Feather AMG8833 IR thermal camera and resistive touchscreen
  • Hi everyone, it is my first post on this forum, so it is better to precise that I am a newbie in the world of programming.
    I bought a Adafruit HUZZAH32 - ESP32 Feather (assembled with plain and stacking headers), a Adafruit 3.5" 480x320 TFT FeatherWing and a Adafruit AMG8833 IR Thermal Camera FeatherWing (I soldered the headers myself). The aim of my project is to make a thermal camera. So I connected the TFT and the Thermal camera to the ESP32 feather, I tested with some examples found in the specific libraries (touchpaint_featherwing and thermal_cam_interpolate) and it works very well. I modified the code to add some temperature scale.
    Now, I try to improve this wonderful tool: I want to use the resistive touchscreen TFT to increase the maximal and minimal temperature of the thermal camera, by pressing the TFT at specific location. So I modify my code (based on the touchpaint_featherwing example) and I supposed it is good, but the results is that the thermal camera works for a frame and then freeze. And touching the TFT at the specific location doesn't change anything.
    I incorporate my code at the end of this post.
    I noticed if I comment the line #23 "Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);", #103 "TouchTFT();" and at the line #162 all the function "void TouchTFT(){...}", the thermal camera doesn't freeze (but of course touching the TFT doesn't work due to the comment of the function TouchTFT() ) and it works well as before.
    Is it not possible to use the thermal camera and the resistive touchscreen of the TFT in the same time?
    Thank you for your help.
    #include <Adafruit_GFX.h>
    #include <Adafruit_HX8357.h>
    #include <Wire.h>
    #include <Adafruit_AMG88xx.h>
    #include <Adafruit_STMPE610.h>
    #define STMPE_CS 32
    #define TFT_CS   15
    #define TFT_DC   33
    #define SD_CS    14
    #define TS_MINX 3800
    #define TS_MAXX 100
    #define TS_MINY 100
    #define TS_MAXY 3750
    #define TFT_RST -1
    Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
    int MINTEMP = 15;
    int MAXTEMP = 28;
    const uint16_t camColors[] = {0x480F,
    0x400F,0x400F,0x400F,0x4010,0x3810,0x3810,0x3810,0x3810,0x3010,0x3010,
    0x3010,0x2810,0x2810,0x2810,0x2810,0x2010,0x2010,0x2010,0x1810,0x1810,
    0x1811,0x1811,0x1011,0x1011,0x1011,0x0811,0x0811,0x0811,0x0011,0x0011,
    0x0011,0x0011,0x0011,0x0031,0x0031,0x0051,0x0072,0x0072,0x0092,0x00B2,
    0x00B2,0x00D2,0x00F2,0x00F2,0x0112,0x0132,0x0152,0x0152,0x0172,0x0192,
    0x0192,0x01B2,0x01D2,0x01F3,0x01F3,0x0213,0x0233,0x0253,0x0253,0x0273,
    0x0293,0x02B3,0x02D3,0x02D3,0x02F3,0x0313,0x0333,0x0333,0x0353,0x0373,
    0x0394,0x03B4,0x03D4,0x03D4,0x03F4,0x0414,0x0434,0x0454,0x0474,0x0474,
    0x0494,0x04B4,0x04D4,0x04F4,0x0514,0x0534,0x0534,0x0554,0x0554,0x0574,
    0x0574,0x0573,0x0573,0x0573,0x0572,0x0572,0x0572,0x0571,0x0591,0x0591,
    0x0590,0x0590,0x058F,0x058F,0x058F,0x058E,0x05AE,0x05AE,0x05AD,0x05AD,
    0x05AD,0x05AC,0x05AC,0x05AB,0x05CB,0x05CB,0x05CA,0x05CA,0x05CA,0x05C9,
    0x05C9,0x05C8,0x05E8,0x05E8,0x05E7,0x05E7,0x05E6,0x05E6,0x05E6,0x05E5,
    0x05E5,0x0604,0x0604,0x0604,0x0603,0x0603,0x0602,0x0602,0x0601,0x0621,
    0x0621,0x0620,0x0620,0x0620,0x0620,0x0E20,0x0E20,0x0E40,0x1640,0x1640,
    0x1E40,0x1E40,0x2640,0x2640,0x2E40,0x2E60,0x3660,0x3660,0x3E60,0x3E60,
    0x3E60,0x4660,0x4660,0x4E60,0x4E80,0x5680,0x5680,0x5E80,0x5E80,0x6680,
    0x6680,0x6E80,0x6EA0,0x76A0,0x76A0,0x7EA0,0x7EA0,0x86A0,0x86A0,0x8EA0,
    0x8EC0,0x96C0,0x96C0,0x9EC0,0x9EC0,0xA6C0,0xAEC0,0xAEC0,0xB6E0,0xB6E0,
    0xBEE0,0xBEE0,0xC6E0,0xC6E0,0xCEE0,0xCEE0,0xD6E0,0xD700,0xDF00,0xDEE0,
    0xDEC0,0xDEA0,0xDE80,0xDE80,0xE660,0xE640,0xE620,0xE600,0xE5E0,0xE5C0,
    0xE5A0,0xE580,0xE560,0xE540,0xE520,0xE500,0xE4E0,0xE4C0,0xE4A0,0xE480,
    0xE460,0xEC40,0xEC20,0xEC00,0xEBE0,0xEBC0,0xEBA0,0xEB80,0xEB60,0xEB40,
    0xEB20,0xEB00,0xEAE0,0xEAC0,0xEAA0,0xEA80,0xEA60,0xEA40,0xF220,0xF200,
