esp8266 gateway doesn't connect to mqtt broker
  • Hi, I'm using ESP8266 mqtt client gateway to connect to my controller and I use cloud mqtt service. controller has connected to the broker but esp8266 doesn't connect. even it doesn't connect to the wifi and it was a access point and I've followed a topic to add a code for turn off access point. this is my code for gateway:
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "***********"
    #define MY_MQTT_PASSWORD "**************"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "*****************"
    #define MY_ESP8266_PASSWORD "******************"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    #define MY_IP_ADDRESS 192,168,178,87
    //MQTT broker if using URL instead of ip address.
    #define MY_CONTROLLER_URL_ADDRESS "m21.cloudmqtt.com"
    #define MY_PORT 11262
    #include <ESP8266WiFi.h>
    and I get this in serial:
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 4
    cnt
    271 TSM:FAIL:DIS
    289 TSF:TDI:TSL
    connected with Shatel, channel 1
    dhcp client start...
    ip:192.168.1.6,mask:255.255.255.0,gw:192.168.1.1
    pm open,type:2 0
    10306 TSM:FAIL:RE-INIT
    10330 TSM:INIT
    10351 !TSM:INIT:TSP FAIL
    10377 TSM:FAIL:CNT=2
    10399 TSM:FAIL:DIS
    10419 TSF:TDI:TSL
    anyone knows how to fix it?
    @tsunami see if removing
    helps. I think this define is only meant to be used when not using MY_CONTROLLER_URL_ADDRESS (but I am not entirely sure).
    If that doesn't help, take a look at https://github.com/mysensors/MySensors/issues/926
    It seems like the ESP8266 gateway will be unable to use DNS when using static IP configuration. In my experimental branch I have added DNS support, but it is not reliable and needs more work. You could try to use an IP address instead of m21.cloudmqtt.com - not sure if it helps but it could be worth trying.
  • @mfalkvidd said in esp8266 gateway doesn't connect to mqtt broker:
    thanks alot everything works good now and gatewat has connected to the mqtt broker. but i can't connect it to the domiticz. domoticz topics are: domoticz/in/mymqtt
    but for gateway is different and i can't change for domoticz.
    https://forum.mysensors.org/topic/5618/domoticz-now-supports-the-mysensors-mqtt-gateway/ might be useful
    thank you I've done it and works great. but I found it if node is offline and I put switch on or off in controller it works but when node get connect to the controller it doesn't update switch state. how to fix it?
    @tsunami program the sketch to fetch status at boot. See the first example at https://www.mysensors.org/build/dimmer for how it can be done.
  • 24
