Making WiFiManager compatible with MySensors 2.3.2
  • Its not bug but a workaround just in case if any one is searching for solution. I was using WiFiManager with MySensors 2.3.1 for WiFi gateway and it was working fine and now i upgraded MySensors from 2.3.1 to 2.3.2 and my WiFi gateway sketch refuse to compile. for the time being workaround: You need to comment out two location in core/MyGatewayTransportEthernet.cpp
    may be there is better way but this is quick fix.
    Line 49 to 55
    #if defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_ESP32)
    #if !defined(MY_WIFI_SSID)
    #error ESP8266/ESP32 gateway: MY_WIFI_SSID not defined!
    Line 184 to 189
    /*	(void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
    	while (WiFi.status() != WL_CONNECTED) {
    		delay(1000);
    		GATEWAY_DEBUG(PSTR("GWT:TIN:CONNECTING...\n"));
    	GATEWAY_DEBUG(PSTR("GWT:TIN:IP: %s\n"), WiFi.localIP().toString().c_str());*/
  • Thank you.
  • 33
  • 5
  • 11
  • 5
  • 8
11.3k
