Trying to build a ethernet gateway but cant set an ip address
  • I have been running a serial gateway for quite a few years now but i have just built a ethernet gateway and am trying to get it up and running.....
    Here is the output from the monitor.
    MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    4 TSM:INIT
    5 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    18 MCO:REG:NOT NEEDED
    601 GWT:TIN:IP=5.0.0.0
    1603 MCO:BGN:STP
    1604 MCO:BGN:INIT OK,TSP=1
    1607 TSM:READY:NWD REQ
    1612 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    1903 TSF:MSG:READ,9-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
    1911 TSF:MSG:READ,0-9-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    1916 TSF:MSG:BC
    1949 TSF:MSG:READ,14-9-0,s=3,c=1,t=16,pt=2,l=2,sg=0:0
    1956 TSF:MSG:READ,11-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    2395 TSF:MSG:READ,14-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    2509 TSF:MSG:READ,10-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    2518 TSF:MSG:READ,10-9-0,s=255,c=3,t=21,pt=1,l=1,sg=0:9
    I cant seem to set an ip address, it keeps giving a random one each time i restart it. Any ideas?
  • Mod
    @JCH could you share how you try to set the ip address?
    This is how setting a static ip address is described on the build page:
    #define MY_IP_ADDRESS 192,168,178,66
  • Here is my gateway code
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,1,6
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 5
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0xDE,0xAD,0xBE,0xEF,0xFE,0xED
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
  • Mod
    @JCH looks similar to https://forum.mysensors.org/topic/9871/ethernet-w5100-gateway-ip-problem/
    How much ram on the Arduino is available after compiling the sketch?
  • How do i find that out? Is it this below?
    Sketch uses 24032 bytes (78%) of program storage space. Maximum is 30720 bytes.
    Global variables use 964 bytes (47%) of dynamic memory, leaving 1084 bytes for local variables. Maximum is 2048 bytes.
  • Mod
    @JCH yes exactly.
    Looks there is plenty of dynamic memory left, so it might not be related to the thread I linked 😞
  • @mfalkvidd any luck on figuring this out. I'm have the same issue
  • Mod
    @hoggin I don't know.