    0xF1E0,0xF1C0,0xF1A0,0xF180,0xF160,0xF140,0xF100,0xF0E0,0xF0C0,0xF0A0,
    0xF080,0xF060,0xF040,0xF020,0xF800,};
    Adafruit_AMG88xx amg;
    unsigned long delayTime;
    #define AMG_COLS 8
    #define AMG_ROWS 8
    float pixels[AMG_COLS * AMG_ROWS];
    #define INTERPOLATED_COLS 24
    #define INTERPOLATED_ROWS 24
    float get_point(float *p, uint8_t rows, uint8_t cols, int8_t x, int8_t y);
    void set_point(float *p, uint8_t rows, uint8_t cols, int8_t x, int8_t y, float f);
    void get_adjacents_1d(float *src, float *dest, uint8_t rows, uint8_t cols, int8_t x, int8_t y);
    void get_adjacents_2d(float *src, float *dest, uint8_t rows, uint8_t cols, int8_t x, int8_t y);
    float cubicInterpolate(float p[], float x);
    float bicubicInterpolate(float p[], float x, float y);
    void interpolate_image(float *src, uint8_t src_rows, uint8_t src_cols,
                           float *dest, uint8_t dest_rows, uint8_t dest_cols);
      delay(500);
      Serial.begin(115200);
      tft.begin();
      tft.setRotation(135);
      tft.fillScreen(HX8357_BLACK);
      if (!amg.begin()) {
        while (1) { delay(1); }
      DrawButtons();
      amg.readPixels(pixels);
      float dest_2d[INTERPOLATED_ROWS * INTERPOLATED_COLS];
      int32_t t = millis();
      interpolate_image(pixels, AMG_ROWS, AMG_COLS, dest_2d, INTERPOLATED_ROWS, INTERPOLATED_COLS);
      uint16_t boxsize = min(tft.width() / INTERPOLATED_COLS, tft.height() / INTERPOLATED_COLS);
      drawpixels(dest_2d, INTERPOLATED_ROWS, INTERPOLATED_COLS, boxsize, boxsize, false);
      DrawLegend();
      TouchTFT();
      // delay(50);
    void drawpixels(float *p, uint8_t rows, uint8_t cols, uint8_t boxWidth, uint8_t boxHeight, boolean showVal) {
      int colorTemp;
      for (int y=0; y<rows; y++) {
        for (int x=0; x<cols; x++) {
          float val = get_point(p, rows, cols, x, y);
          if(val >= MAXTEMP) colorTemp = MAXTEMP;
          else if(val <= MINTEMP) colorTemp = MINTEMP;
          else colorTemp = val;
          uint8_t colorIndex = map(colorTemp, MINTEMP, MAXTEMP, 0, 255);
          colorIndex = constrain(colorIndex, 0, 255);
          uint16_t color;
          color = val * 2;
          tft.fillRect(160+5+boxWidth * y, 308 - (5+boxHeight * x), boxWidth, boxHeight, camColors[colorIndex]);
          if (showVal) {
            tft.setCursor(boxWidth * y + boxWidth/2 - 12, 40 + boxHeight * x + boxHeight/2 - 4);
            tft.setTextColor(HX8357_WHITE);  tft.setTextSize(1);
            tft.print(val,1);
    void DrawLegend() {
      float diff = MAXTEMP - MINTEMP;
      for (int ii = 0; ii < 255; ii += 1) {
        tft.fillRect(130, 300-1*ii, 30, 1, camColors[ii]);
      for (int ii = 0; ii < 6; ii += 1) {
          tft.fillRect(120, 300-51*ii, 10, 2, camColors[ii*255/5]);
          tft.setTextSize(1);
          tft.setTextColor(camColors[ii*255/5]);
          tft.setCursor(85, 297-51*ii);
          tft.print(MINTEMP + ii*diff/5);
    void DrawButtons() {
      const char* butname[] = {"M+","M-","SD","m+","m-"};
      for (int ii = 0; ii < 5; ii += 1) {
        tft.fillRect(10, 20+60*ii, 50, 30, HX8357_WHITE);
        tft.setTextSize(2);
        tft.setTextColor(HX8357_BLACK);
        tft.setCursor(25, 30+60*ii);
        tft.print(butname[ii]);
    void TouchTFT() {
      TS_Point p = ts.getPoint();
      p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
      p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
      if (p.x > 10 && p.x < 60) {
            if (p.y > 20 && p.y < 50) {
          MAXTEMP = MAXTEMP + 1;
          tft.fillRect(10, 20+60*ii, 50, 30, HX8357_BLACK);
        else if (p.y > 80 && p.y < 110) {
          MAXTEMP = MAXTEMP - 1;
        else if (p.y > 140 && p.y < 170) {
          MAXTEMP = MAXTEMP;
        else if (p.y > 200 && p.y < 230) {
          MINTEMP = MINTEMP + 1;
        else if (p.y > 260 && p.y < 290) {
          MINTEMP = MINTEMP -1;
