Problem with BME280 Hum value
  • Hi,
    i try to create a node by the BME280 example and send them to IoBroker.
    But then I get by IoBroker just the Temp and the Pressure value.
    BME280 - Requesting new data from sensor module.
    BME280 - Sensor module has some new values ready:
    BME280 - Temperature = 25.69 °C
    BME280 - Humidity = 41.13 %
    BME280 - Pressure = 1023.98 hPa
    BME280 - Forecast = stable
    BME280 - Sending the new temperature to the gateway.
    330804 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.7
    BME280 - Sending the new humidity to the gateway.
    330816 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:41.1
    BME280 - Sending the new pressure to the gateway.
    330828 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1024.0
    BME280 - Measurement complete. Going to wait until next measurement.
    And the log from IoBroker
    mysensors.0	2019-09-05 18:55:48.532	info	Add new object: 1.0_TEMP.V_ID - 1.0_TEMP.V_ID
    mysensors.0	2019-09-05 18:55:48.531	info	Add new object: 1.0_TEMP.V_TEMP - 1.0_TEMP.V_TEMP
    mysensors.0	2019-09-05 18:55:48.530	info	Add new object: 1.0_TEMP - 1.0_TEMP
    mysensors.0	2019-09-05 18:55:48.475	info	Add new object: 1.2_BARO.V_FORECAST - 1.2_BARO.V_FORECAST
    mysensors.0	2019-09-05 18:55:48.475	info	Add new object: 1.2_BARO.V_PRESSURE - 1.2_BARO.V_PRESSURE
    mysensors.0	2019-09-05 18:55:48.474	info	Add new object: 1.2_BARO - 1.2_BARO
    mysensors.0	2019-09-05 18:55:48.416	info	Version :1.1
    mysensors.0	2019-09-05 18:55:48.356	warn	setObject mysensors.0.1 (type=device) property native missing!
    mysensors.0	2019-09-05 18:55:48.353	info	Name :BME280 Sensor
    Any idea? Any help is welcome.
  • Check the variable type you are sending with the humidity. The log parser indicates you are sending a V_TEMP for the humidity reading instead of a V_HUM
    You can find the log parser here: https://www.mysensors.org/build/parser
    Much easier than trying to read the log output directly.
  • You are right, I solved it. But now it looks like sending failed during presentation? Any idea?
    _  __       ____
            |___/                      2.3.1
    16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    26 TSM:INIT
    27 TSF:WUR:MS=0
    33 TSM:INIT:TSP OK
    35 TSF:SID:OK,ID=3
    37 TSM:FPAR
    73 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    587 TSF:MSG:READ,0-0-3,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    592 TSF:MSG:FPAR OK,ID=0,D=1
    2080 TSM:FPAR:OK
    2081 TSM:ID
    2082 TSM:ID:OK
    2084 TSM:UPL
    2087 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2184 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2189 TSF:MSG:PONG RECV,HP=1
    2192 TSM:UPL:OK
    2193 TSM:READY:ID=3,PAR=0,DIS=1
    2198 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2322 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2329 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
    2338 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4346 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:BME280 Sensor
    4356 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
    4364 TSF:MSG:SEND,3-3-0-0,s=2,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
    4371 TSF:MSG:SEND,3-3-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4412 !TSF:MSG:SEND,3-3-0-0,s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=NACK:
    4419 TSF:MSG:SEND,3-3-0-0,s=3,c=0,t=6,pt=0,l=0,sg=0,ft=1,st=OK:
    4425 MCO:REG:REQ
    4463 !TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
    6470 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    6535 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    6540 MCO:PIM:NODE REG=1
    6542 MCO:BGN:STP
    Hello world, I am a sensor node.
    6544 MCO:BGN:INIT OK,TSP=1
    BME280 - Temperature = 25.18 °C
    BME280 - Humidity = 39.49 %
    BME280 - Pressure = 1022.52 hPa
    BME280 - Forecast = unknown
    6616 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.2
    6627 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:39.5
    6637 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.0
    6645 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1022.5
    BME280 - Sending the latest forecast to the gateway.
    6677 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
  • Mod
    @mrrose sending multiple messages in rapid succession strains the power supply. How is the node powered? What capacitors do you use near the nrf24? See if adding an additional capacitor helps, and/or add wait(100) after each call to presentation and send.
  • The wait(100) worked thanks. I`m using an 10uF so far.
  • 15
  • 24
11.3k
