Keep getting error 'child_id 0 already exists in children of node 1, cannot add child'
  • Hi all,
    I'm trying to connect my first MySensors node (MQ135 gas sensor) to a serial gateway. This is connected to a raspberry pi 4 running Home Assistant on Hassio. However I keep on getting this error in the home assistant logs:error.PNG I have already tried clearing the eeprom but the sensor still won't appear in home assistant any ideas on how to solve this?
    Any help is greatly appreciated😁
    Here is the log output on my sensor node I'm trying to connect:
    17:08:18.717 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
    17:08:18.717 -> 28 TSM:INIT
    17:08:18.717 -> 28 TSF:WUR:MS=0
    17:08:18.717 -> 36 TSM:INIT:TSP OK
    17:08:18.717 -> 38 TSF:SID:OK,ID=2
    17:08:18.717 -> 40 TSM:FPAR
    17:08:18.717 -> 45 ?TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    17:08:20.713 -> 2054 !TSM:FPAR:NO REPLY
    17:08:20.748 -> 2056 TSM:FPAR
    Here is the sketch on the node:
     * Connect the MQ2 sensor as follows :
     *   A H A   >>> 5V
     *   B       >>> A0
     *   H       >>> GND
     *   B       >>> 10K ohm >>> GND
     * Contribution: epierre
     * Based on http://sandboxelectronics.com/?p=165
     * License: Attribution-NonCommercial-ShareAlike 3.0 Unported (CC BY-NC-SA 3.0)
     * Modified by HEK to work in 1.4
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define     CHILD_ID_MQ                   0
    /************************Hardware Related Macros************************************/
    #define     MQ_SENSOR_ANALOG_PIN         (0)  //define which analog input channel you are going to use
    #define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
    #define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
    //which is derived from the chart in datasheet
    /***********************Software Related Macros************************************/
    #define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
    #define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interval(in milliseconds) between each samples in the
    //calibration phase
    #define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
    #define         READ_SAMPLE_TIMES            (5)     //define the time interval(in milliseconds) between each samples in
    //normal operation
    /**********************Application Related Macros**********************************/
    #define         GAS_LPG                      (0)
    #define         GAS_CO                       (1)
    #define         GAS_SMOKE                    (2)
    /*****************************Globals***********************************************/
    uint32_t SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    //VARIABLES
    float Ro = 10000.0;    // this has to be tuned 10K Ohm
    int val = 0;           // variable to store the value coming from the sensor
    uint16_t lastMQ = 0;
    float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
    //with these two points, a line is formed which is "approximately equivalent"
    //to the original curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
    float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
    float           SmokeCurve[3] = {2.3,0.53,-0.44};   //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
    MyMessage msg(CHILD_ID_MQ, V_LEVEL);
        Ro = MQCalibration(
                 MQ_SENSOR_ANALOG_PIN);         //Calibrating the sensor. Please make sure the sensor is in clean air
        sendSketchInfo("Air Quality Sensor", "1.0");
        present(CHILD_ID_MQ, S_AIR_QUALITY);
        uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO);
        Serial.println(val);
        Serial.print("LPG:");
        Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_LPG) );
        Serial.print( "ppm" );
        Serial.print("    ");
        Serial.print("CO:");
        Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO) );
        Serial.print("    ");
        Serial.print("SMOKE:");
        Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_SMOKE) );
        Serial.print("\n");
        if (valMQ != lastMQ) {
            send(msg.set((int16_t)ceil(valMQ)));
            lastMQ = ceil(valMQ);
        sleep(SLEEP_TIME); //sleep for: sleepTime
    /****************** MQResistanceCalculation ****************************************
    Input:   raw_adc - raw value read from adc, which represents the voltage
    Output:  the calculated sensor resistance
    Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
             across the load resistor and its resistance, the resistance of the sensor
             could be derived.
    float MQResistanceCalculation(int raw_adc)
        return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
    /***************************** MQCalibration ****************************************
    Input:   mq_pin - analog channel
    Output:  Ro of the sensor
    Remarks: This function assumes that the sensor is in clean air. It use
             MQResistanceCalculation to calculates the sensor resistance in clean air
             and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
             10, which differs slightly between different sensors.
    float MQCalibration(int mq_pin)
        int i;
        float inVal=0;
        for (i=0; i<CALIBARAION_SAMPLE_TIMES; i++) {          //take multiple samples
            inVal += MQResistanceCalculation(analogRead(mq_pin));
            delay(CALIBRATION_SAMPLE_INTERVAL);
        inVal = inVal/CALIBARAION_SAMPLE_TIMES;                   //calculate the average value
        inVal = inVal/RO_CLEAN_AIR_FACTOR;                        //divided by RO_CLEAN_AIR_FACTOR yields the Ro
        //according to the chart in the datasheet
        return inVal;
    /*****************************  MQRead *********************************************
    Output:  Rs of the sensor
    Remarks: This function use MQResistanceCalculation to calculate the sensor resistance (Rs).
