Possible issue with plugin
  • Hi all
    Today I built the Candle Hub so I can learn and then interact with some cheap rf433 sensors. When I activated inclusion mode on the Gateway it found 2 sensors, but after Vera did all the things it needs to do to setup the new devices, it only ever displayed one. The creator of the Hub has advised that it should initially create 4 devices; could this be an issue with the Mysensors plugin for Vera? If this is possible, what information can I provide that will help correct this?
  • 6
