDoor();
      if (currentMillis - previousMillis >= UPDATE_INTERVAL) {
        readDHT();
        read1Wire();
    @mimaret great work! Thanks for posting your solution.
  • 15
  • 24
