Looking for esp8266 moisture sensor sketch that works with current libraries
  • I am trying my hand at setting up my first esp8266 gateway with attached moisture sensor but continue to have compilation errors that others have experienced. The fix seemed to be to find the right mysensors libraries but I am not having any luck (tried 2.00-2.32)..
    Would love to work with a sketch that is known to work with 2.3.1-2.3.2
    Errors:
    /root/Arduino/libraries/MySensors/core/MyGatewayTransportEthernet.cpp:28:22: error: 'MY_ESP8266_SSID' was not declared in this scope
     #define MY_WIFI_SSID MY_ESP8266_SSID
    /root/Arduino/libraries/MySensors/core/MyGatewayTransportEthernet.cpp:163:19: note: in expansion of macro 'MY_WIFI_SSID'
      (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
    /root/Arduino/libraries/MySensors/core/MyGatewayTransportEthernet.cpp:34:26: error: 'MY_ESP8266_PASSWORD' was not declared in this scope
     #define MY_WIFI_PASSWORD MY_ESP8266_PASSWORD
    Sketch:
    #define MY_BAUD_RATE 9600
    // Enables and select radio type (non attached at the moment)
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "****"
    #define MY_ESP8266_PASSWORD "****"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_ESP8266_HOSTNAME "test-sensor-gateway"
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #if defined(MY_USE_UDP)
    #include <WiFiUdp.h>
    #include <ESP8266WiFi.h>
    #define CHILD_ID 0
    int AirValue = 694;
    int WaterValue = 344;
    int intervals = (AirValue - WaterValue)/3;
    int soilMoistureValue = 0;
    MyMessage msg(CHILD_ID, V_LEVEL);
    unsigned long SLEEP_TIME = 30000;
    int sensorPin = A0;
      sendSketchInfo("Soil Moisture Sensor Capacitive", "1.0");
      present(CHILD_ID, S_MOISTURE);
      int soilMoistureValue;
      soilMoistureValue = analogRead(sensorPin);
      if(soilMoistureValue > WaterValue && soilMoistureValue < (WaterValue + intervals))
          send(msg.set(100));
        else if(soilMoistureValue > (WaterValue + intervals) && soilMoistureValue < (AirValue - intervals))
            send(msg.set(50));
        else if(soilMoistureValue < AirValue && soilMoistureValue > (AirValue - intervals))
           send(msg.set(0));
    sleep(SLEEP_TIME);
    // note-to-self: search for possible wait() alternative or deep-sleep
  • Fixed it with the following changes: .(Still interested in finding more esp8266 sketches)
    #define MY_WIFI_SSID ""
    #define MY_WIFI_PASSWORD ""
    #define MY_HOSTNAME "test-sensor-gateway"
    #define CHILD_ID 0
    int AirValue = 694;
    int sensorPin = A0;
          send(msg.set(100));
            send(msg.set(50));
           send(msg.set(0));
    sleep(SLEEP_TIME);
  • Mod
    @mrhutchinsonmn esp8266 does not support sleep(). The sleep call will return immediately.
    On the other hand, sleeping a gateway will cause any connection to a controller to fail, so if sleep had worked, not much else would.
    Was your intention to sleep the esp, or did the sleep call just come along with copied code?
  • @mfalkvidd was part of the sketch. I could see right away that sleep did not work 🙂
  • 4
  • 1
  • 9
  • 14
  • 933
