Geiger counter + temp.sensors
  • Greetings from Switzerland!
    Let me share with you a small project I did to monitor the radio-activity and temperature (2 sensors).
    The device is installed in my garage and one or the temp. probe is installed in the laundry.
    It is built around the following Geiger counter module : https://www.ebay.com/itm/Geiger-counter-dosimeter-kit-assembled-w-SBT11A-tube-iR-USB-Arduino-compat/162946293010
    Since I have a RFM69 based network, I got the 3.3V module version.
    The tube is an SBT-11a detecting the alpha, beta & gamma radiations and the temp sensors are 2 x 1 wire Dallas DS18B20.
    Here the output (Domoticz)
    The script is really simple. I used the temp sample https://www.mysensors.org/build/temp
    and modified it to push the data to the controller when the geiger counter sends the value to the serial port. To get it working, I had to place the geiger counter in RADLOGGER mode using the IR remote control. Then by adjusting the LOG PERIOD parameters I have defined the frequency at which the counter is pushing the data to the serial port, thus triggering the transmission to the controller (every 5 mn here).
    #define CHILD_ID_RADIATION 90   // Id of the Geiger child
    #include <OneWire.h>
    #define MAX_ATTACHED_DS18B20 2
     //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    int numSensors = 0;
    bool receivedConfig = false;
    bool metric = true;
      // Initialize temperature message and geiger
      MyMessage msg(0, V_TEMP);
      MyMessage msg_rad(CHILD_ID_RADIATION, V_LEVEL);
    void before()
      sensors.begin();
      // initialize the serial communications (must be 9600 for the geiger counter):
      Serial.begin(9600);
    void presentation() {
      sendSketchInfo("Geiger & Temperature Sensors", "2.0");
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        present(i, S_TEMP);
      present(CHILD_ID_RADIATION, S_DUST);
     if (Serial.available()) {
        delay(200);
        String str_cpm = Serial.readStringUntil("\n"); //update str_cpm with serial entry
        send(msg_rad.set(str_cpm.toInt()));    // Send to gateway wiLL BE TRIGGERED WHEN VALUE IS RECEIVED FROM THE COUNTER.ADJUST THE TIMEFRAME FROM THE COUNTER WITH IR REMOTE CONTROL.
      wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
    #else
          send(msg.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
      //sleep(SLEEP_TIME);
    To code is really not optimised but it works at least :)) Feel free to optimise / share 🙂
    There is another possible approach to work with this counter. It is possible to generate an impulse on an output pin at every tube discharge. This is then possible to read these impulses from the arduino then convert them to the right value (CPM, µSv/h...).
    Stay safe !
    All the best !
    Jef
  • 8
  • 1
  • 1
