๐ฌ NRF2RFM69
RFM69 NSS is equivalent of NRF24 CSN
DIO0 act as interrupt line, and is attached in accordance with connecting the radio.
the pin above DIO0 is actually the reset line for the RFM69 module.. Which might come in handy, if you want to do a hardware reset at some point in time
So why isn't it working then? Did I fry the radio?
Could you have added it to a 5V arduino? RFM is not 5V tolerant, so that could fry the radio..
No, I used it only on the raspberry
New update: I used the module on the EasyPCB, nrf24 version, from @sundberg84 and recompiled the sketch to use the rfm69 and it is able to initialize the radio. So there must be something wrong with the compiled gateway on the RPI as it should be a direct swap from a NRF24. I am moving to the RPI thread
PS Now it seems to be working... I haven't changed anything.... must have been a bad connection then
mysgw: MCO:BGN:INIT CP=RPNG---- mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: Listening for connections on 0.0.0.0:5003 mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1
Hi all,
which size of cap should be used on this board and is it possible to connect a SMA Antenna ?Many thanks
Markus
use a 4.7uF capacitor, or there about..
There is no pads for a SMA connector, but you could attach one with a pigtail..
@tbowmo Thanks for the Information... One stupid question about the SMA conenctor Is it enough to connect only the Antenna Output conenction or must GND also conencted...?
You can just solder the antenna only on pcb. I use a coil spring type
just one more question... I have on the Gateway a RFM69HW and a node with a RFM69W module. In the Gateway Sketch is the HW type enabled
#define MY_RFM69_FREQUENCY RF69_868MHZ #define MY_IS_RFM69HW
But there is no comunication from the node... I use Mysensors 2.1.1.
Any idea?
What gateway is that? I'd suggest to try mysensors 2.2 development
@gohan It at the Moment only a test. So I have one EasyPCB NRF board with FTDI as Gateway and another EasyPCB board with DHT22 Sensor attached as Node. On both is a 4,7uF electrolytic condensator attached Close to the NRF socket. Both boards are at the Moment with RFM69W 868. The sensor node is battey powered.
Get latest 2.2 library and use new rfm69 driver. Did you remember to close the IRQ contact in the easypcb?
@gohan Oh Sh* must check this... I've tried it yesterday on both devices the 2.2 Dev. But will Keep ypu informed...
Don't find the jumperfor the IRQ on the Rev 9 board. can you please post a Picture. Seems that this one is definitly not closed...
--> Edit... found it in the documentation but still the same.
Think the next Point to check for me are the antennas...
I'd suggest to buy the coil spring antennas for your frequency, they are cheap and compact.
in principle there is traffic between node and Gateway..
159631 !TSM:FPAR:NO REPLY 159637 TSM:FPAR 169848 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 171868 !TSM:FPAR:NO REPLY 171874 TSM:FPAR 179087 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 181106 !TSM:FPAR:FAIL 181112 TSM:FAIL:CNT=4 181118 TSM:FAIL:DIS 181123 TSF:TDI:TSL 191131 TSM:FAIL:RE-INIT 191137 TSM:INIT 191143 TSM:INIT:TSP OK 191150 TSM:INIT:STATID=10 191158 TSF:SID:OK,ID=10 191164 TSM:FPAR 198377 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 200396 !TSM:FPAR:NO REPLY 200402 TSM:FPAR 207616 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 209635 !TSM:FPAR:NO REPLY 209641 TSM:FPAR 216854 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 218873 !TSM:FPAR:NO REPLY 218880 TSM:FPAR 226093 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 228112 !TSM:FPAR:FAIL 228118 TSM:FAIL:CNT=5 228124 TSM:FAIL:DIS 228128 TSF:TDI:TSL 238135 TSM:FAIL:RE-INIT 238141 TSM:INIT 238147 TSM:INIT:TSP OK 238153 TSM:INIT:STATID=10 238161 TSF:SID:OK,ID=10 238168 TSM:FPAR 248385 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 250404 !TSM:FPAR:NO REPLY 250411 TSM:FPAR 257624 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 259643 !TSM:FPAR:NO REPLY 259649 TSM:FPAR 269731 TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 271751 !TSM:FPAR:NO REPLY 271757 TSM:FPAR
