rboard - Cheap relay/radio/arduino board ~$10
    Finally got the email they are on the way....will report in when ive tested them,
    And they just arrived... 6days ..not too bad!
    Now to test!
    Well that was easy....
    Loaded up the RelayActuator sketch, changed the relay pin to 4.
    It joined Vera as it should, and after providing it a 5V powersource the relay clicks on and off as commanded!
    Now loaded up the Garage Door sketch , choosing A0 for the switch and D4 for the relay and again works straight away!
    I note they also have a header for 433Mhz module and according to the schematic, the pads could be used for 5v,GND, and D3 - so could be used for another sensor such as Dallas temp....or ultrasonic/IR..anything!
    Great buy for $10
    ftp://imall.iteadstudio.com/Mainboard/IM140704001_mini_Rboard/SCH_IM140704001_MiniRboard.pdf
    Good price but a pity you still need an external 5 Volts supply...
    Yep no getting away from the need for power! A mains version would be great, but although it only adds a few $ in electronics, getting all the approvals adds $$$. But for DIY'ers adding a phone powersupply is cheap and reasonably compact.
    Yeah it seems like a really nice board but it could have had access to a few more digital pins on the board.
    Is it really only A0 and D3 that can be accessed other then the relay?
    Looks like. Surprising that folks don't at least put a few more pins on solderable holes on boards like this, where you could put a pin or solder a wire - seems easy and takes little space.
  • Hey! my first post 🙂
    I read about these boards here a week or so ago, and order one to play with! Just waiting on my Vera to arrive and I'm gonna start playing 🙂
  • it is possible to add hardware button to the setup and control the relay.
    @derrij
    Yes, here in an example:
    https://codebender.cc/sketch:47534
    @hek there's no code visible on android.....
    @Yveaux
    I can see it on my chrome/android.
    Update: The stock browser also works.
    @hek now it is working... Did you change anything?
    @Yveaux
    Nope.
  • Which board do I choose when uploading a sketch to this?
    It's all good, I found a website which stated what it was compatible with So I'm moving on 🙂
    Now I am just trying to work out how to connect a switch to the A0 pin. There are two pins so is the switch just bridging the two? Sorry, I really am trying to learn this stuff.
  • Ok, looks like I am slowly getting there 🙂
    fyi I tried playing around with the above sketch, but it's a no go as Codebender tells me <Bounce2.h> is missing.
    @Homer
    The link above has been updated to point the MySensors codebender location (where Bounce2 is available).
    Thanks mate. I'll give it ago again soon.
    I used one of these boards for a multi sensor recently.... Temp/Motion and Relay actuator.
    Turns out to be a very tidy solution !
    I'm using the A0 pins connected to a ds18b20 . This is really cute in that the sensor is connected in parasite mode meaning i only need two wires. To do this all you need to do is join pin 1 and 3 to GND and the middle signal wire goes to the A0 ( which is used as D14 ). The rboard also has a 10k resistor from the A0 connection to 3.3v. It works just fine!!
    Then for the PIR, im using the readily available RF433 connections to provide D3, 3.3v and GND. The cute trick here is that even though these PIR's are designed for 5v, they run great on 3,3 v too...you just need to connect it differently! See in the photo where the yellow wire which is the 3.3 v vcc supply connects on the PIR sensor.. Genius!!!
    See here for background on this:
    http://techgurka.blogspot.com.au/2013/05/cheap-pyroelectric-infrared-pir-motion.html
    Do this, feed it 5v ( as relay needs 5v) and you have a tidy little multisensor.
    Here's some pics:
    full sketch here https://codebender.cc/sketch:61919
    @gregl I've now my rboard, but I have no Foca, so I used my programmer I matched against the pins on the board.
    I choose mini pro 3V3 in the arduino ide but impossible to sync .... is there something I am missing ?
    Also, do you change something on initialization as for the 4 switch version ?
    thanks,
    Hi @epierre - I do have a foca and i program as Nano with Atmega328.
    What do you mean "change something on initialization as for the 4 switch version" ?? iirc i also just programmed that as a Nano. is this what you mean??
    Cheers,
    Greg
    @gregl so there is no way to program it without a foca ? ;-(
    I meant about the gw initialization, for the 4 switch rboard you used other parameters, so my wuestion was wether I could use it with default values or extra values.
    @epierre - you dont need the foca programmer... any programmer should work as long as you wire correctly - you could even use another arduino.
    http://www.instructables.com/id/Arduino-Examples-2-Use-an-Arduino-as-a-FTDI-Progr/
    • make sure you only feed it 3.3v via the programming socket...!
