Removing sensors from mysensors.json
  • I am running hassio 0.62.1 on a Pi with serial gateway
    All running fine.
    When I remove a sensor from Mysensors.json and save the file the sensor reappears after opening the file again!
    Can't get it removed permanently.
    I am using the hassio samba share to edit the mysensors.json file in the windows editor.
    The sensor I want to remove is NOT connected to the gateway.
    Any tip?
    I'm using hassbian, and to edit .json, prior to that, I just stop homassistant , edit file, save file and start homeassistant service again... all working..
  • 6
  • 17
