FOTA/MYSBootloader - Documentation enhacement - Make it clear that you must program only the MYSBootloader, without sketch
  • Hi all,
    I tried to get FOTA working two times before, and I was about to give up a third time as I had always the same problems:
    • After programming the MYSBootloader I loose the ability to do upload sketches via FTDI (with both pro-mini, nano's and barebones 328P)
    • With MySController I could not upload any new FW, even a simple reboot command make the arduino to lock hard and it had to be powered down.
    I tried the oficial github firmwares , the ones from GuilleBot I played with fuses, boards.txt, platformio.ini setting, different GWs, etc, etc, etc....
    Last night I found this issue in github that gave me the detail that was missing. Just do not upload a sketch to the board, only program the MYSBootloader and wait until it asks the FW to the controller!
    Another source of confusion, at least for me, was that I did not knew what to expect of the whole process. What where the different steps and the expected duration of the upload. I will try to describe my setup and how I could finally get it working.
    MySetup
    • Controller: HomeAssistant
    • GW:MQTT GW using ESP8266
    • Portainer from the HomeAssistan AddOns
    • MQTT from the HomeAssistan AddOns (mosquitto)
    • FW Controller - MYCONTROLLER.ORG using MQTT GW.
      Follow this post instructions
      I installed it with docker in the same machine as HA using Portainer and cdrocker's image
    • Platformio.org for building sketches and programming bootloaders
      Out of scope of this post, but way better than using Arduino. Totally worth the pain of learning it's basics.
    • A MQTT Gui to see what is happening between the node and the controller
      I'm using MQTT EXplorer
    • An Arduino UNO as an ISP
    • Sensors: A big mess of half working handmade boards, EasyPCB and SlimNode Sensors.
    Steps
    • Get the correct MYSBootloader for your setup
      Check GuilleBot repository if you are using another nfr24 channel or want to play with different radio power
    • Modify boards.txt or your platformio.ini to add the bootloader
      In my case, for the nano:
    [platformio]
    default_envs =  MYSBootloaderNano
    [env]
    platform = atmelavr
    framework = arduino
    upload_protocol = stk500v1
    upload_port = /dev/ttyACM0
    upload_speed = 19200
    upload_flags =
         -v
         -e
         -P$UPLOAD_PORT
         -b$UPLOAD_SPEED
    lib_deps =
      MySensors
      MySensors NodeManager
    [env:MYSBootloaderNano]
    board = nanoatmega328new
    board_bootloader.file = bootloader/MYSBootloader_16MHz.hex
    The important bits, the upload_flags specially the -e to erase the memory and the board_bootloader.file
    • Program only the bootloader (and the fuses if necessary), for platformio:
    $ platformio -f -c vim run --target bootloader
    • Build the FW of your node, and copy the .hex somewhere on your PC. Again for platformio:
    $ platformio -f -c vim run --target run
    Look in .pio/build/<board>/
    • Add the FW to MyController.org following the product manual
    • Build your HW if needed, plug the radio, etc
    • Be sure to keep the MQTT Explorer and MyController.org to see some feedback of the whole process
    • Powerup the sensor
    • You will see a new node with ID 1 in MyController.org, if you look in "Status -> Resources logs" or in the MQTT Explorer you should see the node asking for a new FW.
    • In MyController.org assign the FW to the new node with ID 1 and upload it.
      Check the manual if in doubt.
    • You will see in MQTT Explorer that the controller and the node get very chatty. The node will ask for each piece of the HEX in small batches.
    • You have some time now, get up and make yourself a cup of coffee and prepare a small celebration.
    • Check the MQTT Explorer, the FW is still uploading... go and get some confetti.
    • Check Mycontroller.org or HomeAssitant, the FW is uploaded and a new node just popup!
      Party mode
    Enjoy!
  • Hero Member
    @MatiasV said in FOTA/MYSBootloader - Documentation enhacement - Make it clear that you must program only the MYSBootloader, without sketch:
    I'd be interested in hearing the full extent of your thoughts as to why you think platformio.org is better. Feel free to start a different thread if that's what you prefer.
  • @NeverDie I can give my thoughts here, and we can move it later to another thread if necessary.
    The bigger selling points, at least for me:
    • Every project is a self contained directory, even the boards configuration, bootloaders, libraries, code and build procedure
      I have a project template for mysensors (mainly a platform.ini) that I copy for each node that I create.
    • I can manage everything with my known tools (vim, make, git, etc)
    I like to play with arduino and electronics, but have other interests (Family, friends and 3 small kids...) so I usually have little time to spent in my hobbies. Platformio allows me to just have all the configuration in code and know 6 months ahead that I can do a "make clean && make upload" for a particular node without issues, even if I lost my PC, as everything is in my gitlab account.
    Also the FW of my 3dprinter must be complied and uploaded with platformio (marlin 2.0) so I can have only one tool for both hobbies.
  • 198
  • 4
  • 73
  • 5
  • 7
  • 9
