Home Assistant not assigning Node IDs
  • Hello,
    I'm setting up home assistant with mysensors for the first time, and have hit a snag. If I assign a node ID manually, the network works fine, however if I leave it to the controller to assign a node ID, it tries to assign node 0 to the sensor (I think, if i'm interpreting the logs correctly). The gateway is running on the example sketch for the WS5100 ethernet module, and the sketch for the sensor is below. I have tried a different arduino for both gateway and sensor, and tried clearing the EEPROM of both the gateway and sensor (these arduinos have been used to tinker with MySensors a few years ago).
    I have also tried clearing the home-assistant persistence file.
    Below are some logs from each of the pieces of the puzzle:
    Gateway Serial Output:
    0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    17 MCO:REG:NOT NEEDED
    320 GWT:TIN:IP=192.168.1.25
    1323 MCO:BGN:STP
    1325 MCO:BGN:INIT OK,TSP=1
    1327 TSM:READY:NWD REQ
    1363 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    12073 GWT:TSA:ETH OK
    12082 GWT:RFC:MSG=0;255;3;0;2;
    12091 GWT:RFC:MSG=255;255;3;0;20;
    12129 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    22179 GWT:RFC:MSG=0;255;3;0;2;
    Sensor Sketch:
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN  4
    #define CHILD_ID 1
    #define RELAY_ON 1
    #define RELAY_OFF 0
    bool state = false;
    bool initialValueSent = false;
    MyMessage msg(CHILD_ID, V_STATUS);
      pinMode(RELAY_PIN, OUTPUT);
    void presentation()  {
      sendSketchInfo("Relay+button", "1.0");
      present(CHILD_ID, S_BINARY);
      if (!initialValueSent) {
        send(msg.set(state?RELAY_ON:RELAY_OFF));
        Serial.println("Requesting initial value from controller");
        request(CHILD_ID, V_STATUS);
        wait(2000, C_SET, V_STATUS);
      if (message.isAck()) {
          Serial.println("Receiving initial value from controller");
          initialValueSent = true;
        // Change relay state
        state = (bool)message.getInt();
    Sensor Serial Output:
    16 MCO:BGN:INIT REPEATER,CP=RNNRA---,REL=255,VER=2.3.1
    26 TSM:INIT
    27 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    35 !TSF:SID:FAIL,ID=0
    37 TSM:FAIL:CNT=1
    39 TSM:FAIL:DIS
    40 TSF:TDI:TSL
    Home Assistant config:
    mysensors:
      version: '2.3'
      gateways:
        - device: '192.168.XX.XX'
          persistence_file: /config/mysensors.json
    I have also tried a mysensors version of 2.2, but no change.
    Home Assistant log:
    Config directory: /config
    2019-03-23 22:58:02 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "notify". Check lines 73 and 79.
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded owntracks from homeassistant.components.owntracks
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded shell_command from homeassistant.components.shell_command
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded custom_updater from custom_components.custom_updater
    2019-03-23 22:58:03 WARNING (MainThread) [homeassistant.loader] You are using a custom component for custom_updater which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded twilio from homeassistant.components.twilio
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded person from homeassistant.components.person
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded notify from homeassistant.components.notify
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setting up mqtt
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.loader] Loaded mqtt.server from homeassistant.components.mqtt.server
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setting up logger
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setting up recorder
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setting up http
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setting up lovelace
    2019-03-23 22:58:03 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [transitions.core] Exited state new
    2019-03-23 22:58:04 INFO (MainThread) [transitions.core] Entered state starting
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up system_log
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up api
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up auth
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up onboarding
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [hbmqtt.broker] Listener 'default' bind to 0.0.0.0:1883 (max_connections=-1)
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.4 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [hbmqtt.broker] Listener 'ws-1' bind to 0.0.0.0:8080 (max_connections=-1)
    2019-03-23 22:58:04 INFO (MainThread) [transitions.core] Exited state starting
    2019-03-23 22:58:04 INFO (MainThread) [transitions.core] Entered state started
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 1.4 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up history
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
    2019-03-23 22:58:04 INFO (MainThread) [homeassistant.setup] Setting up frontend
    2019-03-23 22:58:05 INFO (MainThread) [hbmqtt.broker] Listener 'default': 1 connections acquired
    2019-03-23 22:58:05 INFO (MainThread) [hbmqtt.broker] Connection from 127.0.0.1:57651 on listener 'default'