    For the 4 relay board the CE/CS pins are wired differently to the defaults used by MySensors sketches (9,10) , so you need to tell mysensors library to use (8,9) as this is how they are wired on the Rboard - see the doco ftp://imall.iteadstudio.com/IM120618001_RBoard/DS_IM120618001_RBoard.pdf
    @gregl nope, I tried and it failed... this is why I asked. One pin is missing, another has another use... I've ordered the foca and I will see.
    Regarding your PIR Wiring on the picture, you added a 1DS80 right ? I mistakenly thought it was the yellow one ...
    @epierre - ill see if i can get it to program with another arduino...i dont think there is anything special about the foca....
    so the PIR is wired as such that the VCC provided by the rboard mini ( 3.3) connects to a jumper pin and supplies the PIR module there.... then the PIR quite happliy operates on 3.3!
    The ds18b20 is connected to the "A0" pin headers hidden under the radio - i just bent them over. On the ds18b20 connect pin 1 and 3 to GND and pin 2 to the A0 ... easy!!
    @epierre Hello,
    I received the foca and ... RX and TX have to be inverted (RX to TX, and TX to RX), the answer is so simple...
    @hek a suggestion, would there be a knowledge management section about wiring a special platform to use mysensors ? I think about the Mega or the iboard ? that would be very useful, rather than going through many forum pages ?
  • Woohoo! After stuffing around with a sketch for my Ethernet Gateway that was never complete to begin with, I have got that working and then made my first sensor using this board!!! L-)
  • I've decided to try and do a little more with this board. I initially programmed it to only operate the relay on and off to activate the garage door opener, but it's time for me to push myself lol and do more 🙂
    The problem with how I have it now, is that my Vera 3 doesn't know if the door is open or closed. I was going to add a tilt sensor to the board and have that mounted to the actual door, which I think would mean that it could send a message reporting if it is closed or not. But then I started thinking about the example above which included a switch.
    So using the relay and the switch to operate the garage door, would that then work to keep Vera 3 in the loop as to whether or not the door is open or closed?
    If I don't get a response soon, I'll just build it and see what happens 🙂
    Thanks in advance for everyones help! I have already learnt a lot from this site 🙂
    Hi Dean,
    Rather than use a tilt sensor and mount the mini rboard to the moving door, why not just use a reed switch? then you can mount the rboard next to your door controller and run cheap speaker wire to a reed switch and the magnet attached to the moving door..
    Here is a sketch i use for my garage door using reed switch
    https://codebender.cc/sketch:44296
  • Thanks for the tips @gregl!
    I am trying to see if I can build this with the sensors that I have, so I can keep my wife happy. So far I am not doing a very good job lol
    One of my problems is not knowing which pin is what on this board. I see that you stated above that A0 is D14; how do you find this out?
    The other thing I was wondering about is this: If I set up this sensor and garage door to only ever open/close using either my controller sending the message or me pressing a button, then do I even need a reed switch to determine what state the door is in? Can the sketch keep count of the state?
    I like your suggested sketch above; in fact I like both examples, and would like to merge the two. The one above with the motion sensor- I don't need that bit, but I like having a temp sensor. What I would like to do is have the temp sensor and instead of the motion sensor I have a switch. Does that sound possible?
    My wife has given me the rest of the night off, so I'll see what I can come up with 🙂
  • I just worked out where you get the info regarding what pin is what 🙂 you have a link in the sketch 🙂
  • lol scratch that last comment.... I have been looking at that PDF and I have no idea how the A0 pin is D14.
  • Ok what I have done is uploaded the sketch that is exampled above which has the temp sensor. Instead of the motion sensor, I will use a switch, and I'll connect the two wires to the 433 module spot; one wire to GND, and the other to DATA. I am hoping that this will mean that when the switch is activated it will operate.
    Gonna go test 🙂
  • lol I ended up with a board that now malfunctions sometimes 🙂 For some reason the relay began to turn on and off repeatedly, then it stopped working altogether, and now it seems to be working as it should... when my son was running past me the other day which lead to the board falling on the ground, it must have fixed whatever the problem is! In any case, I won't be using that relay for anything too important. I have it in my garage now; it opens and closes the garage door, has a motion sensor and tells me if someone goes into the garage, and it is also sending me the temperature outside. I am happy 🙂
    So now I want to use another one of these boards to turn a light on, but I want to also have a separate switch which will operate through the board. So basically I am going to use the Garagedoor sketch mentioned above, which is the same as the "Relay with button actuator". I understand what pins I need to assign, but I am a little confused as to how I need to wire up the switch. Am I just completing a circuit, or am I supplying power as the trigger?
    What voltage are you giving the board?
    I think i recall having an issue when i was giving it just 5v... i think at 6/7v the issue went away....