             The Rs changes as the sensor is in the different concentration of the target
             gas. The sample times and the time interval between samples could be configured
             by changing the definition of the macros.
    float MQRead(int mq_pin)
        int i;
        float rs=0;
        for (i=0; i<READ_SAMPLE_TIMES; i++) {
            rs += MQResistanceCalculation(analogRead(mq_pin));
            delay(READ_SAMPLE_INTERVAL);
        rs = rs/READ_SAMPLE_TIMES;
        return rs;
    /*****************************  MQGetGasPercentage **********************************
    Input:   rs_ro_ratio - Rs divided by Ro
             gas_id      - target gas type
    Output:  ppm of the target gas
    Remarks: This function passes different curves to the MQGetPercentage function which
             calculates the ppm (parts per million) of the target gas.
    int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
        if ( gas_id == GAS_LPG ) {
            return MQGetPercentage(rs_ro_ratio,LPGCurve);
        } else if ( gas_id == GAS_CO ) {
            return MQGetPercentage(rs_ro_ratio,COCurve);
        } else if ( gas_id == GAS_SMOKE ) {
            return MQGetPercentage(rs_ro_ratio,SmokeCurve);
        return 0;
    /*****************************  MQGetPercentage **********************************
             pcurve      - pointer to the curve of the target gas
    Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
             of the line could be derived if y(rs_ro_ratio) is provided. As it is a
             logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
             value.
    int  MQGetPercentage(float rs_ro_ratio, float *pcurve)
        return (pow(10,( ((log(rs_ro_ratio)-pcurve[1])/pcurve[2]) + pcurve[0])));
    Here are the home assistant logs:
    2020-03-23 16:47:06 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 1, cannot add child
    2020-03-23 16:54:11 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 1, cannot add child
    2020-03-23 17:00:06 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 1, cannot add child
    2020-03-23 17:04:54 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 1, cannot add child
    2020-03-23 17:08:19 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 2, cannot add child
  • Mod
    (moved to the Home Assistant category, where it hopefully will get attention from people using HA)
  • 2020-03-23 17:04:54 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 1, cannot add child
    This isn't an error, it's just a warning. Whenever you power up a node and present your sensors, Home Assistant will check if they are already known (and listed in your persistance file). If they are, you get this warning as an information. There's nothing to worry about unless you change an existing sensor's type but keep the same ID. In this case, Home Assistant won't update the sensor to the new type and you would have to remove the conflicting child object manually from your persistance file, reload your configuration and present your sensor again.
    Your sensor node thinks its ID is 2. You wrote that you tried clearing the eeprom and your sketch doesn't assign a static node ID. If you don't assign a static ID, the node will request one from the controller. So where does it come from? Did you confirm it cleared? Did your connection work at some time after clearing the eeprom?
    Your node didn't get a reply from its parent. Are there any related messages in the serial output of the parent node (gateway)? This could very well be a general power / hardware or range issue especially since your Home Assistant log shows that you seem to be able to connect to your network atleast occassionally.
    Please take a look at the debug / FAQ and follow the flowchart:
    https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
    I guess your sensor readings don't appear in your Home Assistant dashboard during the times the radio connection works? Could you please post the configuration of your MySensors integration in configuration.yaml?
  • Thanks for the help. I cleared the eeprom again just to confirm that it isn't causing the problem and the connection still is not working.