    2019-03-23 22:58:05 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.7 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [transitions.core] Exited state new
    2019-03-23 22:58:06 INFO (MainThread) [transitions.core] Entered state connected
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up updater
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up map
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up shell_command
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain shell_command took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.loader] Loaded mqtt.sensor from homeassistant.components.mqtt.sensor
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.loader] Loaded sensor.time_date from homeassistant.components.sensor.time_date
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up sensor
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.loader] Loaded device_tracker.luci from homeassistant.components.device_tracker.luci
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.loader] Loaded google from homeassistant.components.google
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.loader] Loaded google.tts from homeassistant.components.google.tts
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up sun
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up zone
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up group
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up person
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.loader] Loaded notify.twilio_sms from homeassistant.components.notify.twilio_sms
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up notify
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up mysensors
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.time_date
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.5 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up script
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up webhook
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up system_health
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up tts
    2019-03-23 22:58:06 INFO (MainThread) [homeassistant.setup] Setting up conversation
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setting up logbook
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setting up automation
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setting up config
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mqtt
    2019-03-23 22:58:07 DEBUG (SyncWorker_21) [mysensors.persistence] Loading sensors from persistence file /config/mysensors.json
    [SNIP]
    2019-03-23 22:58:07 DEBUG (SyncWorker_9) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.2 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.2 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.5 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain mysensors took 0.4 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.6 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 0.6 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.2 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.6 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.25', 5003)
    2019-03-23 22:58:07 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.7 seconds.
    2019-03-23 22:58:07 INFO (MainThread) [mysensors] Connected to <TCPTransport closed=False reading=False 0x55b5d4923eb8>
    [SNIP]
    2019-03-23 22:58:17 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2019-03-23 22:58:17 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;14;Gateway startup complete.
    2019-03-23 22:58:17 INFO (MainThread) [mysensors.handler] n:0 c:255 t:3 s:14 p:Gateway startup complete.
    2019-03-23 22:58:17 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 255
    2019-03-23 22:58:17 DEBUG (MainThread) [mysensors] Sending 255;255;3;0;20;
    2019-03-23 22:58:17 DEBUG (MainThread) [mysensors] Receiving 0;255;0;0;18;2.3.1
    2019-03-23 22:58:17 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 14.47s
    2019-03-23 22:58:17 INFO (MainThread) [homeassistant.core] Starting Home Assistant
    2019-03-23 22:58:17 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.1
    [SNIP]
    2019-03-23 22:58:27 DEBUG (SyncWorker_32) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
    2019-03-23 22:58:27 DEBUG (MainThread) [mysensors] Sending 0;255;3;0;2;
    2019-03-23 22:58:27 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;2;2.3.1
    Hope I've provided enough info here.
    Thanks.
  • Mod
    @adamant yes you are inerpreting the logs correctly.
    The log parser says this line means "Assigned id 0 is invalid". The node probably has 0 in the eeprom address MySensors uses for keeping track of the node's id.
    Load the MySensors cleareeprom sketch on the node and run the sketch, then load the repeater sketch again.
  • A ha, that fixed it. Thanks very much! If you don't mind, what is the difference between the MySensors eeprom clearing sketch vs the stock arduino one? From first glance it seems as if the Arduino one would actually clean more, since it iterates over the whole eeprom rather than just the bits relevant to MySensors.
  • Mod
    @adamant yes that's correct. The (other) difference is that the stock arduino version writes 0x00 to each location, while the MySensors version writes 0xFF. 0xFF is the value the eeprom has before it is written to the first time when it comes out of the factory.
