How ethernet gateway code can check if is connected with controller?
  • Having arduino ethernet gateway I need to send messages with senors values to controller (Home assistant requirement to auto configure sensors).
    With serial gateway simple sending in first iteration of loop:
    		if ( ! inital_msgs_sent ) {
    			inputs.sendStates();
    			outputs.sendStates();
    			inital_msgs_sent = true;
    worked.
    But with ethernet controller loop starts when HA is not yet connected to GW so sent messages do not reach controller 😕
    So, how should I fix it?
    1. Is any way to know if controller is connected ?
    2. Is any way to know if controller requested presentation?
    3. Is any way to know if send message really reached controller?
    TIA, regards,
  • @matkor said in How ethernet gateway code can check if is connected with controller?:
    2. Is any way to know if send message really reached controller?
    Seems positive send() result means message reached controller when executed on gateway?
  • Answering one of my own questions.
    On ethernet gateway send() may return true when there is no connected controller, even when there is no ethernet cable plugged in. 😕
  • 1
  • 10
  • 1