    @Dean So let me get this straight,, You are using that board to "opens and closes the garage door, has a motion sensor and tells me if someone goes into the garage, and it is also sending me the temperature outside . I am happy ...." and you don't consider that contrary to "I won't be using that relay for anything too important." ?
    Did I understand you correctly?
  • @gregl thanks for your suggestion, that thought actually did come to mind when I was trying to troubleshoot what was going on. I had been using 4 AA batteries to power it, and they had been used for quite some time, so I ended up locating an old mobile phone charger and used that to power it. The board has been working reliably every since, but I am reluctant to use the board for anything important.
    @ServiceXp yes you heard me right 🙂 the board is currently doing all those things, but I'm not depending on it. My wife is home all the time, so if for some reason the relay decides to open the garage, she will hear it and close out back up. It is my first sensor, and even though it hasn't come together as well as all of you, in still proud of myself for building it, and even though it's reliability is debatable, I like the idea of keeping it running at this stage because it gives me a smile every time I open the Vera dashboard 🙂
    So can anyone give me a little hand with how the actual switch part is supposed to work? Thanks in advance 🙂
    @Dean Does the build make it difficult to swap out the rboard, and demote that temperamental rboard to say controlling a light? For me, I consider the garage door to be one of those more important functions.. 🙂
    You will wire one side of the switch to the pin you want to use on the rboard and the other side to GND. When you initialize the pin, you need to use INPUT_PULLUP eg: pinMode(buttonPin, INPUT_PULLUP)
    http://arduino.cc/en/Reference/pinMode
    Hope that helps...
    You will wire one side of the switch to the pin you want to use on the rboard and the other switch to GND. When you initialize the pin, you need to use INPUT_PULLUP eg: pinMode(buttonPin, INPUT_PULLUP)
    Hope that helps...
    Hi @ServiceXp , that is the exact info I was after! Thank you very much 🙂
    At present the build is just the board, radio and motion sensor all just wired up and sitting above the lightswitch in the garage. For me it was kind of a test to see if I could do this. Like I said, my wife is home all the time so there is no way the garage door will open without someone knowing. If the board keeps working as it is presently, then I'll feel more confident in using the board again somewhere else. But so far it is working very well, which I am very pleased about 🙂 But you're right, keeping a garage secure is something that is usually pretty important, the other thing is that there is no internal access into our home, so between that and my wife being home, personally I am ok with the present arrangement.
    Thanks again for your help!
  • Cool, this one is also interesting!
    http://imall.iteadstudio.com/im120618001.html
    I agree... I placed an order with them last and it arrived yesterday. I bought a few items including a couple more Mini Rboards, but I also bought what you linked. Not sure what I will do with it, but at that price I couldn't say no. 🙂
    ive had an rboard in production with mysensors for 6 months or so.... it hasnt missed a beat and caused me absolutely no issues!!!
    @gregl I wanted to try mine, but it seems it doesn't commute, have you a test script ?
    When I send the order:
    echo "9;0;1;1;2;1" >> /dev/ttyUSB0
    I see on the debug:
    read: 0-0-9 s=0,c=1,t=2,pt=0,l=1:1
    send: 9-9-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
    Incoming change for sensor:0, New status: 1
    But I don't hear the relay commute nor mesure a conductivity on the relay limits.
    any hint ?
    You may not have enough power to drive the relay...five it at least 6v
    . ...or the Wong pin in your sketch.
    @gregl right this was linked to a powering issue.
    :~$ echo "9;1;1;1;2;1" >> /dev/ttyUSB0
    :~$ echo "9;1;1;1;2;0" >> /dev/ttyUSB0
    what is strange is that it is the sensor 1 and not the 0, but the way the demo code is you have to do that...
    digitalWrite(message.sensor-1+RELAY_1,
    @hek sending a message would be good in http://www.mysensors.org/download/serial_api_14 in § serial communication example, it is missing...
  • Sorry about bumping an old thread...
