TX RX ERR - LED for Sensors
    is there a simple way to get these LEDs working on Sensors? Like the LEDs on the Serial Gateway but as said... for Sensors.
    Many Thanks
    Petz
    @Meister_Petz
    you want to transmit to a node an instruction to turn on/off an LED... or you want to show at the node that it is in TX/RX process?
  • @BulldogLowell
    I would like the node to show that it is in TX/RX process.
    There isn't any super-easy way of hooking in this in the sketch. You would have to subclass the MySensors class or add the functionality you want directly.
  • Nevertheless Thanks!
    That's how I solved it:
    If message sent, blink LED
    If message received, blink LED
    That's my code for 1, 2 or 3 LEDs:
        // YOUR DEFINITIONS
        // Definitions
        // POWER RX TX LED
        // Definitions
             // choose one Mode
               // All with one LED => LEDMode = 1
               // POWER seperate   => LEDMode = 2
               // only TX and RX   => LEDMode = 3
               // 3 seperate LEDS  => LEDMode = 4
               // for a power LED, I would connect a LED between GND and VCC in general.
             const int LEDMode = 3; // 2 3 4 (0 is off)
             // Mode 1
             #define LEDPwrRXTXPin 4
             // Mode 2
             #define LEDPwrPin1 3
             #define LEDRXTXPin 4
             // Mode 3
             #define LEDRXPin 3
             #define LEDTXPin 4
             // Mode 4
             #define LEDPwrPin2 19
             #define LEDRXPin 3
             #define LEDTXPin 4
             int blinkRX = 0;
             int blinkTX = 0;
        // YOUR CODE
        // VOID SETUP
        // POWER RX TX LED
        // VOID SETUP
             if (LEDMode == 1){
               pinMode(LEDPwrRXTXPin, OUTPUT);
             if (LEDMode == 2){
               pinMode(LEDPwrPin1, OUTPUT);
               pinMode(LEDRXTXPin, OUTPUT);
             if (LEDMode == 3){
               pinMode(LEDRXPin, OUTPUT);
               pinMode(LEDTXPin, OUTPUT);
             if (LEDMode == 4){
               pinMode(LEDPwrPin2, OUTPUT);
        // POWER RX TX LED
        // VOID LOOP
        if (LEDMode == 1){
          digitalWrite(LEDPwrRXTXPin,HIGH);
          if (blinkTX == 1){
            digitalWrite(LEDPwrRXTXPin, LOW); // invert blink because power is already on
            delay(40);
            digitalWrite(LEDPwrRXTXPin, HIGH);
            blinkTX = 0;
        if (LEDMode == 2){
          digitalWrite(LEDPwrPin1,HIGH);
          digitalWrite(LEDRXTXPin,LOW);
          if (blinkTX == 1){
            digitalWrite(LEDRXTXPin, HIGH);
            delay(40);
            digitalWrite(LEDRXTXPin, LOW);
            blinkTX = 0;
        if (LEDMode == 3){
          digitalWrite(LEDRXPin,LOW);
          digitalWrite(LEDTXPin,LOW);
          if (blinkTX == 1){
            digitalWrite(LEDTXPin, HIGH);
            delay(40);
            digitalWrite(LEDTXPin, LOW);
            blinkTX = 0;
        if (LEDMode == 4){
          digitalWrite(LEDPwrPin2,HIGH);
          if (blinkTX == 1){
            delay(40);
            blinkTX = 0;
        // YOUR CODE
        // VOID LOOP
        // !!! at  gw.send(msg.set...); there also needs to be a - blinkTX = 1; - !!!
        // POWER RX TX LED
        // INCOMING MESSAGE
        if (LEDMode == 1){
          delay(40);
        if (LEDMode == 2){
          digitalWrite(LEDRXTXPin,HIGH);
          delay(40);
        if (LEDMode == 3){
          digitalWrite(LEDRXPin, HIGH);
          delay(40);
          digitalWrite(LEDRXPin, LOW);
        if (LEDMode == 4){
            delay(40);
        // YOUR CODE
        // INCOMING MESSAGE
    Still missing is the ERROR. Is there a way to ask if there was a "fail" within the message?