0;255;3;0;9;189196 TSF:PNG:SEND,TO=0 0;255;3;0;9;189206 TSF:CKU:OK 0;255;3;0;9;189214 TSF:MSG:GWL OK 0;255;3;0;9;191236 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 0;255;3;0;9;244555 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;244574 TSF:MSG:BC 0;255;3;0;9;244582 TSF:MSG:FPAR REQ,ID=10 0;255;3;0;9;244594 TSF:PNG:SEND,TO=0 0;255;3;0;9;244604 TSF:CKU:OK 0;255;3;0;9;244613 TSF:MSG:GWL OK 0;255;3;0;9;257744 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 0;255;3;0;9;269957 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;269977 TSF:MSG:BC 0;255;3;0;9;269985 TSF:MSG:FPAR REQ,ID=10 0;255;3;0;9;269996 TSF:PNG:SEND,TO=0 0;255;3;0;9;270006 TSF:CKU:OK 0;255;3;0;9;270014 TSF:MSG:GWL OK 0;255;3;0;9;281585 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 0;255;3;0;9;289732 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;289753 TSF:MSG:BC 0;255;3;0;9;289761 TSF:MSG:FPAR REQ,ID=10 0;255;3;0;9;289771 TSF:PNG:SEND,TO=0 0;255;3;0;9;289781 TSF:CKU:OK 0;255;3;0;9;289789 TSF:MSG:GWL OK 0;255;3;0;9;297015 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 0;255;3;0;9;306757 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;306776 TSF:MSG:BC 0;255;3;0;9;306784 TSF:MSG:FPAR REQ,ID=10 0;255;3;0;9;306796 TSF:PNG:SEND,TO=0 0;255;3;0;9;306806 TSF:CKU:OK 0;255;3;0;9;306814 TSF:MSG:GWL OK 0;255;3;0;9;316682 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0 0;255;3;0;9;322084 TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0: 0;255;3;0;9;322103 TSF:MSG:BC 0;255;3;0;9;322111 TSF:MSG:FPAR REQ,ID=10 0;255;3;0;9;322123 TSF:PNG:SEND,TO=0 0;255;3;0;9;322131 TSF:CKU:OK 0;255;3;0;9;322142 TSF:MSG:GWL OK 0;255;3;0;9;333180 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
That's either the node not receiving or the gateway having problems when sending
@gohan any idea what else I can do/check ?
@Markus. You have an RF issue. Typically for nrf24l01+ I'd use a different power supply or a different module.
Are you sure both modules are set to the same channel and frequency? What antennas are you using?
Do you have HW modules?
@alexsh1 I use at the Moment RFm69W 868 modules not NRF. Because the RFMs are mounted on the NRF connector on an EasyPCB. I use at the Moment single wire antennas with a lenght of 8,3 cm.
@Markus and channel and freq? are they the same in your sketch?
@alexsh1 should be, becaus ist not defined explicit in the Sketch. By Default in the MYS Lib 2.2 dev is it 868 mhz. And when i try to define the frequency in the Sketch. Like
I get the error message.'RF69_868MHZ' was not declared in this scope
@Markus. try RFM69_868MHZ (RF69 -> RFM69)
@mfalkvidd you are right... Ist now added in the GW and node Sketch, but still the same Problem.
I think at the end will it be a power problem. It seems that the sensor node powered with 2x AA cells can not handle the Radio on TX/RX. The same on the Gateway site which is also a Easy PBB powered fom the FTDI Connector connected to USB. The question now is how can i fix this power Problems ? Or more, how can i make sure that this is definitly not the reason.
Try bigger capacitor
@gohan 10uF electrolyt cap direct on the radios already tierd beside the 4,7uF on the Radio socket.
@gohan ohhhh helllll... its working.. As usual.. the Problem was infront of the Monitor... So, two Problems. the first mistake i did was to use a HW module as Gateway. The power source was a FTDI adaptor which has only max Output current of 50mA (HW module Needs 120mA Minimum). The result was randomly reboot of the Gateway. The second and main Problem was the Jumper of the IRQ on the Easy PCB boards. I checked only the domumentation and there is the Jumper wrong descriped. So i placed the Jumper wrong. I have corrected this now on my two test boards and use a W module on the Gateway.. now its working
Many thanks for all the Patience...
Where is it wrong described?
@gohan the arrow goes to the Jumper close to the cap on the NRF socket.
