openHAB and NRF24 without gateway attachments
  • Hello!
    Im new to all of this stuff but i already like what smart house opportunities can give to everyone. 😉
    And heres my story begins: As ESP8266 is power-hungry i went for NRF24. I successfully added NRF24 to my rasp and done everything to have communication with my NRF24 node following this guide , and node code this guide.
    So my question:
    How can i forward or post NRF24 nodes sensor status to MQTT server? As in used guide - door status.
    As i already read there are ways with Ethernet Shield W5100 but is it possible to forward info without gateway?
    My setup:
    • Raspberry pi 3 with Openhab & MQTT server & NRF24L01 & MySensors branch
    • NRF24L01 node (Arduino Nano)
    • couple senors connected to ESP8266 sending info to MQTT server
    Hi @mārtiņš-prūsis, welcome to the MySensors forum. Great to have youhere 🙂
    From what you are describing, it sounds like you already have both a raspberry pi gateway and esp8266 gateways using MQTT. The nodes send data to a gateway, which forward the messages through MQTT. Could you describe the difference between the mqtt you have and the mqtt you want?
  • Correct, i have MQTT communication between rapsberry and esp8266 nodes without problems, but recently i added NRF24 module to raspberry and created NRF24 arduino node. There is communication between raspberry and NRF24 arduino node through air (see picture). Last five rows messaging door state sg=0:"1;0" (0=open, 1=closed), so i want to have this door state forwarded to MQTT server. Maybe later on info from PIR or temperature sensors. 0_1542137444741_nrf.JPG
    How can i forward this received state to MQTT?
    @mārtiņš-prūsis thanks for clarifying. Just follow the instructions in the MQTT section on https://www.mysensors.org/build/raspberry
  • I done all steps only i skipped gateway type. I did MQTT gateway type and made a new gateway and vola, its working.
    Thank you!
  • 22
  • 135
  • 19
  • 7
