I'm not familiar with the project that inspired this one, but you should pay attention to hot spots, heat should be equally spread across the whole plate.
plus you should have good sensors and provide controllable configuration of heat points for soldering different components according to the manufacturer's datasheet.
@legeantvert said:
On the same way, i dont understand how and where are stored the values inside the gateway if not used on each reception, are they stored somewhere to be able to answer them when serial request arrive?
You could bypass this on some kind of events obviously !
Actually my perl gateway is acting as the server Vera is for the arduino gateway. So from there I can trigger external URL, store data in a sqlite3 database... and so on !
thx for reply
yes dragino HE works like yun I think.
for linkit as the product seems new, there is a little bit less docs. but I will see, price was so interesting that it was too much tempting lol.
I will tell you what I can get...
for fun, I have not presented yet, but I have a board in progress for raildin : 8x relays + 8inputs for yun and I added ethernet connector+hub usb chip
