@andriej
Hi, I had problem using the main branch mysensors/Raspberry, that because of the bit-field struct (header_s) in Sensor.h They will get packed in different order on the arduino compared to the RPi (at least with my compiler, gcc). In order to fix this I created the 1.4dev branch. It uses full bytes instead of the bit-fields, but you need (of cause) to compile both the sensors (arduino) and the gateway (RPi) using the 1.4dev branch.
We need to fix this in the main branch later on (and use the same files as in mysensors/Arduino/libraries/MySensors)
@skywatch said in Awesome tip: run LinuxFX instead of Windows!:
@NeverDie Thanks - Interestingly they show a free version on their site still. Did they revert due to bad publicity?
https://www.linuxfx.org/
I stopped following it, but I seem to recollect that the free version was noticeably missing things--otherwise, who'd buy the paid-for version? Anyway, its standing on Distro-watch has fallen considerably. It may seem unfair to niche distros, but I think it's generally better to stick with the more popular distros, unless you have good reason to choose otherwise.
Hi everyone
Which MySensors lib did you use? The 2.3.2 or the delevopment version? I tried to fix the errors, but they don't appear in the development branch. Only another error which i fixed.
Regards, Edi
@OldSurferDude Thanks a very valued to know. I was wondering today why my (big) powerbanks fall down after short time. I have small 1 & 2-pieces powerbanks, they work very well. I use also BSM hw-168 or hw-107 for charging single 18650. Will try to use them outside also with small solarpanels.
Some humidity sensors are known to lose accuracy with age. For instance, the Si7021 is known to have this problem. If that matters to you, then the best choice is to pick sensors that have datasheets and which have specs as to their expected longevity or accuracy over time. Then buy from mouser/digikey to be certain you're getting the real thing rather than factory rejects or counterfeits.
For extra insurance, I avoid electrolytic capacitors entirely whenever possible. I buy only 7XR rated ceramic capacitors that are overspec'd. The difference in price is small compared to a failure down the road.