  • +1 for the RX/TX LED support in code for node! 🙂
    ++ to include the new RGB implementation along with this mod!
  • now without delay() but with LEDs are on for a number of loops (millis()) didn't work smoothly)
        // DEFINITIONS
          // POWER RX TX LED
          // Definitions
               // choose one Mode
                 // RX TX combined, no PWR LED  => LEDMode = 5
               const int LEDMode = 5; // 2 3 4 5 (0 is off)
               // does not need to be modified
               // Mode 1
               // Mode 2
               // Mode 3
               #define LEDRXPin 3
               #define LEDTXPin 4
               // Mode 4
               #define LEDPwrPin2 14
               #define LEDRXPin2 3
               #define LEDTXPin2 4
               // Mode 5
               #define LEDRXTXPin2 4
               int blinkRX = 0;
               int blinkTX = 0;
               int blinkLoopTX = 0;
               int blinkOffTX = 500; // number of Loops until blink is off
               int blinkLoopRX = 0;
               int blinkOffRX = 500; // number of Loops until blink is off
        // VOID SETUP - VOID SETUP - VOID SETUP - VOID SETUP - VOID SETUP
          // POWER RX TX LED
          // VOID SETUP
               if (LEDMode == 1){
               if (LEDMode == 2){
               if (LEDMode == 3){
               if (LEDMode == 4){
               // no POWERLEd only RX TX combined => LEDMode = 5
               if (LEDMode == 5){
                 pinMode(LEDRXTXPin2, OUTPUT);
        // VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP - VOID LOOP
          // POWER RX TX LED
          // VOID LOOP
          if (LEDMode == 1){
            if (blinkTX == 0 && blinkRX == 0){digitalWrite(LEDPwrRXTXPin,HIGH);}
            if (blinkTX == 1 || blinkRX == 1){
              if (blinkLoopTX >= blinkOffTX){ blinkTX = 0; blinkRX = 0; blinkLoopTX = 0;}
              blinkLoopTX++;
          if (LEDMode == 2){
            if (blinkTX == 0 && blinkRX == 0){digitalWrite(LEDRXTXPin,LOW);}
              blinkLoopTX++;
          if (LEDMode == 3){
            if (blinkTX == 0){digitalWrite(LEDTXPin,LOW);}
            if (blinkTX == 1){
              if (blinkLoopTX >= blinkOffTX){ blinkTX = 0; blinkLoopTX = 0;}
              blinkLoopTX++;
            if (blinkRX == 0){digitalWrite(LEDRXPin,LOW);}
            if (blinkRX == 1){
              if (blinkLoopRX >= blinkOffRX){ blinkRX = 0; blinkLoopRX = 0;}
              blinkLoopRX++;
          if (LEDMode == 4){
            if (blinkTX == 0){digitalWrite(LEDTXPin2,LOW);}
            if (blinkTX == 1){
              digitalWrite(LEDTXPin2, HIGH);
              blinkLoopTX++;
            if (blinkRX == 0){digitalWrite(LEDRXPin2,LOW);}
            if (blinkRX == 1){
              digitalWrite(LEDRXPin2, HIGH);
              blinkLoopRX++;
          if (LEDMode == 5){
            if (blinkTX == 0 && blinkRX == 0){digitalWrite(LEDRXTXPin2,LOW);}
              digitalWrite(LEDRXTXPin2, HIGH);
              blinkLoopTX++;
          // YOUR CODE
          // VOID LOOP
        // VOID INCOMING MESSAGE - VOID INCOMING MESSAGE - VOID INCOMING MESSAGE
          // POWER RX TX LED
          // INCOMING MESSAGE
          blinkRX = 1;
          // YOUR CODE
          // INCOMING MESSAGE
    I use something similar mainly to show if messages are received. For this purpose I created a small class/ library to blink and time LED's. The class uses a similar syntax as Bounce2 for assigning and handling LED's attached to output pins. LedFlash.
    A code example:
    https://codebender.cc/sketch:85200
  • 87
  • 7
  • 7
