Relay / Motion Multisensor
  • Hi, I thought I would share my newest project with you Guys.
    This project is a multisensory, containing a relay and a motion sensor.
    The project is powered by 230V and has a small 5V power supply in the box as well.
    What I used:
    HC-SR501 PIR
    1 channel relay
    Arduino Pro Mini 5V
    NRF24L01+
    AMS1117 5V-3.3V Step Down Module
    1A 5V Power Supply from Ebay
    Code:
    MultiSensor_Relay_Motion.ino
    Pictures:
    The Multisensor is used in my basement room, and turns on the light if there is motion, when I enter the room.
    The logic is made by PLEG on a Vera3
  • Very nice.
    Nice! But you should probably isolate the high voltage parts a bit. We wouldn't want a MySensors related fire started.
    +1 on that one!
  • @ServiceXp @hek Here just a little update
    I have now glued all parts to the box, and added a plastic cover over the part with 230V
    so now nothing should be able to touch and it looks a bit nicer.
  • Hello
    i want to make a similar project but i want to add a dht22 with this sketch
    have you a sketch with a dht because i have a problem with mine
    thanks
  • @madmax good idea I have some DHT22 lying around. But I have not tried making a multi sensor with them.
    Have You tried the skech from the site, I tried it and it work on mine?
  • @Dalhoj i use this and it's working fine
    i want to include another relay and it's ok for me
    #include <SimpleTimer.h>
    #define CHILD_ID_HUM 1
    #define CHILD_ID_TEMP 2
    #define CHILD_ID_MOTION 3
    #define CHILD_ID_RELAY 4
    #define HUMIDITY_SENSOR_DIGITAL_PIN 19
    #define MOTION_SENSOR_DIGITAL_PIN 3
    #define INTERRUPT MOTION_SENSOR_DIGITAL_PIN-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define RELAY  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds) - 10mins
    DHT dht;
    SimpleTimer timer;
    float lastTemp;
    float lastHum;
    boolean lastTripped;
    boolean metric = true;
    MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
      gw.sendSketchInfo("HumTempRelayMotion", "1.0");
      gw.present(CHILD_ID_MOTION, S_MOTION);
      gw.present(CHILD_ID_RELAY, S_LIGHT);
      pinMode(RELAY, OUTPUT);
      digitalWrite(RELAY, gw.loadState(RELAY)?RELAY_OFF:RELAY_ON);
      //Serial.begin(9600);
      timer.setInterval(30000, getMeasure);
      timer.run();
      boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
      if (tripped != lastTripped) {
        lastTripped = tripped;
        Serial.print("M: ");
        Serial.println(tripped);
        gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      if (message.type==V_LIGHT) {
         // Change relay state
         digitalWrite(message.sensor-CHILD_ID_RELAY+RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
         // Store state in eeprom
    void getMeasure() {
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
  • hello, just looking to use this project to try and set up a motion triggered sprinkler to scare away some rabbits eating my plants and grass. Thinking of the relay triggering a 24v valve, my only problem is how do I extend the time the replay is closed, thinking I only need to spray water for 5-10secs... any tips would be greatly appreciated.
    thanks
  • Guys, I would like to use this sketch with dht but on Uno and with 8 relays and use analog pins...
    Should I Just change part:
    #define RELAY 8
    To
    #define RELAY A0
    This project got me inspired, so I made this:
    Same PIR, no relay on this board yet. To test the principle (and sketch) I used a red LED. The kicker is that I can send an SMS ("LED ON") to this board to switch on the LED, and another (... "LED OFF" tada !) to switch it back off. I can ask "STAT?" and it sends me an SMS with the status of all analog/digital ports. And when the PIR "fires" I get a prowl message via Domoticz. Call me a kid, blame the glas of wine I just had, but this is super fun !!!!!
  • @Ashley-Savage
    ah mis read the code... build circuit and sorted my timer via my vera with a timer to switch off relay after 5 secs...
  • Has anyone the code for mysensors 2.1?
    It doesnt work for me in 2.1 ๐Ÿ˜•
    Please help
  • I need your help pls ๐Ÿ˜•