[link text]https://www.openhardware.io/view/4/EasyNewbie-PCB-for-MySensors(link url)
But the other Jumper isthe right one . Well, could be also wrong interpreted frommy site, however ist now working and the range is also fine so far...
you are right, the picture has an error, but the pcb has the right labels. Maybe @sundberg84 may fix the picture
@gohan yes and i didn't checked the PCB Label...shit happends
@Markus. Sorry, this is because it was changed from Rev 8 to Rev 9 and the location of the IRQ jumper is changed. I will try to update to REV 9 pictures only.
I've added the panel design to dirtypcb's store.. So just order it from the following link
http://dirtypcbs.com/view.php?share=16378&accesskey=4e199dccdf623eab0c90fddbc4786f80
I ordered PCBs from dirtypcbs via the link above. But just now I got this message from dirtypcb:
"Problems Drill holes don't match with the solder pads."
Do you know why?Thanks for your help!
I got them from seeed studio, no problem
@gohan But then I guess you didn't use the panel version?
From what I can see it looks like the drill file in the panel version is missing the drill holes on the board itself. It looks like it only contains the drill holes between the cards? I am not sure, and has little experience with drill files and pcb design, but it looks like this when I open the drill file (and the profile layer, .gml-file) in gerbview in kicad:
From what I can see the drill holes on the boards itself is missing, but I guess there are others that have ordered this panel version from dirtypcbs, so I find it strange that there should be an error.
That sounds weird, as I haven't touched the files at dirtypcb for the last couple of years.. And I got a notification from dirtypcb the other day, that another set was successfully ordered..
Perhaps it's a fluke in their system?
@tbowmo
OK. Then I guess the files are OK, and that the error is in dirtypcb's system. Thanks!
But what about the drill file on your github. Why am I not seeing the drill holes on the card itself when I am opening it? Shouldn't they be a part of the drill file?
probably.. Can't remember much of what I did 2 years ago
@tbowmo
That's understandableI received this email from dirtypcbs today:
"Thanks for ordering!
So here is the thing- please see attached screenshots. The only drill holes in this Gerber are the mouse bits(the pink layer, photo 001). The light green layer(photo 002) is the top solder mask layer. The problem is that no drills are specified in the solder pads or circles, which means that if we make the board exactly how the gerber is designed, all of the light green parts are solder pads and there WILL NOT be drill holes at the bottom of the solder pads, which seems wrong.
I checked this gerber in our system, and I couldn't find any other orders that included it. Even if we have made this board for other people, it doesn't mean that this back-and-forth didn't happen before. I suggest that you write the designer and forward this message and screenshot to him, so that he can update the design in case you order again in the future.
I am also going to include a screenshot of the whole design, and I hope that will be clear to you what the problem is."The attachments in the email are basically showing the same as the image I attached in my post above.
I don't find any design files for the panel layout in your git repository, just gerber files. I guess you don't have them anymore?
I will try to make a new panel layout myself, if I not succeed, I will just order single boards.
If I remember right I used this gerber panelizer to place 3 of the normal gerber files on one board. You could do the same again, and re-create a panel.
@tbowmo
Thanks! I have looked at it, and it seems easy to create a panel with that tool. I will look more into it later today or tomorrow.
I ordered this board trough pcbway on 6th december and still didn't received it. I event did not received any confirmation email accept paypal payment confirmation. Did any one here ordered those boards with pcbway ? Do they send any information about the order ?
@rozpruwacz, I'll PM you the shipping details.
What value should be the C1 SMD ? I don't have kicad, so I can't open the file. Just saw it the 3d sketch and realized I have to order some SMDs...
@joaoabs i use 10u and ir works ok.
It's not a specific value.. I just added the footprint, so that it was available, if someone wanted to add a capacitor.
First of all, thank you to the creator of this very convenient PCB.
I ordered 10 of those but got confused when I tried to make a RPi 3 gateway and Arduino node.In the "Connecting the Radio" guide, the instructions are to connect NRF's IRQ pin to Arduino No 2 pin.
This is where RFM's D100 pin is supposed to be connected. As far as I could tell from the PCB this is correct, as RFM's D100 pin is broken out to where NRF's IRQ pin is.However, in the "Building a Raspberry Pi Gateway" guide, it says to connect RFM's D100 pin to RPi's pin 22, which is where NRF's CE pin is supposed to be connected, not IRQ. As for IRQ, it says it's "optional", but if you do connect it, this should be to RPi's pin 15.
