I'm not good at programming
  • Hello I'm not good at programming I mix two motion light my times his block is what a he can look at thank
    #define MY_RF24_CE_PIN A0
    #define MY_REPEATER_FEATURE
    #define MOTION_PIN 4
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SSR_A_ID 1 // Id of the sensor child
    #define MOTION_ID 2
    // Sleep time between reads (in milliseconds)
    unsigned long SLEEP_TIME = 100000;
    unsigned long T = 1;
    const int buttonPinA = 3;
    const int relayPinA = 5;
    int oldValueA = 0;
    bool stateA = false;
    bool lastMotion;
    Bounce debouncerA = Bounce();
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage motion_msg(MOTION_ID, V_TRIPPED);
    pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
    pinMode(relayPinA, OUTPUT);
    // After setting up the buttons, setup debouncer
    debouncerA.attach(buttonPinA);
    debouncerA.interval(5);
    digitalWrite(relayPinA, RELAY_OFF);
    // Define the motion sensor pin for digital input
    pinMode(MOTION_PIN, INPUT);
    /*--------------------- Added these lines for toggle switch-------------------------*/
    oldValueA = digitalRead(buttonPinA); // set oldValueA to the current status of the toggle switch
    send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
    sendSketchInfo("Mains Controller", "1.0");
    present(SSR_A_ID, S_LIGHT);
    // Register the motion sensor to the gateway
    present(MOTION_ID, S_MOTION);
    debouncerA.update();
    // Get the update value
    int valueA = debouncerA.read();
    if (valueA != oldValueA) {
    send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
    oldValueA = valueA;
    // Read digital motion value
    bool motion = digitalRead(MOTION_PIN) == HIGH;
    if (motion != lastMotion) {
    // Send tripped value to gw
    send(motion_msg.set(motion ? "1" : "0"));
    lastMotion = motion;
    T++;
    if (T > SLEEP_TIME) {
    T = 1;
    Serial.print("Motion: ");
    Serial.println(motion);
    switch (message.sensor) {
      case 1:
        stateA = message.getBool();
        digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
    Serial.print("from node:");
    Serial.println(message.sender);
    So, if I get this right..
    You want a motion detection sensor? And you tried turning a button node into a motion sensing node by having the motion sensor acting as the button?
    And you want two motion sensors?
    Or do you want to be able to turn on the light and/or sense motion at the same time? You code seems to imply the second.
    So.. what is the problem? Is it not working?
    This is odd:
    A solid sate relay (SSR) is an actuator, not a sensor. Did you try to turn that into a second sensor?
    If you want to have two motion sensors connected, you should probably have two of these:
    (or set the child ID and use one message holder)
    Here you are writing to a relay though:
    Hmmm, you're counting the loops? Up to 100.000? Hmm, I wonder how long that takes in milliseconds. In any case, your node will have trouble receiving any command form the gateway if it's sleeping.
    I'm not sure how that debouncer works.
    What's this all about?
    Why the +4? If you only have one relay, why not just point to that pin directly?
  • thank you for your response
    light with classic toggle switch
    and i have add pir sensor
    for what I ask to correct
      I have to thank you
    Can you explain the problem a bit more?
  • in domoticz he sends his state of light
    it is he and turn on or off