    Here's the serial output from the gateway:
    2020-03-24 15:38:13 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:273906 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    2020-03-24 15:38:13 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:273912 TSF:MSG:BC
    2020-03-24 15:38:13 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:273915 TSF:MSG:FPAR REQ,ID=2
    2020-03-24 15:38:13 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:273918 TSF:PNG:SEND,TO=0
    2020-03-24 15:38:13 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:273923 TSF:CKU:OK
    2020-03-24 15:38:13 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:273925 TSF:MSG:GWL OK
    2020-03-24 15:38:14 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:274456 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    2020-03-24 15:38:15 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275932 TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    2020-03-24 15:38:15 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275938 TSF:MSG:PINGED,ID=2,HP=1
    2020-03-24 15:38:15 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275946 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275961 TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275970 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275978 TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
    2020-03-24 15:38:16 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 2 child 255
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:275990 TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:276008 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:276016 TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=18,sg=0:Air Quality Sensor
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:276027 TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:276037 TSF:MSG:READ,2-2-0,s=0,c=0,t=22,pt=0,l=0,sg=0:
    2020-03-24 15:38:16 WARNING (MainThread) [mysensors.sensor] child_id 0 already exists in children of node 2, cannot add child
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:276047 TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    2020-03-24 15:38:16 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:276056 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    2020-03-24 15:38:18 DEBUG (SyncWorker_11) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
    I've added it all as I'm not sure what is relevant😁
    Here is the mysensor config in the configuration.yaml file:
    mysensors:
      gateways:
        - device: '/dev/ttyUSB0'
          baud_rate: 115200
      optimistic: false
      persistence: true
      retain: true
      version: '2.3'
  • @henry-north According to the serial output from the gateway you do have communication between the gateway and the node.
    I think there is some issue with the Homeassistant persistence file, or perhaps you changed the child type in the node scetch after it was presented first time as pointed out by @BearWithBeard? If so it will no longer match the data in the persistence file and you will get the "cannot add child" warning, and (I think) not se the sensor in HA. Try to delete the persistence file (mysensors.pickle). Then first restart HA, then restart/present gateway and then reset/present the node(s).
    You can change the persistance file to a readable format by putting this in your configuration:
    persistence_file: '/config/mysensors.json'
    Makes it much easier to see what's going on.
  • Thanks for the log. As @olka said, the communication seems to be working. I'm wondering though, if the node is able to present its sensors and both the node and gateway can send / receive ping pong messages - which happens after the node is looking for a parent (FPAR section in the log) - how could the sensor note get stuck at FPAR as you described in your opening post? Those two serial outputs don't match up imho.
    Your configuration.yaml looks fine, btw. I second @olka's suggestion to switch to a human readable JSON file though.
  • Thanks again for the advice. I added
    to my configuration.yaml file after deleting mysensors.pickle and things seemed to work much better as I didn't get the initial error. However I did get these errors instead:
    2020-03-24 19:45:34 INFO (MainThread) [homeassistant.setup] Setting up mysensors
    2020-03-24 19:45:34 WARNING (SyncWorker_3) [mysensors.persistence] File does not exist or is not readable: /config/mysensors.json
    2020-03-24 19:45:34 WARNING (SyncWorker_3) [mysensors.persistence] Trying backup file: /config/mysensors.json.bak
    2020-03-24 19:45:34 WARNING (SyncWorker_3) [mysensors.persistence] File does not exist or is not readable: /config/mysensors.json.bak
    2020-03-24 19:45:34 WARNING (SyncWorker_3) [mysensors.persistence] Failed to load sensors from file: /config/mysensors.json
    2020-03-24 19:45:34 DEBUG (SyncWorker_10) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
    2020-03-24 19:45:44 DEBUG (SyncWorker_2) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
    And also I still can't get past the original point in the communications but perhaps that is now linked to the file permissions above:
    2020-03-24 19:45:34 INFO (MainThread) [mysensors] Connected to Serial<id=0xb272eab0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors] Receiving 0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:5 TSM:INIT
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:7 TSF:WUR:MS=0
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:15 TSM:INIT:TSP OK
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:18 TSM:INIT:GW MODE
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:21 TSM:READY:ID=0,PAR=0,DIS=0
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:24 MCO:REG:NOT NEEDED
    2020-03-24 19:45:35 INFO (MainThread) [mysensors.handler] n:0 c:255 t:3 s:14 p:Gateway startup complete.
    2020-03-24 19:45:35 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 0 child 255
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:28 MCO:BGN:INIT OK,TSP=1
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:36 TSM:READY:NWD REQ
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:41 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    2020-03-24 19:45:35 DEBUG (MainThread) [mysensors.handler] n:0 c:255 t:3 s:9 p:52 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=1,l=1,sg=0,ft=0,st=OK:0
  • 1
  • 17
  • 1
  • 6
