  3. Motion and lux meters combined in a single device
23 Posts 9 Posters 14.7k Views 6 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    I always wanted a motion sensor that could also detect light levels.
    Until now I used two sensors attached to one arduino to achieve that, but now I make a hardware combination that works and also looks more discreet.
    This is the device I used as a base, adding the light sensor.
    First of all I removed the white dome.
    Then a little adjustment was needed becasue the light sensor is too long so the sensor chip fits properly inside the dome.
    Also the white plastic needed some cutting to allow the circuit to enter the dome.
    The light sensor circuit has to be on the opposite side of this little metal pit in order to fit properly.
    Here is the assembly almos done, with the light sensing chip facing up inside the dome.
    Little hotglue on the corners to hold it toghether
    And that's all to it.
    Here's the code. Just a simple combine of the 2 sensors.
    #include <BH1750.h>
    #include <Wire.h>
    #define CHILD_ID_LIGHT 0
    #define LIGHT_SENSOR_ANALOG_PIN 0
    BH1750 lightSensor;
    // Initialize motion message
    MyMessage msg2(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    uint16_t lastlux;
      gw.begin();
      gw.sendSketchInfo("MotionLuxSensor", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      lightSensor.begin();
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      Serial.println(lux);
      if (lux != lastlux) {
          gw.send(msg2.set(lux));
          lastlux = lux;
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    hekH blaceyB 2 Replies Last reply
    • ferpandoF ferpando
      #include <BH1750.h>
      #include <Wire.h>
      BH1750 lightSensor;
      uint16_t lastlux;
        gw.begin();
            lastlux = lux;
      hekH Offline
      hekH Offline
      @ferpando
      Very nice solution and pictures!
        #include <BH1750.h>
        #include <Wire.h>
        BH1750 lightSensor;
        uint16_t lastlux;
          gw.begin();
              lastlux = lux;
        blaceyB Offline
        blaceyB Offline
        blacey
        @ferpando Nice!
        • ferpandoF Offline
          ferpandoF Offline
          ferpando
          Thank you @hek and @blacey
          It works pretty well.
          It updates light level every 30 seconds and also when movement is detected.
          Also the dome helps average the light level of the room making it more consistent.
          • rvendrameR Offline
            rvendrameR Offline
            rvendrame
            @ferpando, do you run this sensor on battery? Any idea about for how long the battery will last?
            ESP8266 GW + mySensors 2.3.2
            Alexa / Google Home
            • ferpandoF Offline
              ferpandoF Offline
              ferpando
              @rvendrame
              Not at the moment. It is designed to be on a wall socket.
              If you plan to use it on battery, probably would be a good idea to by pass both voltage regulators on the devices and run on 3.3V.
              Also consider increasing the time between light reads.
              • M Offline
                M Offline
                mikemayers
                wrote on last edited by mikemayers
                @ferpando
                very nice setup. What pins are the Lux sensor wired to the Arduino? In the sketch, only pin A0 is defined but on wiring diagram A4 & A5 is used.
                ferpandoF 1 Reply Last reply
                • M mikemayers
                  @ferpando
                  ferpandoF Offline
                  ferpandoF Offline
                  ferpando
                  @mikemayers
                  You need to connect the arduino to pins 4 and 5 for the digital BH1750.
                  I don't know why the sketch references pin 0. Must be something left behind from the analog version.
                  M 1 Reply Last reply
                    @mikemayers
                    M Offline
                    M Offline
                    mikemayers
                    @ferpando got it!
                    • F Offline
                      F Offline
                      floris
                      Thanks! just what i was looking for!
                      Floris
                      • M Offline
                        M Offline
                        mikemayers
                        is it posible to add an LED indicator to tells there's motion. If so what has to be done?
                        AWIA 1 Reply Last reply
                        • M mikemayers
                          AWIA Offline
                          AWIA Offline
                          AWI
                          @mikemayers You could either use the output from the motion sensor directly to operate the LED or write a few lines of code and use an Arduino pin for it. And a Led with resistor of course..
                          • AWIA AWI
                            M Offline
                            M Offline
                            mikemayers
                            I didn't know you could do that. Should I include a resistor in series? For the Adruino pin, do you have a sample code?
                            • M mikemayers
                              AWIA Offline
                              AWIA Offline
                              AWI
                              @mikemayers Yes put a resistor in series with the LED (330 ohm will do). A piece of code can be as simple or complicated as you want. There are plenty of examples in Arduino tutorials. Just take care to take specific measures for power management if using battery power. You need to switch off the LED before you enter sleep mode (or be creative).
                              // in setup
                              pinMode(LED_PIN,OUTPUT);					// define output (LED_PIN = Arduino pin)
                              // in loop (at the right place)
                              if (tripped){    // from the "Blink" example sketch :-)
                                digitalWrite(LED_PIN, HIGH);   // turn the LED on (HIGH is the voltage level)
                                delay(1000);                         // wait for a second
                                digitalWrite(LED_PIN, LOW);    // turn the LED off by making the voltage LOW
                              jeylitesJ 1 Reply Last reply
                              • AWIA AWI
                                // in setup
                                jeylitesJ Offline
                                jeylitesJ Offline
                                jeylites
                                @mikemayers this might work based on @AWI 's blink ... blink idea.
                                #define CHILD_ID 31   // Id of the sensor child
                                #define LED_PIN 5
                                  gw.begin();
                                  gw.sendSketchInfo("Motion Sensor", "1.0");
                                  pinMode(LED_PIN, OUTPUT);
                                   delay(100);        // wait for a second
                                  delay(100);
                                • jeylitesJ jeylites
                                  #define LED_PIN 5
                                    gw.begin();
                                    delay(100);
                                  M Offline
                                  M Offline
                                  mikemayers
                                  @jeylites
                                  Thank you!
                                  It seems to be working I think..... Question: When motion is triggered there is no activity on the LED, but when the motion is turned OFF the LED blinks once. Is it suppose to do that? I was wondering if could it be the other way, blink LED when there's motion and OFF LED when there's no motion. Can that be done? What do I have to change to have it do that? Thanks again guys!
                                  jeylitesJ AWIA 2 Replies Last reply
                                  • M mikemayers
                                    @jeylites
                                    Thank you!
                                    jeylitesJ Offline
                                    jeylitesJ Offline
                                    jeylites
                                    @mikemayers
                                    I get what you're saying and I've no clue on how to do that. :(
                                    • M mikemayers
                                      @jeylites
                                      Thank you!
                                      AWIA Offline
                                      AWIA Offline
                                      AWI
                                      @mikemayers put the gw.sleep(... line at the end of the loop. Everytime motion is detected or released there is an interrupt. At this time the loop starts again and you should check the status and blink the led if on or change.
                                      • AWIA AWI
                                        M Offline
                                        M Offline
                                        mikemayers
                                        @AWI I did as you say on gw and it did turn on the LED when motion is triggered, but the motion remained ON even after the set duration. I think, it's creating a continues loop.
                                        • M mikemayers
                                          AWIA Offline
                                          AWIA Offline
                                          AWI
                                          @mikemayers can you post your sketch?
