Openhab thing/item for gas sensor
  • Dear Forum
    I would appreciate some pointers making a gas meter sensor working in openhab using a serial gateway. I used the water meter sketch and redefined S_WATER with S_GAS. The sensors shows up in openhab and reports data, but the data never gets stored as item.
    The Sensor sketch uses:
    #define CHILD_ID 1 // Id of the sensor child
    MyMessage flowMsg(CHILD_ID,V_FLOW);
    MyMessage volumeMsg(CHILD_ID,V_VOLUME);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    things definition:
    Bridge mysensors:bridge-eth:mybridge [ ipAddress="127.0.0.1", tcpPort=5003, sendDelay=100, networkSanCheckEnabled=true ] {
    Thing gasMeter Meter_Gas [ nodeId=100, childId=1 ] {
    Channels:
    Type number : volume []
    Type number : flow []
    Type number : var1 []
    items definition:
    Number Gas_Flow "GasFlow" <flow> (Gas) ["Meter"] {channel="mysensors:gasMeter:mybridge:Meter_Gas:flow"}
    Number Gas_Volume "GasVol" <volume> (Gas) ["Meter"] {channel="mysensors:gasMeter:mybridge:Meter_Gas:vol"
    openhab receives the messages and shows them in the gateway debug output:
    Message from gateway received: 100;1;1;0;24;36
    Node 100 found in gateway
    Child 1 found in node 100
    Message from gateway received: 100;1;1;0;35;0.360
    But the output of the other (working) sensors is then processed and stored:
    Updating channel: hum(V_HUM) value to: 49.2
    Humidity1 changed from 48.2 to 49.2
    How can I specifythe channels correctly in the things and items file? Would it be better to use seperate child Ids instead of channels?
  • just a small correction: it's a Raspberry Pi Gateway, but probably this makes no difference
  • 15
  • 1
11.3k
