Error sending switch command, check device/hardware (idx=57)
  • Re: [Error sending switch command](check device/hardware !)
    I know this has been discussed before but with an earlier version of MySensors.
    I have the same problem as disscussed here and want to add an delay for testing if that solves the problem. Using MySensors 2.3.2 but can't find where to add the delay in MyTransport.cpp. Anyone know where to change or having the same issue and found a solution ?
  • 5
  • 5
  • 4
  • 8