    I am using one of these boards to make a relay and temp sensor. I am trying to use Gregl's example that is linked here and stored on Codebender. For the record, here it is:
    //This is Motion/Door & Temp Sensor with Relay
    //Hardware is Mini RBoard ftp://imall.iteadstudio.com/Mainboard/IM140704001_mini_Rboard/SCH_IM140704001_MiniRboard.pdf
    #include <OneWire.h>
    char sketch_name[] = "Multi Sensor";
    char sketch_ver[]  = "2014.11.15r1";
    #define MySensorTESTBED 0
    #if MySensorTESTBED == 1
    #define CLIENT_ID 9  // Sets MYSensors client id
    #define RADIO_CH 96  // Sets MYSensors to use Radio Channel 96
    #define RELAY 4   // Set 4 for mini rboard
    #define TRIGGER	3	// On Mini Rboard there is D3 (Interupt 1) available on the RX Module pins
    #if MySensorTESTBED == 0
    #define CLIENT_ID AUTO  // Sets MYSensors client id
    #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
    //Temp Sensor bits
    #define ONE_WIRE_BUS 14 // Pin where dallas sensor is connected - on Rboard this is A0(D14)
    DallasTemperature DallasSensors(&oneWire);
    float lastTemperature ;
    #define CHILD_ID_T1 3 //CHILD ID for relay
    //Relay Output bits
    #define CHILD_ID_R1 1 //CHILD ID for relay
    //Trigger Sensor Bits
    #define CHILD_ID_S1 2 //CHILD ID for Reed/Motion sensor
    boolean lastTripped = 0;
    MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
    MyMessage relayMsg(CHILD_ID_R1,V_LIGHT);
    MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
    	// Startup OneWire Temp Sensors
    	DallasSensors.begin();
    	gw.begin(incomingMessage, CLIENT_ID , false,AUTO,RF24_PA_MAX,RADIO_CH,RF24_250KBPS);
    	gw.sendSketchInfo(sketch_name, sketch_ver);
    	gw.present(CHILD_ID_R1, S_LIGHT);
    	gw.present(CHILD_ID_T1, S_TEMP);
    	gw.present(CHILD_ID_S1, S_MOTION);
    	pinMode(RELAY, OUTPUT);
    	pinMode(TRIGGER,INPUT_PULLUP);
    	//Ensure relay is off
    	digitalWrite(RELAY,RELAY_OFF); //turn relay off
    	// Check for motion change value
    		boolean tripped = digitalRead(TRIGGER) == HIGH;
    		if (lastTripped != tripped ) {
    			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
    			Serial.println("Tripped");
    			lastTripped=tripped;
    		DallasSensors.requestTemperatures();
    		float tempC = DallasSensors.getTempCByIndex(1);
    		if (lastTemperature != tempC && tempC != -127.00) {
    			gw.send(tempMsg.set(tempC,1));
    			lastTemperature=tempC;
    	if (message.type==V_LIGHT && !(message.isAck()) ) { // look for messages for the relay and that are not ACK messages
    		// Change relay state
    		digitalWrite(RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
    Just as the code stands, when I try to compile it, I get an error. First I got one because the Mysensors library had the last letter 's' missing, but even after I make that correction I can't get it to compile. This is the error that I get:
    Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
    In file included from C:\Users\Dean\Documents\Arduino\testingagain\testingagain.ino:7:0:
    C:\Users\Dean\Documents\Arduino\libraries\MySensors/MySensors.h:405:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    Multiple libraries were found for "MySensors.h"
    Used: C:\Users\Dean\Documents\Arduino\libraries\MySensors
    Not used: C:\Users\Dean\Documents\Arduino\libraries\MySensors-2.3.1
    Multiple libraries were found for "DallasTemperature.h"
    Used: C:\Users\Dean\Documents\Arduino\libraries\DallasTemperature
    Not used: C:\Users\Dean\Documents\Arduino\libraries\MAX31850_DallasTemp
    exit status 1
    Error compiling for board Arduino Duemilanove or Diecimila.
    I really don't know where to go to from here, because all I have done is tried to compile a working sketch so it should work, shouldn't it?
    Keen to hear back from someone who knows a lot more about this stuff than me! Thanks
    @homer that sketch was made for MySensors 1.x and needs to be converted to work for MySensors 2.x.
    Followthe guide at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x to convert it.
    Alternatively, remove MySensors 2 and install MySensors 1 instead.
  • @mfalkvidd said in rboard - Cheap relay/radio/arduino board ~$10:
    Thanks mate! I was thinking something like that might be the case, but I didn't know for sure.
    Thank you so much for pointing me in the right direction!!
  • I just wanted to say that I managed to upload a sketch and I have it working!
    I attempted to change the code so it was compatible but I gave that up and decided to merge two sketches. It was good fun, and I enjoyed learning!
    Could you share the sketch? Perhaps others will learn from it too?
  • @alowhum said in rboard - Cheap relay/radio/arduino board ~$10:
    Great idea! ☺
    Here it is
    // Setup Relay bits
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    // Setup Temperature bits
    #define ONE_WIRE_BUS 14 // Pin where dallase sensor is connected
    int numSensors = 0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage tempMsg(0, V_TEMP);
    void before()
      for (int sensor = 1, pin = RELAY_PIN; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
      sensors.begin();
      sendSketchInfo("Temp and Relay", "1.0");
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        present(i, S_TEMP);
          present(sensor, S_BINARY);
      wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
          send(tempMsg.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
      wait(SLEEP_TIME);
        digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
  • 87
  • 7