So, if you connect the radio to the RPi following the NRF instructions, you get a different circuit than if you connect it following the RFM instructions (and using the pin matching you get from the "connecting the radio" guide). When I did the former, the gateway wasn't working, but when I did the latter, it worked.
I don't know why this difference exists, but I think it's important to point out for anyone wanting to use the PCB with an RPi.
@symos IRQ is not utilised for nrf24l01+ in MySensors. There is a provision for future, but just ignore IRQ for now.
You can enable interrupt usage for NRF24, depending on your hardware and needs.
see the #MY_RF24_IRQ_PIN define, which is used around here
Or the documentation at https://www.mysensors.org/apidocs/group__RF24SettingGrpPub.html#ga23c9926f77307bf1b0263432232e4f4a
@tbowmo I wonder what would be an example of using it?!
I knew it would be supported at a certain time in the future but I did not realise it it supported already.
On a related note, if anyone is trying to get the NRF2RFM69 board or similar working with the awesome Sensebender Gateway and W5100 Ethernet board, hereโs what I had to do today as far as the CS and IRQ defines are concerned.
[FYI: Iโm coming back to MySensors after a long hiatus and am in the process of updating (some from v1.3!) all my gateways and sensors...]
Aside from the usual radio selection, I had use the new driver and point the RFM69 NSS and IRQ pins at the nRF CS and IRQ nets. Also, if you want to, you can point the RFM69 RESET pin at the nRF CE net:
#define MY_RFM69_NEW_DRIVER #define MY_RF69_RESET 34 // Note: Should be MY_RFM69_RST_PIN, but this didnโt work. #define MY_RFM69_IRQ_PIN 31 #define MY_RFM69_IRQ_NUM digitalPinToInterrupt(MY_RFM69_IRQ_PIN) #define MY_RFM69_CS_PIN 29 #define MY_DEBUG_VERBOSE_RFM69 // Note: Only if you want to check the pins, RSSI, etc.
Hope that helps someone.
You do know that there is solder pads for RFM69HW on the back of the gateway, right? And the board defs for the gateway are configured to use those pins for the RFM69 by default.
Adding image for reference
@alexsh1 Thanks, though I'm not sure you understood exactly what I'm saying.
If I connect the radio to the RPi 3 following the NRF instructions and using the NRF2RFM69 adapter, it is NOT working.For it to work, I MUST connect the "IRQ" pin of the NRF2RFM69 (which corresponds to RFM's D100 pin) to RPi's pin 22 (which is where CE is supposed to go, according to instructions) and leave CE unconnected.
So if someone is using the NRF2RFM69 adapter and tries to connect the radio to the RPi 3 as if it were an NRF, it won't work. I think this is confusing and that's why I posted it.
Yes @tbowmo, I saw the solder pads on the back - although thanks for the reminder (and image @mfalkvidd)!
Iโm not using those (yet) since I didnโt want to โpermanentlyโ attach one of my โpreciousโ RFM69HWs to it whilst Iโm tinkering with all these lovely new radios you now support. RFM95 next I hope, after checking out the FOTA and signing! You guys have really done great work!
I also wanted to range-test with a few different externally mounted antennas I had lying around and so I combined pads for a surface mount U.fl and edge SMA on my own NRF2RFM69.
Not a great deal of room around the SBGWโs pin breakout (P1) for a helical - although I really respect the design choices - so I figure Iโll probably breakout those pins to pigtail an SMA.
But this is getting a bit off-topic Re: NRF2RFM69 and probably better suited to the Sensebender Gateway thread.
Bringing it back on-topic a little:
Do you know if there is a version of this board that is pad-compatible with the C-versions of these HopeRF RFM69s before I go searching? (Since I believe the C-versions are also pad-compatible with the RFM95sโฆ)
@acb
Hi @acb and others, regarding "Do you know if there is a version of this board that is pad-compatible with the C-versions of these HopeRF RFM69s before I go searching? (Since I believe the C-versions are also pad-compatible with the RFM95sโฆ)" - did you find any alternative?
I'm in the same boat looking for an adapter from NRF24 to the footprint of RFM69*C = RFM95/96.
Thanks, Joost
