Clock with temperature, humidity and CO2 level sensors
    My bedside alarm clock recently got broken so I decided to build up one by myself.
    The prototype looks like that:
    • 1: arduino pro mini 3.3v
    • 2: RFM69 radio
    • 3: MQ135 sensor to measure CO2 level
    • 4: 20k/10k voltage divider to connect the MQ AO pin to an analog pin of the arduino (the MQ sensor runs at 5v, the arduino at 3.3v so we need to "scale" the output)
    • 5: DS3231 RTC so when the power goes down the node will be able to restore its clock even without requesting time to the controller
    • 6: SHT21 sensor for temperature and humidity
    • 7: SSD1306 OLED display 128x64
    The "production" version looks like this:
    I'm again using the versatile EasyPCB from @sundberg84, here in the middle. The voltage divider has been soldered on the board, where battery measurement level is used to be placed. Of course Vin is not connected but instead it is used for MQ's AO pin connection.
    The SH21 and MQ sensors are just outside the box so to have accurate readings. The project is powered by 0.5€ USB ttl Chinese key which allows to power both the board (3.3v) and the MQ sensor (5v).
    I've also added a push button, hidden within the case which will request the time to the controller for the first initialization of the RTC.
    As for the code this is what I'm using based on NodeManager (with the latest SensorMQ code change not yet merged into the development branch):
     * MySensors node configuration
    // General settings
    #define SKETCH_NAME "Clock"
    #define SKETCH_VERSION "1.0"
    #define MY_NODE_ID 1
    // RFM69 radio settings
    #define MY_RADIO_RFM69
    //#define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_IS_RFM69HW
    #define MY_RFM69_NEW_DRIVER
     * NodeManager modules for supported sensors
    #define USE_SIGNAL
    #define USE_SHT21
    #define USE_INTERRUPT
    #define USE_MQ
    #define USE_SSD1306
     * NodeManager built-in features
    // Enable/disable NodeManager's features
    #define FEATURE_DEBUG OFF
    #define FEATURE_POWER_MANAGER OFF
    #define FEATURE_INTERRUPTS ON
    #define FEATURE_CONDITIONAL_REPORT OFF
    #define FEATURE_EEPROM OFF
    #define FEATURE_SLEEP OFF
    #define FEATURE_RECEIVE ON
    #define FEATURE_TIME ON
    #define FEATURE_RTC ON
    #define FEATURE_SD OFF
    #define FEATURE_HOOKING ON
     * Load NodeManager Library
    #include "NodeManagerLibrary.h"
    NodeManager node;
     * Add your sensors below
    // built-in sensors
    SensorSignal signal(node);
    // Attached sensors
    SensorSHT21 sht21(node);
    SensorMQ mq(node,A0);
    DisplaySSD1306 ssd1306(node);
    SensorInterrupt button(node,3);
     * Main Sketch
    void syncTime(Sensor* sensor) {
      // update the time with the controller
      node.syncTime();
      // update the display
      ssd1306.onLoop(ssd1306.children.get(1));
    // before
    void before() {
      Serial.begin(MY_BAUD_RATE);
      * Configure your sensors below
      // temperature/humidity sensor
      sht21.setReportIntervalMinutes(5);
      // gas sensor
      mq.setReportIntervalMinutes(5);
      mq.setRoValue(56842);
      mq.setCurveScalingFactor(38.35);
      mq.setCurveExponent(-2.74);
      // display
      ssd1306.setReportIntervalSeconds(30);
      // button
      button.setInitialValue(HIGH);
      button.setInterruptMode(FALLING);
      button.setInterruptHook(&syncTime);
      * Configure your sensors above
      node.before();
    // presentation
      node.presentation();
    // setup
      node.setup();
    // loop
      node.loop();
    #if FEATURE_RECEIVE == ON
    // receive
      node.receive(message);
    #if FEATURE_TIME == ON
    // receiveTime
      node.receiveTime(ts);
    To show on the display only the information relevant for this project, I had to override DisplaySSD1306 onLoop() function in this way:
    void DisplaySSD1306::onLoop(Child* child) {
      long timestamp = now()+60*60*2;
      _oled->setCursor(0,0);
      // print the current date
      _oled->setFont(X11fixed7x14);
      _oled->print(F("    "));
      if (day(timestamp) < 10) _oled->print(F("0"));
      _oled->print(day(timestamp));
      _oled->print(F("-"));
      if (month(timestamp) < 10) _oled->print(F("0"));
      _oled->print(month(timestamp));
      _oled->println(year(timestamp));
      // print the current time
      _oled->setFont(lcdnums12x16);
      _oled->set2X();
      if (hour(timestamp) < 10) _oled->print(F("0"));
      _oled->print(hour(timestamp));
      _oled->print(F(":"));
      if (minute(timestamp) < 10) _oled->print(F("0"));
      _oled->println(minute(timestamp));
      // print the sensors' data
      _oled->setFont(Adafruit5x7);
      _oled->set1X();
      _oled->println("");
      _oled->print(((ChildFloat*)_node->getChild(1))->getValueFloat());
      _oled->print(F("C "));
      _oled->print((int)((ChildFloat*)_node->getChild(2))->getValueFloat());
      _oled->print(F("% "));
      _oled->print(((ChildInt*)_node->getChild(3))->getValueInt());
      _oled->print(F("ppm"));
      _oled->clearToEOL();
    Finally some pictures of the project once finalized:
    And if you don't like a hot MQ sensor just aside your bed, or want a 3.3v sensor or even something which can run on battery (even if not recommended) , you can try using a CCS811 which is more expensive (€7) than a MQ sensor but not as expensive as many other digital sensors for detecting e.g. CO2 (https://www.aliexpress.com/item/CJMCU-811-CCS811-Carbon-Monoxide-CO-VOCs-Air-Quality-Numerical-Gas-Sensor-Module/32846769569.html).
    There's a library on Adafruit. I'd not say it is that accurate for measurements but for sure way better than the MQ.
  • @user2684 looks very nice. Can you share wiring.
    @pihome sure will do!
  • hi
    I have this error
    'class SensorMQ' has no member named 'setCurveScalingFactor'
    @zrom69 sorry for the delay! This is because I was using the development version of NodeManager available at https://github.com/mysensors/NodeManager/tree/development where SensorMQ implementation has been completely reviewed. Sorry for not making it clear!
